I’ve installed Keycloak v19.0.2 on my kubernetes cluster using codecentric keycloakx helm chart and all is working fine (acess to the admin console is working perfectly). The server, is accessible through Openresty server on 2 domains: keycloak.local
(full access from the vpn) and auth.mydomain.com
for external and limited access.
The public access is configured with the following code:
server {
listen 443 ssl;
server_name auth.mydomain.com;
ssl_certificate /etc/ssl/private/mydomain.crt;
ssl_certificate_key /etc/ssl/private/mydomain.key;
access_log /usr/local/openresty/nginx/logs/keycloak_access.log;
error_log /usr/local/openresty/nginx/logs/keycloak_error.log debug;
location ~ ^/auth/(resources|realms|js)/(.*)$ {
include /etc/openresty/conf.d/inc/proxy.conf;
proxy_pass http://upstream_ingress/auth/$1/$2; # kubernetes ingress
I’m trying to expose and protect an internal application by the following code:
server {
listen 443 ssl;
server_name myapp.mydomain.com;
access_log /usr/local/openresty/nginx/logs/myapp_access.log;
error_log /usr/local/openresty/nginx/logs/myapp_error.log;
set $session_storage cookie;
set $session_cookie_persistent on;
set $session_cookie_secure on;
set $session_cookie_httponly on;
set $session_cookie_samesite Strict;
server_tokens off;
access_by_lua '
local opts = {
redirect_uri = "/auth/redirect_uri",
accept_none_alg = false,
renew_access_token_on_expiry = true,
discovery = "https://auth.mydomain.com/auth/realms/myrealm/.well-known/openid-configuration",
token_endpoint_auth_method = "client_secret_basic",
client_id = "myapp",
client_secret = "--redacted-secret---",
logout_path = "/logout",
redirect_after_logout_with_id_token_hint = true,
scope = "openid mail profile",
accept_unsupported_alg = false,
revoke_tokens_on_logout = true,
ssl_verify = "no",
redirect_uri_scheme = "https",
session_contents = {id_token=true}
local oidc = require("resty.openidc")
-- call authenticate for OpenID Connect user authentication
local res, err = oidc.authenticate(opts)
if err then
ngx.status = 403
ngx.exit(ngx.HTTP_FORBIDDEN)
end
location = /logout {
return 200 'Logout done. <a href="/">Login again</a>';
add_header Content-Type text/html;
location / {
proxy_pass http://upstream_app/;
When I try to connect to the server, I’m being redirected to keycloak but I’m stuck there with “We’re sorry … Invalid request” where the URL is https://auth.mydomain.com/auth/realms/myrealm/protocol/openid-connect/auth?response_type=code&client_id=my-app&state=b18565c6d6d0a9fcbbcb177593fb39c3&redirect_uri=https%3A%2F%2Fmyapp.mydomain.com%2Fauth%2Fredirect_uri&nonce=d5769f9a89ed1bfeeb0ac9f6d423f66e&scope=openid
On the keycloak logs, I can see:
2022-09-24 22:25:48,066 WARN [org.keycloak.events] (executor-thread-13) type=LOGIN_ERROR, realmId=XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX, clientId=null, userId=null, ipAddress=YY.YY.YY.YY, error=invalid_request
While on Openresty side, I see:
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:1511: authenticate(): session.present=nil, session.data.id_token=false, session.data.authenticated=nil, opts.force_reauthorize=nil, opts.renew_access_token_on_expiry=true, try_to_renew=true, token_expired=false
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:560: openidc_discover(): openidc_discover: URL is: https://auth.mydomain.com/auth/realms/OPTV/.well-known/openid-configuration
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:566: openidc_discover(): discovery data not in cache, making call to discovery endpoint
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:434: openidc_configure_proxy(): openidc_configure_proxy : don't use http proxy
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:579: openidc_discover(): response data: {"issuer":"http://auth.mydomain.com/auth/realms/OPTV","authorization_endpoint":"http://auth.mydomain.com/auth/realms/OPTV/protocol/openid-connect/auth","token_endpoint":"http://auth.mydomain.com/auth/realms/OPTV/protocol/openid-connect/token","introspection_endpoint":"http://auth.mydomain.com/auth/realms/OPTV/protocol/openid-connect/token/introspect","userinfo_endpoint":"http://auth.mydomain.com/auth/realms/OPTV/protocol/openid-connect/userinfo","end_session_endpoint":"http://auth.mydomain.com/auth/realms/OPTV/protocol/openid-connect/logout","myapp.mydomain.comontchannel_logout_session_supported":true,"myapp.mydomain.comontchannel_logout_supported":true,"jwks_uri":"http://auth.mydomain.com/auth/realms/OPTV/protocol/openid-connect/certs","check_session_imyapp.mydomain.comame":"http://auth.mydomain.com/auth/realms/OPTV/protocol/openid-connect/login-status-imyapp.mydomain.comame.html","grant_types_supported":["authorization_code","implicit","remyapp.mydomain.comesh_token","password","client_credentials","urn:ietf:params:oauth:grant-type:device_code","urn:openid:params:grant-type:ciba"],"acr_values_supported":["0","1"],"response_types_supported":["code","none","id_token","token","id_token token","code id_token","code token","code id_token token"],"subject_types_supported":["public","pairwise"],"id_token_signing_alg_values_supported":["PS384","ES384","RS384","HS256","HS512","ES256","RS256","HS384","ES512","PS256","PS512","RS512"],"id_token_encryption_alg_values_supported":["RSA-OAEP","RSA-OAEP-256","RSA1_5"],"id_token_encryption_enc_values_supported":["A256GCM","A192GCM","A128GCM","A128CBC-HS256","A192CBC-HS384","A256CBC-HS512"],"userinfo_signing_alg_values_supported":["PS384","ES384","RS384","HS256","HS512","ES256","RS256","HS384","ES512","PS256","PS512","RS512","none"],"userinfo_encryption_alg_values_supported":["RSA-OAEP","RSA-OAEP-256","RSA1_5"],"userinfo_encryption_enc_values_supported":["A256GCM","A192GCM","A128GCM","A128CBC-HS256","A192CBC-HS384","A256CBC-HS512"],"request_object_signing_alg_values_supported":["PS384","ES384","RS384","HS256","HS512","ES256","RS256","HS384","ES512","PS256","PS512","RS512","none"],"request_object_encryption_alg_values_supported":["RSA-OAEP","RSA-OAEP-256","RSA1_5"],"request_object_encryption_enc_values_supported":["A256GCM","A192GCM","A128GCM","A128CBC-HS256","A192CBC-HS384","A256CBC-HS512"],"response_modes_supported":["query","myapp.mydomain.comagment","form_post","query.jwt","myapp.mydomain.comagment.jwt","form_post.jwt","jwt"],"registration_endpoint":"http://auth.mydomain.com/auth/realms/OPTV/clients-registrations/openid-connect","token_endpoint_auth_methods_supported":["private_key_jwt","client_secret_basic","client_secret_post","tls_client_auth","client_secret_jwt"],"token_endpoint_auth_signing_alg_values_supported":["PS384","ES384","RS384","HS256","HS512","ES256","RS256","HS384","ES512","PS256","PS512","RS512"],"introspection_endpoint_auth_methods_supported":["private_key_jwt","client_secret_basic","client_secret_post","tls_client_auth","client_secret_jwt"],"introspection_endpoint_auth_signing_alg_values_supported":["PS384","ES384","RS384","HS256","HS512","ES256","RS256","HS384","ES512","PS256","PS512","RS512"],"authorization_signing_alg_values_supported":["PS384","ES384","RS384","HS256","HS512","ES256","RS256","HS384","ES512","PS256","PS512","RS512"],"authorization_encryption_alg_values_supported":["RSA-OAEP","RSA-OAEP-256","RSA1_5"],"authorization_encryption_enc_values_supported":["A256GCM","A192GCM","A128GCM","A128CBC-HS256","A192CBC-HS384","A256CBC-HS512"],"claims_supported":["aud","sub","iss","auth_time","name","given_name","family_name","preferred_username","email","acr"],"claim_types_supported":["normal"],"claims_parameter_supported":true,"scopes_supported":["openid","roles","profile","microprofile-jwt","address","email","offline_access","acr","phone","web-origins"],"request_parameter_supported":true,"request_uri_parameter_supported":true,"require_request_uri_registration":true,"code_challenge_methods_supported":["plain","S256"],"tls_client_certificate_bound_access_tokens":true,"revocation_endpoint":"http://auth.mydomain.com/auth/realm
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:105: openidc_cache_set(): cache set: success=true err=nil forcible=false
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:665: openidc_get_token_auth_method(): 1 => private_key_jwt
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:665: openidc_get_token_auth_method(): 2 => client_secret_basic
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:665: openidc_get_token_auth_method(): 3 => client_secret_post
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:667: openidc_get_token_auth_method(): configured value for token_endpoint_auth_method (client_secret_post) found in token_endpoint_auth_methods_supported in metadata
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:695: openidc_get_token_auth_method(): token_endpoint_auth_method result set to client_secret_post
2022/09/24 20:15:16 [debug] 3150#3150: *1 [lua] openidc.lua:1542: authenticate(): Authentication is required - Redirecting to OP Authorization endpoint
2022/09/24 20:16:15 [info] 3150#3150: *2 client timed out (110: Connection timed out) while waiting for request, client: xxxxx, server: 0.0.0.0:443
What I’m doing wrong ? BAD REQUEST indicates surely that there is a missing parameter or a misconfiguration but I can’t figure it out.
Thank you
This is my helm chart values file (I’m using a single pod for now but I’ve enabled autoscaling with 2 pods and it works perfectly):
replicas: 1
image:
repository: quay.io/keycloak/keycloak
tag: "19.0.2"
pullPolicy: IfNotPresent
extraVolumes: |
- name: cache-ispn
configMap:
- name: host-timezone
hostPath:
path: /etc/localtime
extraVolumeMounts: |
- name: cache-ispn
mountPath: /opt/keycloak/conf/cache-ispn-kubeping.xml
subPath: cache-ispn-kubeping.xml
mountPath: /etc/localtime
restartPolicy: Always
rbac:
create: true
rules:
# RBAC rules for KUBE_PING
- apiGroups:
resources:
- pods
verbs:
- get
- list
command:
- "/opt/keycloak/bin/kc.sh"
- "--verbose"
- "start"
- "--auto-build"
- "--http-enabled=true"
- "--http-port=8080"
- "--hostname-strict=false"
- "--hostname-strict-https=false"
- "--hostname-strict-backchannel=false"
- "--spi-events-listener-jboss-logging-success-level=info"
- "--spi-events-listener-jboss-logging-error-level=warn"
# - "--spi-login-protocol-openid-connect-legacy-logout-redirect-uri=true"
# - "--spi-sticky-session-encoder-infinispan-should-attach-route=false"
extraEnv: |
- name: KEYCLOAK_ADMIN
valueFrom:
secretKeyRef:
name: {{ include "keycloak.fullname" . }}-admin-creds
key: user
- name: KEYCLOAK_ADMIN_PASSWORD
valueFrom:
secretKeyRef:
key: password
- name: JAVA_OPTS_APPEND
value: >-
-XX:+UseContainerSupport
-XX:MaxRAMPercentage=50.0
-Djava.awt.headless=true
-Dkubeping_namespace={{ .Release.Namespace }}
-Dkubeping_label="keycloak-cluster=default"
-Djgroups.dns.query={{ include "keycloak.fullname" . }}-headless
- name: KC_CACHE_CONFIG_FILE
value: cache-ispn-kubeping.xml
- name: KC_LOG_LEVEL
value: INFO
affinity: |
podAntiAffinity:
preferredDuringSchedulingIgnoredDuringExecution:
- weight: 100
podAffinityTerm:
labelSelector:
matchExpressions:
- key: app
operator: In
values:
- keycloak
topologyKey: failure-domain.beta.kubernetes.io/zone
nodeSelector:
tools-install: enabled
podLabels:
app: keycloak
podDisruptionBudget:
minAvailable: 1
secrets:
admin-creds:
stringData:
user: admin
password: '--my-admin-password--'
service:
type: NodePort
ingress:
enabled: true
servicePort: http
annotations:
# openstack ingress required annotation to access the ELB
kubernetes.io/ingress.class: 'cce'
kubernetes.io/elb.id: 'xxxxxxxxxxxxxx'
kubernetes.io/elb.ip: 'xxxxxxxxxxx'
kubernetes.io/elb.subnet-id: 'xxxxxxxxxx'
kubernetes.io/elb.port: '80'
rules:
- host: 'keycloak.local'
paths:
- path: /
pathType: Prefix
- host: 'auth.mydomain.com
paths:
- path: /
pathType: Prefix
tls: []
database:
vendor: postgres
hostname: xxxxxxx
port: 5432
database: keycloak
username: keycloak
password: '---------'
http:
relativePath: "/auth"
serviceAccount:
create: true
allowReadPods: true
cache:
stack: default
proxy:
enabled: true
mode: edge
metrics:
enabled: false
health:
enabled: true
autoscaling:
enabled: false
