Hello
I followed the walkthrough for setting up a custom authenticator spi for keycloak.I’m trying to use the example code from https://github.com/keycloak/keycloak/tree/master/examples/providers/authenticator . But when I run mvn clean install wildfly:deploy i’m getting this error :
`FATAL] Non-resolvable parent POM for org.keycloak:keycloak-examples-parent:8.0.0-SNAPSHOT: Could not find artifact org.keycloak:keycloak-parent:pom:8.0.0-SNAPSHOT and 'parent.relativePath' points at wrong local POM @ org.keycloak:keycloak-examples-parent:8.0.0-SNAPSHOT, C:\Users\dazoulay\Downloads\keycloak-master\keycloak-master\examples\pom.xml, line 20, column 13`
The old examples were not designed to be used directly from the GitHub clone, but rather from the download on the website. Try downloading the examples from https://www.keycloak.org/downloads.html.
So I just downloaded the examples from the Downloads page and tried the LDAP example. The error is the same as if I’d downloaded the GitHub clone:
david.a.sharpe@CA-L2TTLPQ2 MINGW64 /c/Dev/keycloak-examples-8.0.1/ldap
$ mvn install
[INFO] Scanning for projects...
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-resolvable parent POM for org.keycloak:keycloak-examples-parent:8.0.0-SNAPSHOT: Failure to find org.keycloak:keycloak-parent:pom:8.0.0-SNAPSHOT in https://repository.jboss.org/nexus/content/groups/public/ was cached in the local repository, resolution will not be reattempted until the update interval of jboss-public has elapsed or updates are forced and 'parent.relativePath' points at wrong local POM @ org.keycloak:keycloak-examples-parent:8.0.0-SNAPSHOT, C:\Dev\keycloak-examples-8.0.1\pom.xml, line 20, column 13
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project org.keycloak.example.demo:keycloak-examples-ldap:8.0.0-SNAPSHOT (C:\Dev\keycloak-examples-8.0.1\ldap\pom.xml) has 1 error
[ERROR] Non-resolvable parent POM for org.keycloak:keycloak-examples-parent:8.0.0-SNAPSHOT: Failure to find org.keycloak:keycloak-parent:pom:8.0.0-SNAPSHOT in https://repository.jboss.org/nexus/content/groups/public/ was cached in the local repository, resolution will not be reattempted until the update interval of jboss-public has elapsed or updates are forced and 'parent.relativePath' points at wrong local POM @ org.keycloak:keycloak-examples-parent:8.0.0-SNAPSHOT, C:\Dev\keycloak-examples-8.0.1\pom.xml, line 20, column 13 -> [Help 2]
Notably the Downloads page does say that the Examples are DEPRECATED, so I guess that’s that. Now the “Downloads” page has “Quickstarts distribution” under the “Examples” heading, but there is no LDAP example.
I think there is some issue with the Keycloak examples and the version
in the pom.xml.
Maybe the easiest to fix is to checkout whole repository
“http://github.com/keycloak/keycloak” and then just build the hole
Keycloak server to your local maven repo.
cd keycloak
mvn clean install -DskipTests=true
cd examples/ldap/target/ (Directory target should be there if example
was successfully built)
Oddly enough, examples/ldap/target/
is not there after successfully building the whole Keycloak server. I looked in the top level pom and found an “examples” profile, so I tried mvn install -DskipTests=true -Pexamples
but that didn’t create the examples/ldap/target/
directory either. I can see that building was successful though: adapters/oidc/tomcat/tomcat/target
exists, for example.
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary for Keycloak 9.0.0-SNAPSHOT:
[INFO]
[INFO] Keycloak BOM Parent ................................ SUCCESS [ 1.901 s]
[INFO] Keycloak BOM for adapters .......................... SUCCESS [ 0.050 s]
[INFO] Keycloak BOM for server extensions ................. SUCCESS [ 0.034 s]
[INFO] Keycloak BOM utilities for the quickstarts ......... SUCCESS [ 0.050 s]
[INFO] Keycloak ........................................... SUCCESS [ 0.083 s]
[INFO] Keycloak Common .................................... SUCCESS [ 3.283 s]
[INFO] Keycloak Core ...................................... SUCCESS [ 3.434 s]
[INFO] Keycloak Server SPI ................................ SUCCESS [ 1.999 s]
[INFO] Keycloak Server Private SPI ........................ SUCCESS [ 10.584 s]
[INFO] Keycloak Kerberos Federation ....................... SUCCESS [ 0.300 s]
[INFO] Keycloak LDAP UserStoreProvider .................... SUCCESS [ 0.950 s]
[INFO] Keycloak SAML Core Public API ...................... SUCCESS [ 5.950 s]
[INFO] Keycloak SAML Core ................................. SUCCESS [ 3.167 s]
[INFO] Keycloak REST Services ............................. SUCCESS [ 7.200 s]
[INFO] Keycloak JS Integration ............................ SUCCESS [ 3.634 s]
[INFO] Keycloak Themes .................................... SUCCESS [ 4.916 s]
[INFO] Keycloak Dependencies Parent ....................... SUCCESS [ 0.033 s]
[INFO] Keycloak Dependencies Server Min ................... SUCCESS [ 0.084 s]
[INFO] Keycloak Model Parent .............................. SUCCESS [ 0.066 s]
[INFO] Keycloak Model JPA ................................. SUCCESS [ 1.734 s]
[INFO] Keycloak Model Infinispan .......................... SUCCESS [ 3.416 s]
[INFO] Keycloak SSSD Federation ........................... SUCCESS [ 2.301 s]
[INFO] KeyCloak Authz: Parent ............................. SUCCESS [ 0.083 s]
[INFO] KeyCloak AuthZ: Provider Parent .................... SUCCESS [ 0.083 s]
[INFO] KeyCloak AuthZ: Common Policy Providers ............ SUCCESS [ 0.584 s]
[INFO] Keycloak Dependencies Server All ................... SUCCESS [ 0.083 s]
[INFO] Keycloak Federation ................................ SUCCESS [ 0.067 s]
[INFO] Keycloak Util Embedded LDAP ........................ SUCCESS [ 1.000 s]
[INFO] Keycloak Util Parent ............................... SUCCESS [ 0.066 s]
[INFO] Keycloak WildFly Integration ....................... SUCCESS [ 0.050 s]
[INFO] Keycloak WildFly Add User Script ................... SUCCESS [ 1.100 s]
[INFO] Keycloak WildFly Extensions ........................ SUCCESS [ 0.551 s]
[INFO] Keycloak WildFly Server Subsystem .................. SUCCESS [ 1.999 s]
[INFO] Keycloak Integration ............................... SUCCESS [ 0.067 s]
[INFO] Keycloak Admin REST Client ......................... SUCCESS [ 0.783 s]
[INFO] Keycloak Client Registration API ................... SUCCESS [ 0.267 s]
[INFO] Keycloak Client CLI ................................ SUCCESS [ 0.066 s]
[INFO] Keycloak Client Registration CLI ................... SUCCESS [ 3.067 s]
[INFO] Keycloak Admin CLI ................................. SUCCESS [ 2.300 s]
[INFO] Keycloak Client CLI Distribution ................... SUCCESS [ 1.250 s]
[INFO] Keycloak Adapter SPI ............................... SUCCESS [ 0.517 s]
[INFO] Keycloak Tomcat Adapter SPI ........................ SUCCESS [ 0.233 s]
[INFO] Keycloak Undertow Integration SPI .................. SUCCESS [ 0.617 s]
[INFO] Keycloak Servlet Integration ....................... SUCCESS [ 0.417 s]
[INFO] Common JBoss/Wildfly Core Classes .................. SUCCESS [ 0.250 s]
[INFO] Keycloak Jetty Adapter SPI ......................... SUCCESS [ 0.499 s]
[INFO] Keycloak Client Adapter SPI Modules ................ SUCCESS [ 0.034 s]
[INFO] Keycloak SAML Client Adapter Public API ............ SUCCESS [ 0.267 s]
[INFO] Keycloak SAML Client Adapter Core .................. SUCCESS [ 0.883 s]
[INFO] Keycloak Undertow SAML Adapter ..................... SUCCESS [ 0.417 s]
[INFO] Keycloak SAML Tomcat Integration ................... SUCCESS [ 0.049 s]
[INFO] Keycloak Tomcat Core SAML Integration .............. SUCCESS [ 0.284 s]
[INFO] Keycloak Tomcat SAML Integration ................... SUCCESS [ 0.367 s]
[INFO] Keycloak Tomcat 7 SAML Integration ................. SUCCESS [ 0.300 s]
[INFO] Keycloak Wildfly SAML Adapter ...................... SUCCESS [ 0.383 s]
[INFO] KeyCloak Authz: Client API ......................... SUCCESS [ 0.867 s]
[INFO] Keycloak Adapter Core .............................. SUCCESS [ 1.700 s]
[INFO] Keycloak WildFly Elytron SAML Adapter .............. SUCCESS [ 0.633 s]
[INFO] Keycloak Wildfly SAML Adapter Subsystem ............ SUCCESS [ 1.000 s]
[INFO] Keycloak SAML Wildfly Integration .................. SUCCESS [ 0.067 s]
[INFO] Keycloak SAML Servlet Filter ....................... SUCCESS [ 0.466 s]
[INFO] Keycloak Jetty Core SAML Integration ............... SUCCESS [ 0.867 s]
[INFO] Keycloak Jetty 9.2.x SAML Integration .............. SUCCESS [ 0.817 s]
[INFO] Keycloak Jetty 9.3.x SAML Integration .............. SUCCESS [ 0.883 s]
[INFO] Keycloak Jetty 9.4.x SAML Integration .............. SUCCESS [ 0.766 s]
[INFO] Keycloak SAML Jetty Integration .................... SUCCESS [ 0.051 s]
[INFO] Keycloak SAML Client Adapter Modules ............... SUCCESS [ 0.067 s]
[INFO] Keycloak Installed Application ..................... SUCCESS [ 0.300 s]
[INFO] Keycloak Undertow Integration ...................... SUCCESS [ 0.800 s]
[INFO] Keycloak Fuse 7.0 Integration ...................... SUCCESS [ 0.066 s]
[INFO] Keycloak Fuse 7.0 Adapter - Camel + Undertow ....... SUCCESS [ 0.983 s]
[INFO] Keycloak OSGI Adapter .............................. SUCCESS [ 0.933 s]
[INFO] Keycloak Fuse 7.0 Adapter - Undertow ............... SUCCESS [ 0.950 s]
[INFO] Keycloak Jetty Core Integration .................... SUCCESS [ 0.550 s]
[INFO] Keycloak Jetty 9.4.x Integration ................... SUCCESS [ 0.450 s]
[INFO] Keycloak Fuse 7.0 Adapter - Jetty 9.4 .............. SUCCESS [ 0.700 s]
[INFO] Keycloak Tomcat Integration ........................ SUCCESS [ 0.050 s]
[INFO] Keycloak Tomcat Core Integration ................... SUCCESS [ 0.367 s]
[INFO] Keycloak Tomcat Integration ........................ SUCCESS [ 0.383 s]
[INFO] Keycloak Fuse 7.0 Adapter - Tomcat 8 ............... SUCCESS [ 0.633 s]
[INFO] Keycloak CLI SSO Framework ......................... SUCCESS [ 3.067 s]
[INFO] Keycloak JAX-RS OAuth Client ....................... SUCCESS [ 0.334 s]
[INFO] Keycloak Jetty 9.2.x Integration ................... SUCCESS [ 0.466 s]
[INFO] Keycloak Jetty 9.3.x Integration ................... SUCCESS [ 0.517 s]
[INFO] Keycloak Jetty Integration ......................... SUCCESS [ 0.083 s]
[INFO] Keycloak Servlet Filter Adapter Integration ........ SUCCESS [ 0.467 s]
[INFO] spring-boot-container-bundle ....................... SUCCESS [ 1.283 s]
[INFO] spring-boot-legacy-container-bundle ................ SUCCESS [ 1.033 s]
[INFO] Keycloak Spring Security Integration ............... SUCCESS [ 2.001 s]
[INFO] Keycloak Spring Boot Adapter Core .................. SUCCESS [ 0.599 s]
[INFO] Keycloak Spring Boot Integration ................... SUCCESS [ 0.350 s]
[INFO] Keycloak Spring Boot 2 Integration ................. SUCCESS [ 0.684 s]
[INFO] Keycloak Tomcat 7 Integration ...................... SUCCESS [ 0.283 s]
[INFO] Keycloak Wildfly Integration ....................... SUCCESS [ 0.317 s]
[INFO] Keycloak Wildfly Elytron OIDC Adapter .............. SUCCESS [ 0.700 s]
[INFO] Keycloak Wildfly Adapter Subsystem ................. SUCCESS [ 0.900 s]
[INFO] Keycloak WildFly Integration ....................... SUCCESS [ 0.067 s]
[INFO] Keycloak OIDC Client Adapter Modules ............... SUCCESS [ 0.050 s]
[INFO] Keycloak Adapters .................................. SUCCESS [ 0.050 s]
[INFO] Keycloak Misc ...................................... SUCCESS [ 0.067 s]
[INFO] Keycloak :: Spring :: Boot ......................... SUCCESS [ 0.065 s]
[INFO] Keycloak :: Spring :: Boot :: Default :: Starter .. SUCCESS [ 0.267 s]
[INFO] Keycloak :: Spring :: Boot ......................... SUCCESS [ 0.084 s]
[INFO] Keycloak :: Legacy :: Spring :: Boot :: Default :: Starter SUCCESS [ 0.300 s]
[INFO] keycloak-test-helper ............................... SUCCESS [ 0.550 s]
[INFO] Keycloak TestSuite ................................. SUCCESS [ 0.082 s]
[INFO] DB Allocator Plugin ................................ SUCCESS [ 2.318 s]
[INFO] Keycloak Arquillian Integration TestSuite .......... SUCCESS [ 0.166 s]
[INFO] Test apps .......................................... SUCCESS [ 0.051 s]
[INFO] Test apps distribution ............................. SUCCESS [ 3.850 s]
[INFO] Keycloak Authz: PhotoZ Test Parent ................ SUCCESS [ 0.100 s]
[INFO] Keycloak Authz Test: Photoz RESTful API ............ SUCCESS [ 1.666 s]
[INFO] Keycloak Authz Tests: Photoz HTML5 Client .......... SUCCESS [ 0.901 s]
[INFO] Keycloak Authz Tests: Hello World Example .......... SUCCESS [ 0.349 s]
[INFO] Keycloak Authz: Servlet Authorization Test ......... SUCCESS [ 0.767 s]
[INFO] Keycloak Authz: Simple Servlet App with Policy Enforcer SUCCESS [ 0.350 s]
[INFO] integration-arquillian-test-apps-servlets .......... SUCCESS [ 0.567 s]
[INFO] Keycloak Test App Profile JEE ...................... SUCCESS [ 0.467 s]
[INFO] integration-arquillian-test-apps-cors-parent ....... SUCCESS [ 0.099 s]
[INFO] Angular Product Portal JS .......................... SUCCESS [ 1.201 s]
[INFO] JAX-RS Database Service Using OAuth Bearer Tokens .. SUCCESS [ 0.600 s]
[INFO] Fuse Test Applications ............................. SUCCESS [ 0.083 s]
[INFO] Customer Portal - Secured in Karaf/Fuse ............ SUCCESS [ 1.133 s]
[INFO] CXF JAXRS Example - Secured in Karaf/Fuse .......... SUCCESS [ 1.167 s]
[INFO] CXF JAXRS Example - Secured in Karaf/Fuse 7 on Undertow SUCCESS [ 0.966 s]
[INFO] CXF JAXWS Example - Secured in Karaf/Fuse .......... SUCCESS [ 1.934 s]
[INFO] CXF JAXWS Example - Secured in Karaf/Fuse 7 on Undertow SUCCESS [ 1.600 s]
[INFO] Product Portal - Secured in Karaf/Fuse ............. SUCCESS [ 0.800 s]
[INFO] Product Portal - Secured in Karaf/Fuse 7 on Undertow SUCCESS [ 0.817 s]
[INFO] Camel endpoint example - Secured in Karaf/Fuse ..... SUCCESS [ 0.583 s]
[INFO] Camel endpoint example - Secured in Karaf/Fuse 7.0 on Undertow SUCCESS [ 0.533 s]
[INFO] Keycloak Fuse Example - Features ................... SUCCESS [ 0.400 s]
[INFO] Keycloak Examples - External Config ................ SUCCESS [ 0.717 s]
[INFO] spring-boot-adapter-app ............................ SUCCESS [ 0.933 s]
[INFO] Servers ............................................ SUCCESS [ 0.084 s]
[INFO] Auth Server ........................................ SUCCESS [ 0.066 s]
[INFO] Auth Server Services ............................... SUCCESS [ 0.084 s]
[INFO] Auth Server Services - Testsuite Providers ......... SUCCESS [ 2.500 s]
[INFO] Auth Server - JBoss ................................ SUCCESS [ 0.083 s]
[INFO] Keycloak TestSuite Utils ........................... SUCCESS [ 1.683 s]
[INFO] Test Util .......................................... SUCCESS [ 1.234 s]
[INFO] Auth Server - Undertow ............................. SUCCESS [ 1.533 s]
[INFO] App Server ......................................... SUCCESS [ 0.050 s]
[INFO] App Server - SPI ................................... SUCCESS [ 0.234 s]
[INFO] App Server - JBoss ................................. SUCCESS [ 0.049 s]
[INFO] App Server - Karaf ................................. SUCCESS [ 0.067 s]
[INFO] App Server - Tomcat ................................ SUCCESS [ 0.050 s]
[INFO] App Server - Undertow .............................. SUCCESS [ 0.567 s]
[INFO] App Server - Jetty Parent .......................... SUCCESS [ 0.116 s]
[INFO] Cache Server ....................................... SUCCESS [ 0.067 s]
[INFO] Cache Server - JBoss Family ........................ SUCCESS [ 0.083 s]
[INFO] Tests .............................................. SUCCESS [ 0.300 s]
[INFO] Base TestSuite ..................................... SUCCESS [ 26.984 s]
[INFO] Other Tests Modules ................................ SUCCESS [ 0.067 s]
[INFO] Adapter Tests ...................................... SUCCESS [ 0.083 s]
[INFO] Adapter Tests - JBoss .............................. SUCCESS [ 0.083 s]
[INFO] Adapter Tests - Karaf .............................. SUCCESS [ 0.084 s]
[INFO] Adapter Tests - WAS ................................ SUCCESS [ 0.083 s]
[INFO] Adapter Tests - WLS ................................ SUCCESS [ 0.100 s]
[INFO] SSSD tests ......................................... SUCCESS [ 2.850 s]
[INFO] BUILD SUCCESS
[INFO] Total time: 02:53 min
[INFO] Finished at: 2020-01-16T15:43:34-08:00
