Keycloak 17 "failed to initialize keycloak"
Trying to run Keycloak 17 in container behind load balancer. Current setup:
AWS ALB
1 EC2 instance
Docker
Dockerfile:
FROM quay.io/keycloak/keycloak:17.0.0 as builder
ENV KC_METRICS_ENABLED=true
ENV KC_DB=mariadb
COPY --from=builder /opt/keycloak/lib/quarkus/ /opt/keycloak/lib/quarkus/
WORKDIR /opt/keycloak
ENV KC_LOG_LEVEL=DEBUG
ENV KC_PROXY=edge
ENV KC_HTTP_ENABLED=true
ENTRYPOINT ["/opt/keycloak/bin/kc.sh", "start"]
Docker run command:
docker run -d -p 8080:8080 \
    -e KEYCLOAK_ADMIN=admin -e KEYCLOAK_ADMIN_PASSWORD=admin \
    -e KC_DB_URL=jdbc:mariadb://ip-1-2-3-4.us-west-2.compute.internal:3306/keycloak17 \
    -e KC_DB_USERNAME=keycloak \
    -e KC_DB_PASSWORD=keycloak \
    -e KC_PROXY=edge \
    -e KC_HOSTNAME=keycloak.not-a-rea-ldomain.net \
    -e KC_HOSTNAME_STRICT=false \
    local/keycloak17
Everything seems to be fine, except when I try to go to an account console such as https://keycloak.not-a-real-domain.net/realms/Test123/account/ it fails with the below error:
I don’t see anything obvious in the DEBUG log, I’ve also tried to set the frontend URL for the realm but that didn’t help either.
Any advice?
Thanks.
goto the client ‘Account-console’ (under Master realms) and add ‘+’ to web origins.
tell me if it works for you.
Thanks.
Hi @Raf,
Thanks, that worked. I had to do it for both “account” and “account-console”, which wasn’t immediately obvious, but thanks for your assistance.
