We are using keycloak as IDP and have some custom plugins/Spi, we are in process of updating our keycloak instance to version 17 Quarkas distribution and the SPIs began to break (error below) during keycloak build process. I’ve made sure that there are no keycloak libraries packed as part of jar.
The SPI looks like below and have corresponding entries in Manifest file under Manifest/services/org.keycloak.services.resource.RealmResourceProviderFactory
Custom SPI/plugin
public class SwaggerJsonRetrieverFactory implements RealmResourceProviderFactory {
@Override
public RealmResourceProvider create(KeycloakSession session) {
return new SwaggerJsonRetriever(session);
@Override
public void init(Config.Scope config) {
@Override
public void postInit(KeycloakSessionFactory factory) {
@Override
public void close() {
@Override
public String getId() {
return "swagger.json";
My pom.xml looks like below
<dependencies>
<dependency>
<artifactId>keycloak-core</artifactId>
<scope>provided</scope>
<version>${keycloak.version}</version>
</dependency>
<dependency>
<artifactId>keycloak-server-spi</artifactId>
</dependency>
<dependency>
<artifactId>keycloak-services</artifactId>
</dependency>
<dependency>
<artifactId>keycloak-server-spi-private</artifactId>
</dependency>
<dependency>
<groupId>io.swagger</groupId>
<artifactId>swagger-parser</artifactId>
<version>1.0.22</version>
</dependency>
<dependency>
<groupId>ch.qos.logback</groupId>
<artifactId>logback-classic</artifactId>
<version>${logback.version}</version>
</dependency>
<dependency>
<artifactId>logback-core</artifactId>
</dependency>
<dependency>
<groupId>com.fasterxml.jackson.dataformat</groupId>
<artifactId>jackson-dataformat-yaml</artifactId>
<version>${jackson-dataformat-yaml.version}</version>
</dependency>
</dependencies>
The error which I’m getting
io.quarkus.builder.BuildException: Build failure: Build failed due to errors
[error]: Build step io.quarkus.arc.deployment.ArcProcessor#validate threw an exception: javax.enterprise.inject.spi.DeploymentException: Found 2 deployment problems:
[1] Unsatisfied dependency for type org.keycloak.models.KeycloakSession and qualifiers [@Default]
- java member: com.abc.swagger.SwaggerJsonRetriever().session
- declared on CLASS bean [types=[com.abc.swagger.SwaggerJsonRetriever, java.lang.Object], qualifiers=[@Default, @Any], target=com.abc.swagger.SwaggerJsonRetriever]
[2] Unsatisfied dependency for type org.keycloak.models.KeycloakSession and qualifiers [@Default]
Is there any configuration which I’m missing, any help will be appreciated.
