Keycloak 8 - Cas Plugin - Gateway and Passive Mode problem
HI Keycloak Community,
a little question to you.
We are using Cas Plugin (https://github.com/Doccrazy/keycloak-protocol-cas) for an application with Guest and Logged user.
The “gateway” parameter is present in the CAS Protocol.
It is used to perform a trust authentication on resources that must be made available for both guest and logged-in users. If the parameter is set to “true”, the user is not asked to log in.
In Doccrazy Plugin this parameter is send to keycloack in a class that extend AutorizationEndpointBase, in method “build
return handleBrowserAuthenticationRequest(authenticationSession, new CASLoginProtocol(session, realm, session.getContext().getUri(), headers, event), gateway, false);
This parameter is read as “passive” parameter of AuthorizationEndpointBase.handleBrowserAuthenticationRequest.
However, when we request a resource from guest users we get the following error:
18:09:16,415 INFO  [stdout] (default task-9) Service https://chatbot.alpiworld.com/qbot/qchat/v2/js/qchat-all.js
18:09:16,420 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-9) Uncaught server error: org.jboss.resteasy.core.NoMessageBodyWriterFoundFailure: Could not find MessageBodyWriter for response object of type: org.keycloak.protocol.LoginProtocol$Error of media type: application/octet-stream
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ServerResponseWriter.lambda$writeNomapResponse$2(ServerResponseWriter.java:118)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.interception.ContainerResponseContextImpl.filter(ContainerResponseContextImpl.java:398)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ServerResponseWriter.executeFilters(ServerResponseWriter.java:219)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ServerResponseWriter.writeNomapResponse(ServerResponseWriter.java:95)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ServerResponseWriter.writeNomapResponse(ServerResponseWriter.java:69)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.writeResponse(SynchronousDispatcher.java:529)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:460)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:356)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:227)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
	at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
	at org.keycloak.keycloak-services@8.0.1//org.keycloak.services.filters.KeycloakSessionServletFilter.doFilter(KeycloakSessionServletFilter.java:91)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
	at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
	at io.undertow.core@2.0.27.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
	at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
	at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
	at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
	at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
	at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
	at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
	at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
	at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1504)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
	at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
	at io.undertow.core@2.0.27.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:376)
	at io.undertow.core@2.0.27.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
Do you have any idea of the reason?
Thanks!!!
Riccardo
