You do not know how to set up logging similar to the one below in the new Keycloak 17 with Quarkus?
Typically how send logs to some IP? and other?
/opt/jboss/keycloak/bin/jboss-cli.sh --connect --command='/subsystem=logging/logger=org.keycloak.events/:add(category=org.keycloak.events,level=DEBUG)'
/opt/jboss/keycloak/bin/jboss-cli.sh --connect --command='/subsystem=logging/xml-formatter=LOG-STASH:add(key-overrides={message=@message})'
/opt/jboss/keycloak/bin/jboss-cli.sh --connect --command='/socket-binding-group=standard-sockets/remote-destination-outbound-socket-binding=log-stash:add(host=127.0.0.1, port=5044)'
/opt/jboss/keycloak/bin/jboss-cli.sh --connect --command='/subsystem=logging/socket-handler=LOGSTASH-SOCKET:add(named-formatter=LOG-STASH, outbound-socket-binding-ref=log-stash, level=DEBUG)'
/opt/jboss/keycloak/bin/jboss-cli.sh --connect --command='/subsystem=logging/async-handler=LOGSTASH-ASYNC:add(queue-length=512, subhandlers=[LOGSTASH-SOCKET])'
/opt/jboss/keycloak/bin/jboss-cli.sh --connect --command='/subsystem=logging/root-logger=ROOT:add-handler(name=LOGSTASH-ASYNC)'
