I’m using keycloak-admin-client-17.0.0.jar and the org.keycloak.admin.client.Keycloak class.
In version 16 I was able to use this code to get back the list of realms.
In 17 I get following stack trace.
CODE
Optional<RealmRepresentation> representationOptional = keycloakAdmin.realms().findAll().stream() .filter(r -> r.getRealm().equals(COMPANY_SERVICE_REALM_NAME)).findAny();
STACK TRACE
Caused by: javax.ws.rs.NotAuthorizedException: HTTP 401 Unauthorized
at org.jboss.resteasy.client.jaxrs.internal.ClientInvocation.handleErrorStatus(ClientInvocation.java:222) ~[resteasy-client-3.13.2.Final.jar:3.13.2.Final]
at org.jboss.resteasy.client.jaxrs.internal.ClientInvocation.extractResult(ClientInvocation.java:196) ~[resteasy-client-3.13.2.Final.jar:3.13.2.Final]
at org.jboss.resteasy.client.jaxrs.internal.proxy.extractors.BodyEntityExtractor.extractEntity(BodyEntityExtractor.java:62) ~[resteasy-client-3.13.2.Final.jar:3.13.2.Final]
at org.jboss.resteasy.client.jaxrs.internal.proxy.ClientInvoker.invokeSync(ClientInvoker.java:151) ~[resteasy-client-3.13.2.Final.jar:3.13.2.Final]
at org.jboss.resteasy.client.jaxrs.internal.proxy.ClientInvoker.invoke(ClientInvoker.java:112) ~[resteasy-client-3.13.2.Final.jar:3.13.2.Final]
at org.jboss.resteasy.client.jaxrs.internal.proxy.ClientProxy.invoke(ClientProxy.java:76) ~[resteasy-client-3.13.2.Final.jar:3.13.2.Final]
at com.sun.proxy.$Proxy138.grantToken(Unknown Source) ~[na:na]
at org.keycloak.admin.client.token.TokenManager.grantToken(TokenManager.java:90) ~[keycloak-admin-client-17.0.0.jar:17.0.0]
at org.keycloak.admin.client.token.TokenManager.getAccessToken(TokenManager.java:70) ~[keycloak-admin-client-17.0.0.jar:17.0.0]
at org.keycloak.admin.client.token.TokenManager.getAccessTokenString(TokenManager.java:65) ~[keycloak-admin-client-17.0.0.jar:17.0.0]
at org.keycloak.admin.client.resource.BearerAuthFilter.filter(BearerAuthFilter.java:52) ~[keycloak-admin-client-17.0.0.jar:17.0.0]
at org.jboss.resteasy.client.jaxrs.internal.ClientInvocation.filterRequest(ClientInvocation.java:579) ~[resteasy-client-3.13.2.Final.jar:3.13.2.Final]
... 12 common frames omitted
I can see the code comes down to this section…
tokenService.grantToken(config.getRealm(), form.asMap());
The params passed in look correct. ‘master’ for the realm, the map contains the same as I had in 16.
(This is a test, so the password and username are as expected)
I presume there must be a setting on the Master realm to allow a Service type account, or something else I’m missing that was enabled in 16, but is not in 17.
Can someone help?
