Hello
When I start Keycloak with new database I have this stacktrace
This is kubeernates deployment
spec:
containers:
- env:
- name: KEYCLOAK_USER
value: admin
- name: KEYCLOAK_PASSWORD
value: abc
value: "true"
- name: KEYCLOAK_LOGLEVEL
value: WARN
- name: DB_VENDOR
value: mysql
- name: DB_ADDR
value: db.eu-west-1.rds.amazonaws.com
- name: DB_DATABASE
value: keycloak
- name: DB_SCHEMA
value: keycloak
- name: DB_PORT
value: "3306"
- name: DB_USER
value: keycloak
- name: DB_PASSWORD
value: PPPPPPP
- name: JDBC_PARAMS
value: character_set_server=utf8mb4&useUnicode=true&verifyServerCertificate=false&useSSL=true&requireSSL=true&allowPublicKeyRetrieval=true&serverTimezone=Europe/Paris
image: jboss/keycloak:7.0.1
And the stacktrace
Added 'admin' to '/opt/jboss/keycloak/standalone/configuration/keycloak-add-user.json', restart server to load user
-b 0.0.0.0
Using MySQL database
18:52:41,473 INFO [org.jboss.as] (MSC service thread 1-1) WFLYSRV0050: Keycloak 7.0.1 (WildFly Core 9.0.2.Final) stopped in 18ms
JBoss Bootstrap Environment
JBOSS_HOME: /opt/jboss/keycloak
JAVA: java
JAVA_OPTS: -server -Xms64m -Xmx512m -XX:MetaspaceSize=96M -XX:MaxMetaspaceSize=256m -Djava.net.preferIPv4Stack=true -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true --add-exports=java.base/sun.nio.ch=ALL-UNNAMED --add-exports=jdk.unsupported/sun.misc=ALL-UNNAMED --add-exports=jdk.unsupported/sun.reflect=ALL-UNNAMED
18:52:42,256 INFO [org.jboss.modules] (main) JBoss Modules version 1.9.1.Final
18:52:42,747 INFO [org.jboss.msc] (main) JBoss MSC version 1.4.8.Final
18:52:42,766 INFO [org.jboss.threads] (main) JBoss Threads version 2.3.3.Final
18:52:42,908 INFO [org.jboss.as] (MSC service thread 1-2) WFLYSRV0049: Keycloak 7.0.1 (WildFly Core 9.0.2.Final) starting
18:52:46,098 INFO [org.jboss.as.ejb3] (MSC service thread 1-2) WFLYEJB0493: EJB subsystem suspension complete
18:52:46,179 INFO [org.wildfly.extension.undertow] (MSC service thread 1-1) WFLYUT0006: Undertow HTTPS listener https listening on 0.0.0.0:8443
18:52:46,250 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-1) WFLYJCA0001: Bound data source [java:jboss/datasources/ExampleDS]
18:52:46,250 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-1) WFLYJCA0001: Bound data source [java:jboss/datasources/KeycloakDS]
18:52:46,346 WARN [org.jboss.as.dependency.private] (MSC service thread 1-1) WFLYSRV0018: Deployment "deployment.keycloak-server.war" is using a private module ("org.kie") which may be changed or removed in future versions without notice.
18:52:46,604 WARN [org.jgroups.protocols.UDP] (ServerService Thread Pool -- 60) JGRP000015: the send buffer of socket ManagedMulticastSocketBinding was set to 1.00MB, but the OS only allocated 212.99KB. This might lead to performance problems. Please set your max send buffer in the OS correctly (e.g. net.core.wmem_max on Linux)
18:52:46,604 WARN [org.jgroups.protocols.UDP] (ServerService Thread Pool -- 60) JGRP000015: the receive buffer of socket ManagedMulticastSocketBinding was set to 20.00MB, but the OS only allocated 212.99KB. This might lead to performance problems. Please set your max receive buffer in the OS correctly (e.g. net.core.rmem_max on Linux)
18:52:46,604 WARN [org.jgroups.protocols.UDP] (ServerService Thread Pool -- 60) JGRP000015: the receive buffer of socket ManagedMulticastSocketBinding was set to 25.00MB, but the OS only allocated 212.99KB. This might lead to performance problems. Please set your max receive buffer in the OS correctly (e.g. net.core.rmem_max on Linux)
18:52:49,617 INFO [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool -- 60) keycloak-7f66c8fb5f-b98t4: no members discovered after 3003 ms: creating cluster as first member
18:52:49,949 INFO [org.infinispan.factories.GlobalComponentRegistry] (MSC service thread 1-2) ISPN000128: Infinispan version: Infinispan 'Infinity Minus ONE +2' 9.4.14.Final
18:52:50,163 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-1) ISPN000078: Starting JGroups channel ejb
18:52:50,164 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-2) ISPN000078: Starting JGroups channel ejb
18:52:50,174 INFO [org.infinispan.CLUSTER] (MSC service thread 1-2) ISPN000094: Received new cluster view for channel ejb: [keycloak-7f66c8fb5f-b98t4|0] (1) [keycloak-7f66c8fb5f-b98t4]
18:52:50,174 INFO [org.infinispan.CLUSTER] (MSC service thread 1-1) ISPN000094: Received new cluster view for channel ejb: [keycloak-7f66c8fb5f-b98t4|0] (1) [keycloak-7f66c8fb5f-b98t4]
18:52:50,184 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-1) ISPN000079: Channel ejb local address is keycloak-7f66c8fb5f-b98t4, physical addresses are [192.168.6.208:55200]
18:52:50,191 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-2) ISPN000079: Channel ejb local address is keycloak-7f66c8fb5f-b98t4, physical addresses are [192.168.6.208:55200]
18:52:50,259 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-2) ISPN000078: Starting JGroups channel ejb
18:52:50,261 INFO [org.infinispan.CLUSTER] (MSC service thread 1-2) ISPN000094: Received new cluster view for channel ejb: [keycloak-7f66c8fb5f-b98t4|0] (1) [keycloak-7f66c8fb5f-b98t4]
18:52:50,278 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-2) ISPN000079: Channel ejb local address is keycloak-7f66c8fb5f-b98t4, physical addresses are [192.168.6.208:55200]
18:52:50,294 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-1) ISPN000078: Starting JGroups channel ejb
18:52:50,297 INFO [org.infinispan.CLUSTER] (MSC service thread 1-1) ISPN000094: Received new cluster view for channel ejb: [keycloak-7f66c8fb5f-b98t4|0] (1) [keycloak-7f66c8fb5f-b98t4]
18:52:50,315 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-1) ISPN000079: Channel ejb local address is keycloak-7f66c8fb5f-b98t4, physical addresses are [192.168.6.208:55200]
18:52:50,344 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-2) ISPN000078: Starting JGroups channel ejb
18:52:50,345 INFO [org.infinispan.CLUSTER] (MSC service thread 1-2) ISPN000094: Received new cluster view for channel ejb: [keycloak-7f66c8fb5f-b98t4|0] (1) [keycloak-7f66c8fb5f-b98t4]
18:52:50,354 INFO [org.infinispan.remoting.transport.jgroups.JGroupsTransport] (MSC service thread 1-2) ISPN000079: Channel ejb local address is keycloak-7f66c8fb5f-b98t4, physical addresses are [192.168.6.208:55200]
18:52:50,596 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 62) WFLYCLINF0002: Started authorization cache from keycloak container
18:52:50,605 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 60) WFLYCLINF0002: Started keys cache from keycloak container
18:52:50,612 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 65) WFLYCLINF0002: Started users cache from keycloak container
18:52:50,605 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 64) WFLYCLINF0002: Started realms cache from keycloak container
18:52:50,852 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 68) WFLYCLINF0002: Started authenticationSessions cache from keycloak container
18:52:50,853 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 70) WFLYCLINF0002: Started clientSessions cache from keycloak container
18:52:50,854 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 71) WFLYCLINF0002: Started work cache from keycloak container
18:52:50,857 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 66) WFLYCLINF0002: Started sessions cache from keycloak container
18:52:50,859 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 69) WFLYCLINF0002: Started offlineSessions cache from keycloak container
18:52:50,866 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 61) WFLYCLINF0002: Started loginFailures cache from keycloak container
18:52:50,867 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 67) WFLYCLINF0002: Started offlineClientSessions cache from keycloak container
18:52:50,867 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 63) WFLYCLINF0002: Started actionTokens cache from keycloak container
18:52:50,874 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 72) WFLYCLINF0002: Started client-mappings cache from ejb container
18:52:50,961 WARN [org.jboss.as.server.deployment] (MSC service thread 1-1) WFLYSRV0273: Excluded subsystem webservices via jboss-deployment-structure.xml does not exist.
18:52:52,031 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 72) WFLYCLINF0002: Started realmRevisions cache from keycloak container
18:52:52,037 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 72) WFLYCLINF0002: Started userRevisions cache from keycloak container
18:52:52,046 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 72) WFLYCLINF0002: Started authorizationRevisions cache from keycloak container
18:52:52,622 WARN [org.jboss.jca.core.connectionmanager.pool.strategy.OnePool] (ServerService Thread Pool -- 72) IJ000604: Throwable while attempting to get a new connection: null: javax.resource.ResourceException: IJ031084: Unable to create connection
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:345)
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:352)
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:287)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.createConnectionEventListener(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1325)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.getConnection(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:499)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getSimpleConnection(AbstractPool.java:632)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getConnection(AbstractPool.java:604)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:624)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.tx.TxConnectionManagerImpl.getManagedConnection(TxConnectionManagerImpl.java:440)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.allocateConnection(AbstractConnectionManager.java:789)
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:151)
at org.jboss.as.connector@17.0.1.Final//org.jboss.as.connector.subsystems.datasources.WildFlyDataSource.getConnection(WildFlyDataSource.java:64)
at org.keycloak.keycloak-model-jpa@7.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.getConnection(DefaultJpaConnectionProviderFactory.java:366)
at org.keycloak.keycloak-model-jpa@7.0.1//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lazyInit(LiquibaseDBLockProvider.java:65)
at org.keycloak.keycloak-model-jpa@7.0.1//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lambda$waitForLock$2(LiquibaseDBLockProvider.java:96)
at org.keycloak.keycloak-server-spi-private@7.0.1//org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:682)
at org.keycloak.keycloak-model-jpa@7.0.1//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.waitForLock(LiquibaseDBLockProvider.java:94)
at org.keycloak.keycloak-services@7.0.1//org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:144)
at org.keycloak.keycloak-server-spi-private@7.0.1//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:227)
at org.keycloak.keycloak-services@7.0.1//org.keycloak.services.resources.KeycloakApplication.<init>(KeycloakApplication.java:137)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2784)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:364)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:277)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:89)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:119)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:36)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:303)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:143)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:583)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:554)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1502)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:596)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
at org.jboss.threads@2.3.3.Final//org.jboss.threads.JBossThread.run(JBossThread.java:485)
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
The last packet successfully received from the server was 113 milliseconds ago. The last packet sent successfully to the server was 108 milliseconds ago.
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.Util.handleNewInstance(Util.java:425)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:990)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ExportControlled.transformSocketToSSLSocket(ExportControlled.java:201)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.MysqlIO.negotiateSSLConnection(MysqlIO.java:4912)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.MysqlIO.proceedHandshakeWithPluggableAuthentication(MysqlIO.java:1663)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:1224)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2190)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2221)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2016)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:776)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:386)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:330)
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:321)
... 55 more
Caused by: javax.net.ssl.SSLHandshakeException: No appropriate protocol (protocol is disabled or cipher suites are inappropriate)
at java.base/sun.security.ssl.HandshakeContext.<init>(HandshakeContext.java:169)
at java.base/sun.security.ssl.ClientHandshakeContext.<init>(ClientHandshakeContext.java:98)
at java.base/sun.security.ssl.TransportContext.kickstart(TransportContext.java:216)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:395)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ExportControlled.transformSocketToSSLSocket(ExportControlled.java:186)
... 71 more
18:52:52,644 INFO [org.jboss.as.server] (Thread-1) WFLYSRV0220: Server shutdown has been requested via an OS signal
18:52:52,644 ERROR [org.jboss.msc.service.fail] (ServerService Thread Pool -- 72) MSC000001: Failed to start service jboss.deployment.unit."keycloak-server.war".undertow-deployment: org.jboss.msc.service.StartException in service jboss.deployment.unit."keycloak-server.war".undertow-deployment: java.lang.RuntimeException: RESTEASY003325: Failed to construct public org.keycloak.services.resources.KeycloakApplication(javax.servlet.ServletContext,org.jboss.resteasy.core.Dispatcher)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:81)
at
... 71 more
18:52:52,690 INFO [org.jboss.modcluster] (ServerService Thread Pool -- 72) MODCLUSTER000002: Initiating mod_cluster shutdown
Does other configuration needs for Keycloak ?
