Keycloak 25.0.2 Stuck Loading Admin Console
I am trying to setup and test Keycloak 25.0.2 on an EKS cluster behind the AWS load balancer and getting an Admin UI loading screen that is all
my deployment.yaml looks like this
Environment: │
│ KC_LOG_LEVEL: info │
│ KC_HOSTNAME_DEBUG: true │
│ KEYCLOAK_ADMIN: admin │
│ KEYCLOAK_ADMIN_PASSWORD: admin │
│ KC_HTTP_RELATIVE_PATH: /auth/ │
│ KC_HTTPS_CERTIFICATE_FILE: /etc/certs/tls.crt │
│ KC_HTTPS_CERTIFICATE_KEY_FILE: /etc/certs/tls.key │
│ KC_HEALTH_ENABLED: true │
│ KC_METRICS_ENABLED: true │
│ KC_HOSTNAME: authentication.test.digitalml.com
│ KC_PROXY_HEADERS: xforwarded │
│ KC_DB: oracle │
│ KC_DB_URL_HOST: ignite7-beta-db1.cbckam62djkc.us-east-1.rds.amazonaws.com
│ KC_DB_URL_PORT: 1560 │
│ KC_DB_URL_DATABASE: ICSPRDB1 │
│ KC_DB_SCHEMA: KEYCLOAK_TEST │
│ jgroups.dns.query: keycloak │
│ KC_DB_USERNAME: <set to the key ‘keycloak_db_username’ in secret ‘keycloak-secret’> Optional: false │
│ KC_DB_PASSWORD: <set to the key ‘keycloak_db_password’ in secret ‘keycloak-secret’> Optional: false │
│ KEYCLOAK_USER: <set to the key ‘keycloak_adm_username’ in secret ‘keycloak-secret’> Optional: false │
│ KEYCLOAK_PASSWORD: <set to the key ‘keycloak_adm_password’ in secret ‘keycloak-secret’> Optional: false │
│ PROXY_ADDRESS_FORWARDING: true │
│ KEYCLOAK_STATISTICS: all
You still having issues?
I suspect, KC_HTTP_RELATIVE_PATH: /auth/ might be your issue.
Would if you try KC_HTTP_RELATIVE_PATH: /.
I’d set log level to debug KC_LOG_LEVEL: debug
