hoozr
April 18, 2022, 6:49pm
#1
Hello there!
I am configuring keycloak in compose like that:
keycloak:
image: quay.io/keycloak/keycloak:17.0.1
depends_on:
- keycloakdb
networks:
- net
environment:
KC_DB: postgres
KC_DB_URL: jdbc:postgresql://keycloakdb/keycloak
KC_DB_USERNAME: keycloak
KC_DB_PASSWORD: password
KEYCLOAK_ADMIN: admin
KEYCLOAK_ADMIN_PASSWORD: sS3459ol
KC_HOSTNAME_STRICT: 'false'
KC_HOSTNAME_STRICT_HTTPS: 'false'
KC_METRICS_ENABLED: 'true'
KC_FEATURES: token-exchange
KC_HTTP_ENABLED: 'true'
command:
- "start"
- "--auto-build"
- "--hostname=localhost"
- "--hostname-port=3000"
- "--hostname-path=/keycloak"
- "--proxy"
- "edge"
container_name: keycloak
I have nginx proxy with such config:
nginx:
build: src/nginx
environment:
ENVIRONMENT_NAME: Development
ports:
- "3000:80"
server {
listen 80;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload";
proxy_http_version 1.1;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header Host $http_host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_pass_request_headers on;
location / {
root /usr/share/nginx/html;
index index.html index.htm;
try_files $uri $uri/ /index.html;
location /keycloak/ {
proxy_pass http://keycloak/;
When navigating to http://localhost:3000/keycloak
I am redirecting to 80 port… What did I miss?
Thanks in advance.
xgp
April 18, 2022, 7:22pm
#2
isn’t "3000:80"
mapping 3000 to the HOST_PORT in a docker compose file, which means 3000 will be exposed on the host and mapped to 80 in the container?
hoozr
April 18, 2022, 7:54pm
#3
Yes, you’re right. So then should I change --hostname-port
to 80 because nginx listening 80 in container?
xgp
April 18, 2022, 8:39pm
#4
Take a look at the docker-compose documentation. That’s not a Keycloak issue.
hoozr
April 18, 2022, 8:45pm
#5
I see there is an active bug for this case in 17.0.1
aksolv
April 19, 2022, 8:24am
#7
Keycloak thinks it’s being accessed on port 80, but the browser is contacting port 3000, if I see it correctly.
You also need KC_PROXY=“edge”.
And HTTP_ADDRESS_FORWARDING=true
And “/keycloak” isn’t the standard path for keycloak so you need KC_HTTP_RELATIVE_PATH=/keycloak
There is a guide on how to setup keycloak behind a reverse proxy. Just ignore everything it says about which paths not to expose, because at least at first you need all of them…
hoozr
April 19, 2022, 9:11am
#9
Thanks, I’ve tried like that. Now I have “Resource not found” from nginx
My nginx.conf:
server {
listen 80;
proxy_set_header Host $host;
location / {
location /keycloak {
proxy_pass http://keycloak/keycloak;
location /api/ {
proxy_pass http://gateway:8080/;
and keycloak setup
keycloak:
environment:
KC_DB: postgres
KC_DB_PASSWORD: secured
KEYCLOAK_ADMIN_PASSWORD: secured
KC_PROXY: edge
KC_HTTP_RELATIVE_PATH: /keycloak
HTTP_ADDRESS_FORWARDING: 'true'
command:
- "start"
- "--auto-build"
hoozr
April 19, 2022, 9:14am
#10
Thanks, xgp , I’ve already tried these. There is very low info about configuring nginx reverse proxy instance.
aksolv
April 19, 2022, 2:04pm
#11
From what you posted, there shouldn’t be anything listening on localhost:8080.
If the docker-compose.yml is the same as above I would expect keycloak at localhost:3000/keycloak/
hoozr
April 19, 2022, 4:39pm
#13
Now I succed to get to welcome page, but when clicking admin console, getting such weird
Nginx config:
server {
listen 8080;
proxy_pass http://keycloak:8080/;
location /admin/ {
proxy_pass http://keycloak:8080/admin;
location /resources/ {
proxy_pass http://keycloak:8080/resources;
location /keycloak/auth/ {
proxy_pass http://keycloak:8080/keycloak/;
nginx:
build: src/nginx
container_name: nginx
ports:
- "8080:8080"
What did I miss?
hoozr
April 19, 2022, 4:52pm
#14
Finally got it worked, now testing. If suceed I write all configs.
If you have the link for the guide, vould you please post it here? Is it different than keycloak documentation?
Did it work? Could you mention what did you do?
hoozr
April 22, 2022, 8:33am
#17
Yes, it worked. Something was not detailed in up-to-date configuration, especially nginx setup.
Keycloak
keycloak:
environment:
KC_DB: postgres
KC_DB_URL: jdbc:postgresql://secured/keycloak
PROXY_ADDRESS_FORWARDING: 'true'
KC_HOSTNAME_STRICT_BACKCHANNEL: 'false'
command:
- "start"
- "--auto-build"
- "--proxy=passthrough" // depends on your load balancer setup, if have TLS termination on upper layer then use "edge" value
Nginx
services:
nginx:
build: src/nginx
environment:
ports:
- "3000:80"
Nginx.conf
server {
listen 80;
location / {
location /api/ {
proxy_set_header X-Correlation-Id $connection-$connection_requests-$msec;
proxy_set_header X-Forwarded-Port 3000;
location /admin/ {
proxy_pass http://keycloak:8080/admin/;
proxy_pass http://keycloak:8080/resources/;
location /js/ {
proxy_pass http://keycloak:8080/js/;
location /realms/ {
proxy_pass http://keycloak:8080/realms/;
With this configuration I have an access to keycloak which sits in internal docker network from exposed 3000 nginx port via http://localhost:3000/keycloak
hmof
April 25, 2022, 7:06am
#18
You don’t need the ports configuration in the docker-compose file since you are telling the reverse proxy to access http://keycloak:8080 . You only need it to access the port directly from elsewhere on the network.
You still seem to have a mix of port 8080 and port 80 though. And the port definition, if you want to keep it, should almost certainly be “127.0.0.1:3000:80”, else the port is exposed to the whole network unless blocked by a firewall elsewhere.
