This used to work fine till I switched to keycloak v18.x.x Quarkus. I updated the JavaScript adapter (keycloak-js) to v19.0.1 which at least logs-out the user now but still haven’t figured out how to redirect back to the login page.
What I understand from the release notes is that the mechanism to logout has been changed. But what I don’t understand is how and where do I use this post_logout_redirect_uri or any other method, as a matter of fact, to just redirect back to login
I’m sorry but I’m quite new to this and don’t understand by what you mean when you say “pre-register the post logout uri in the server”. The only thing I did was download Quarkus v18.0.2 and run this command
Hey guys, im having the same problem, but im using Vue.js instead of React.
My problem is on post_logout_redirect_uri. I didn’t find where to set this url on my client in Keycloak’s web interface.
Could you tell me better or show me where to place the log out url’s registration field? @weltonrodrigo
This options is only available in Keycloak from v18+. The release notes have a pretty decent explanation and rationale. They link to the appropriate section on the manual.
The url ifself must be entered at this field (this is for the new admin console, the old one is similar):
I’ve seen some images on the forum that actually show this field for logout. However, the sequence of fields is a little different from what’s available to me. I’ll check the version of my Keycloak.
Thank you very much.
@weltonrodrigo this current project is unfortunately not for the government, however, where I work we have projects under contract with the government.
The problem I’m encountering is that inside Keycloak (this image is from a local installation of 18.0.1) the field I’ve seen in other discussions on the forum. Even the interface is different. Is there any interface update that might be causing this problem?
Have you tried enabling the option Front Channel logout? This should enable the Front-Channel Logout URL and Front-Channel Logout Session Required options.
Yes!
The post_logout_redirect_url URL is also not changed in the payload even after I enable Front Channel Logout and set a specific URL.
Logout is invoking the same URL as the page that is loaded at the time it should be logging out rather than redirecting to another URL.
Note: this error screen is appearing only in the browser. In my API there is no error.
@jvhk Sorry, I confused the features. The front-channel logout url is one thing and the RP-Initiated Logout is another.
As stated in the other thread (I really believe cross posting this is not ideal), I believed you should include the post redirect url as a redirect URI in the admin console.
