emre
June 10, 2021, 1:50pm
1
We have 3 keycloak instances and 3 infinispan instances. Keycloaks are using the same postgresql database. And all keycloaks uses infinispans as external cache.
All infinispans are clustered and datas replicated.
All keycloaks can see all sessions.
When we get token from keycloak-node-1 we can not validate it on keycloak-node-2 or node-3.
But when we put a load balancer in front of keycloak nodes, we can get and validate token from localhost.
Also, when we deploy our application to kubernetes, it can take token from keycloak but it can not validate that token using either load balancer or nodes directly.
We stuck in this situation.
What we want to do is, taking token from any node, and validate that token in any node.
How can we achieve this?
xgp
June 10, 2021, 4:29pm
2
Can you share your configurations? It sounds like the keycloaks may not be communicating with the infinispan cluster correctly.
emre
June 11, 2021, 7:54am
3
Hi, here is our config in the time I wrote this issue:
part-1:
<?xml version='1.0' encoding='UTF-8'?>
<server xmlns="urn:jboss:domain:16.0">
<extensions>
<extension module="org.jboss.as.clustering.infinispan"/>
<extension module="org.jboss.as.clustering.jgroups"/>
<extension module="org.jboss.as.connector"/>
<extension module="org.jboss.as.deployment-scanner"/>
<extension module="org.jboss.as.ee"/>
<extension module="org.jboss.as.ejb3"/>
<extension module="org.jboss.as.jaxrs"/>
<extension module="org.jboss.as.jmx"/>
<extension module="org.jboss.as.jpa"/>
<extension module="org.jboss.as.logging"/>
<extension module="org.jboss.as.mail"/>
<extension module="org.jboss.as.modcluster"/>
<extension module="org.jboss.as.naming"/>
<extension module="org.jboss.as.remoting"/>
<extension module="org.jboss.as.security"/>
<extension module="org.jboss.as.transactions"/>
<extension module="org.jboss.as.weld"/>
<extension module="org.keycloak.keycloak-server-subsystem"/>
<extension module="org.wildfly.extension.bean-validation"/>
<extension module="org.wildfly.extension.core-management"/>
<extension module="org.wildfly.extension.elytron"/>
<extension module="org.wildfly.extension.health"/>
<extension module="org.wildfly.extension.io"/>
<extension module="org.wildfly.extension.metrics"/>
<extension module="org.wildfly.extension.request-controller"/>
<extension module="org.wildfly.extension.security.manager"/>
<extension module="org.wildfly.extension.undertow"/>
</extensions>
<management>
<security-realms>
<security-realm name="ManagementRealm">
<authentication>
<local default-user="$local" skip-group-loading="true"/>
<properties path="mgmt-users.properties" relative-to="jboss.server.config.dir"/>
</authentication>
<authorization map-groups-to-roles="false">
<properties path="mgmt-groups.properties" relative-to="jboss.server.config.dir"/>
</authorization>
</security-realm>
<security-realm name="ApplicationRealm">
<server-identities>
<ssl>
<keystore path="application.keystore" relative-to="jboss.server.config.dir" keystore-password="password" alias="server" key-password="password" generate-self-signed-certificate-host="localhost"/>
</ssl>
</server-identities>
<authentication>
<local default-user="$local" allowed-users="*" skip-group-loading="true"/>
<properties path="application-users.properties" relative-to="jboss.server.config.dir"/>
</authentication>
<authorization>
<properties path="application-roles.properties" relative-to="jboss.server.config.dir"/>
</authorization>
</security-realm>
</security-realms>
<audit-log>
<formatters>
<json-formatter name="json-formatter"/>
</formatters>
<handlers>
<file-handler name="file" formatter="json-formatter" path="audit-log.log" relative-to="jboss.server.data.dir"/>
</handlers>
<logger log-boot="true" log-read-only="false" enabled="false">
<handlers>
<handler name="file"/>
</handlers>
</logger>
</audit-log>
<management-interfaces>
<http-interface security-realm="ManagementRealm">
<http-upgrade enabled="true"/>
<socket-binding http="management-http"/>
</http-interface>
</management-interfaces>
<access-control provider="simple">
<role-mapping>
<role name="SuperUser">
<include>
<user name="$local"/>
</include>
</role>
</role-mapping>
</access-control>
</management>
<profile>
<subsystem xmlns="urn:jboss:domain:bean-validation:1.0"/>
<subsystem xmlns="urn:jboss:domain:core-management:1.0"/>
<subsystem xmlns="urn:jboss:domain:deployment-scanner:2.0">
<deployment-scanner path="deployments" relative-to="jboss.server.base.dir" scan-interval="5000" runtime-failure-causes-rollback="${jboss.deployment.scanner.rollback.on.failure:false}"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:ee:6.0">
<spec-descriptor-property-replacement>false</spec-descriptor-property-replacement>
<concurrent>
<context-services>
<context-service name="default" jndi-name="java:jboss/ee/concurrency/context/default" use-transaction-setup-provider="true"/>
</context-services>
<managed-thread-factories>
<managed-thread-factory name="default" jndi-name="java:jboss/ee/concurrency/factory/default" context-service="default"/>
</managed-thread-factories>
<managed-executor-services>
<managed-executor-service name="default" jndi-name="java:jboss/ee/concurrency/executor/default" context-service="default" hung-task-termination-period="0" hung-task-threshold="60000" keepalive-time="5000"/>
</managed-executor-services>
<managed-scheduled-executor-services>
<managed-scheduled-executor-service name="default" jndi-name="java:jboss/ee/concurrency/scheduler/default" context-service="default" hung-task-termination-period="0" hung-task-threshold="60000" keepalive-time="3000"/>
</managed-scheduled-executor-services>
</concurrent>
<default-bindings context-service="java:jboss/ee/concurrency/context/default" datasource="java:jboss/datasources/KeycloakDS" managed-executor-service="java:jboss/ee/concurrency/executor/default" managed-scheduled-executor-service="java:jboss/ee/concurrency/scheduler/default" managed-thread-factory="java:jboss/ee/concurrency/factory/default"/>
</subsystem>
<subsystem xmlns="urn:wildfly:health:1.0" security-enabled="false"/>
<subsystem xmlns="urn:jboss:domain:io:3.0">
<worker name="default"/>
<buffer-pool name="default"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jaxrs:2.0"/>
<subsystem xmlns="urn:jboss:domain:jca:5.0">
<archive-validation enabled="true" fail-on-error="true" fail-on-warn="false"/>
<bean-validation enabled="true"/>
<default-workmanager>
<short-running-threads>
<core-threads count="50"/>
<queue-length count="50"/>
<max-threads count="50"/>
<keepalive-time time="10" unit="seconds"/>
</short-running-threads>
<long-running-threads>
</long-running-threads>
</default-workmanager>
<cached-connection-manager/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jmx:1.3">
<expose-resolved-model/>
<expose-expression-model/>
<remoting-connector/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jpa:1.1">
<jpa default-extended-persistence-inheritance="DEEP"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:keycloak-server:1.1">
<web-context>auth</web-context>
<providers>
<provider>classpath:${jboss.home.dir}/providers/*</provider>
</providers>
<master-realm-name>master</master-realm-name>
<scheduled-task-interval>900</scheduled-task-interval>
<theme>
<staticMaxAge>2592000</staticMaxAge>
<cacheThemes>true</cacheThemes>
<cacheTemplates>true</cacheTemplates>
<dir>${jboss.home.dir}/themes</dir>
</theme>
<spi name="eventsStore">
<provider name="jpa" enabled="true">
<properties>
<property name="exclude-events" value="["REFRESH_TOKEN"]"/>
</properties>
</provider>
</spi>
<spi name="userCache">
<provider name="default" enabled="true"/>
</spi>
<spi name="userSessionPersister">
<default-provider>jpa</default-provider>
</spi>
<spi name="timer">
<default-provider>basic</default-provider>
</spi>
<spi name="connectionsHttpClient">
</spi>
<spi name="connectionsJpa">
<provider name="default" enabled="true">
<properties>
<property name="dataSource" value="java:jboss/datasources/KeycloakDS"/>
<property name="initializeEmpty" value="true"/>
<property name="migrationStrategy" value="update"/>
<property name="migrationExport" value="${jboss.home.dir}/keycloak-database-update.sql"/>
</properties>
</provider>
</spi>
<spi name="realmCache">
</spi>
<spi name="connectionsInfinispan">
<default-provider>default</default-provider>
<properties>
<property name="cacheContainer" value="java:jboss/infinispan/container/keycloak"/>
</properties>
</provider>
</spi>
<spi name="jta-lookup">
<default-provider>${keycloak.jta.lookup.provider:jboss}</default-provider>
<provider name="jboss" enabled="true"/>
</spi>
<spi name="publicKeyStorage">
<provider name="infinispan" enabled="true">
<properties>
<property name="minTimeBetweenRequests" value="10"/>
</properties>
</provider>
</spi>
<spi name="x509cert-lookup">
<default-provider>${keycloak.x509cert.lookup.provider:default}</default-provider>
</spi>
<spi name="hostname">
<properties>
<property name="frontendUrl" value="${keycloak.frontendUrl:}"/>
<property name="forceBackendUrlToFrontendUrl" value="false"/>
</properties>
</provider>
</spi>
</subsystem>
<subsystem xmlns="urn:jboss:domain:logging:8.0">
<console-handler name="CONSOLE">
<level name="INFO"/>
<formatter>
<named-formatter name="COLOR-PATTERN"/>
</formatter>
</console-handler>
<periodic-rotating-file-handler name="FILE" autoflush="true">
<formatter>
<named-formatter name="PATTERN"/>
</formatter>
<file relative-to="jboss.server.log.dir" path="server.log"/>
<suffix value=".yyyy-MM-dd"/>
<append value="true"/>
</periodic-rotating-file-handler>
<logger category="com.arjuna">
<level name="WARN"/>
</logger>
<logger category="io.jaegertracing.Configuration">
</logger>
<logger category="org.jboss.as.config">
<level name="DEBUG"/>
</logger>
<logger category="sun.rmi">
</logger>
<root-logger>
<handlers>
<handler name="CONSOLE"/>
<handler name="FILE"/>
</handlers>
</root-logger>
<formatter name="PATTERN">
<pattern-formatter pattern="%d{yyyy-MM-dd HH:mm:ss,SSS} %-5p [%c] (%t) %s%e%n"/>
</formatter>
<formatter name="COLOR-PATTERN">
<pattern-formatter pattern="%K{level}%d{HH:mm:ss,SSS} %-5p [%c] (%t) %s%e%n"/>
</formatter>
</subsystem>
<subsystem xmlns="urn:jboss:domain:mail:4.0">
<mail-session name="default" jndi-name="java:jboss/mail/Default">
<smtp-server outbound-socket-binding-ref="mail-smtp"/>
</mail-session>
</subsystem>
<subsystem xmlns="urn:wildfly:metrics:1.0" security-enabled="false" exposed-subsystems="*" prefix="${wildfly.metrics.prefix:wildfly}"/>
<subsystem xmlns="urn:jboss:domain:naming:2.0">
<remote-naming/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:remoting:4.0">
<http-connector name="http-remoting-connector" connector-ref="default" security-realm="ApplicationRealm"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:request-controller:1.0"/>
<subsystem xmlns="urn:jboss:domain:security-manager:1.0">
<deployment-permissions>
<maximum-set>
<permission class="java.security.AllPermission"/>
</maximum-set>
</deployment-permissions>
</subsystem>
<subsystem xmlns="urn:jboss:domain:security:2.0">
<security-domains>
<security-domain name="other" cache-type="default">
<authentication>
<login-module code="Remoting" flag="optional">
<module-option name="password-stacking" value="useFirstPass"/>
</login-module>
<login-module code="RealmDirect" flag="required">
</login-module>
</authentication>
</security-domain>
<security-domain name="jboss-web-policy" cache-type="default">
<authorization>
<policy-module code="Delegating" flag="required"/>
</authorization>
</security-domain>
<security-domain name="jaspitest" cache-type="default">
<authentication-jaspi>
<login-module-stack name="dummy">
<login-module code="Dummy" flag="optional"/>
</login-module-stack>
<auth-module code="Dummy"/>
</authentication-jaspi>
</security-domain>
<security-domain name="jboss-ejb-policy" cache-type="default">
<authorization>
</authorization>
</security-domain>
</security-domains>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jgroups:8.0">
<channels default="ee">
<channel name="ee" stack="udp" cluster="ejb"/>
</channels>
<stacks>
<stack name="udp">
<transport type="UDP" socket-binding="jgroups-udp"/>
<protocol type="PING"/>
<protocol type="MERGE3"/>
<socket-protocol type="FD_SOCK" socket-binding="jgroups-udp-fd"/>
<protocol type="FD_ALL"/>
<protocol type="VERIFY_SUSPECT"/>
<protocol type="pbcast.NAKACK2"/>
<protocol type="UNICAST3"/>
<protocol type="pbcast.STABLE"/>
<protocol type="pbcast.GMS"/>
<protocol type="UFC"/>
<protocol type="MFC"/>
<protocol type="FRAG3"/>
</stack>
<stack name="tcp">
<transport type="TCP" socket-binding="jgroups-tcp"/>
<socket-protocol type="MPING" socket-binding="jgroups-mping"/>
<socket-protocol type="FD_SOCK" socket-binding="jgroups-tcp-fd"/>
</stack>
</stacks>
</subsystem>
<subsystem xmlns="urn:jboss:domain:datasources:6.0">
<datasources>
<!-- <datasource jndi-name="java:jboss/datasources/ExampleDS" pool-name="ExampleDS" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
<connection-url>jdbc:h2:mem:test;DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE</connection-url>
<driver>h2</driver>
<security>
<user-name>sa</user-name>
<password>sa</password>
</security>
</datasource>
<datasource jndi-name="java:jboss/datasources/KeycloakDS" pool-name="KeycloakDS" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
<connection-url>jdbc:h2:${jboss.server.data.dir}/keycloak;AUTO_SERVER=TRUE</connection-url>
<driver>h2</driver>
<security>
</security>
</datasource>
<drivers>
<driver name="h2" module="com.h2database.h2">
<xa-datasource-class>org.h2.jdbcx.JdbcDataSource</xa-datasource-class>
</driver>
</drivers> -->
<connection-url>jdbc:postgresql://10.250.60.3:5432/keycloak</connection-url>
<driver>postgresql</driver>
<security>
<user-name>keycloak</user-name>
<password>a2V5Y2xvYWtwb3N0Z3Jlc3FsCg</password>
</security>
</datasource>
<drivers>
<driver name="postgresql" module="org.postgresql">
<xa-datasource-class>org.postgresql.xa.PGXADataSource</xa-datasource-class>
</driver>
</drivers>
</datasources>
</subsystem>
<subsystem xmlns="urn:jboss:domain:modcluster:5.0">
<proxy name="default" advertise-socket="modcluster" listener="ajp">
<dynamic-load-provider>
<load-metric type="cpu"/>
</dynamic-load-provider>
</proxy>
</subsystem>
<subsystem xmlns="urn:jboss:domain:ejb3:9.0">
<session-bean>
<stateless>
<bean-instance-pool-ref pool-name="slsb-strict-max-pool"/>
</stateless>
<stateful default-access-timeout="5000" cache-ref="distributable" passivation-disabled-cache-ref="simple"/>
<singleton default-access-timeout="5000"/>
</session-bean>
<pools>
<bean-instance-pools>
<strict-max-pool name="mdb-strict-max-pool" derive-size="from-cpu-count" instance-acquisition-timeout="5" instance-acquisition-timeout-unit="MINUTES"/>
<strict-max-pool name="slsb-strict-max-pool" derive-size="from-worker-pools" instance-acquisition-timeout="5" instance-acquisition-timeout-unit="MINUTES"/>
</bean-instance-pools>
</pools>
<caches>
<cache name="simple"/>
<cache name="distributable" passivation-store-ref="infinispan" aliases="passivating clustered"/>
</caches>
emre
4
part-2:
<passivation-stores>
<passivation-store name="infinispan" cache-container="ejb" max-size="10000"/>
</passivation-stores>
<async thread-pool-name="default"/>
<timer-service thread-pool-name="default" default-data-store="default-file-store">
<data-stores>
<file-data-store name="default-file-store" path="timer-service-data" relative-to="jboss.server.data.dir"/>
</data-stores>
</timer-service>
<remote cluster="ejb" connectors="http-remoting-connector" thread-pool-name="default">
<channel-creation-options>
<option name="MAX_OUTBOUND_MESSAGES" value="1234" type="remoting"/>
</channel-creation-options>
</remote>
<thread-pools>
<thread-pool name="default">
<max-threads count="10"/>
<keepalive-time time="60" unit="seconds"/>
</thread-pool>
</thread-pools>
<default-security-domain value="other"/>
<default-missing-method-permissions-deny-access value="true"/>
<statistics enabled="${wildfly.ejb3.statistics-enabled:${wildfly.statistics-enabled:false}}"/>
<log-system-exceptions value="true"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:infinispan:12.0">
<cache-container name="keycloak" modules="org.keycloak.keycloak-model-infinispan">
<transport lock-timeout="60000"/>
<local-cache name="realms">
<heap-memory size="10000"/>
</local-cache>
<local-cache name="users">
</local-cache>
</local-cache>
<local-cache name="keys">
<heap-memory size="1000"/>
</local-cache>
<replicated-cache name="work"/>
<remote-store cache="sessions" remote-servers="remote-cache" fetch-state="false" passivation="false" preload="false" purge="false" shared="true">
<property name="rawValues">true</property>
<property name="marshaller">org.keycloak.cluster.infinispan.KeycloakHotRodMarshallerFactory</property>
<property name="protocolVersion">2.9</property>
<property name="infinispan.client.hotrod.auth_username">infinispanuser</property>
<property name="infinispan.client.hotrod.auth_password">aW5maW5pc3BhbnVzZXIK</property>
</remote-store>
</distributed-cache>
<distributed-cache name="authenticationSessions" owners="2"/>
<remote-store cache="offlineSessions" remote-servers="remote-cache" fetch-state="false" passivation="false" preload="false" purge="false" shared="true">
</remote-store>
<remote-store cache="clientSessions" remote-servers="remote-cache" fetch-state="false" passivation="false" preload="false" purge="false" shared="true">
</remote-store>
<remote-store cache="offlineClientSessions" remote-servers="remote-cache" fetch-state="false" passivation="false" preload="false" purge="false" shared="true">
</remote-store>
<remote-store cache="loginFailures" remote-servers="remote-cache" fetch-state="false" passivation="false" preload="false" purge="false" shared="true">
</remote-store>
<expiration interval="300000" max-idle="-1"/>
<remote-store cache="actionTokens" remote-servers="remote-cache" fetch-state="false" passivation="false" preload="true" purge="false" shared="true">
</remote-store>
</cache-container>
<cache-container name="server" aliases="singleton cluster" default-cache="default" modules="org.wildfly.clustering.server">
<replicated-cache name="default">
<transaction mode="BATCH"/>
</replicated-cache>
</cache-container>
<cache-container name="web" default-cache="dist" modules="org.wildfly.clustering.web.infinispan">
<replicated-cache name="sso">
<locking isolation="REPEATABLE_READ"/>
</replicated-cache>
<distributed-cache name="dist">
<file-store/>
<distributed-cache name="routing"/>
</cache-container>
<cache-container name="ejb" aliases="sfsb" default-cache="dist" modules="org.wildfly.clustering.ejb.infinispan">
<file-store/>
</cache-container>
<cache-container name="hibernate" modules="org.infinispan.hibernate-cache">
<local-cache name="local-query">
<expiration max-idle="100000"/>
</local-cache>
<invalidation-cache name="entity">
<transaction mode="NON_XA"/>
</invalidation-cache>
<replicated-cache name="timestamps"/>
</cache-container>
</subsystem>
<subsystem xmlns="urn:jboss:domain:undertow:12.0" default-server="default-server" default-virtual-host="default-host" default-servlet-container="default" default-security-domain="other" statistics-enabled="${wildfly.undertow.statistics-enabled:${wildfly.statistics-enabled:false}}">
<buffer-cache name="default"/>
<server name="default-server">
<ajp-listener name="ajp" socket-binding="ajp"/>
<http-listener name="default" socket-binding="http" redirect-socket="https" enable-http2="true" proxy-address-forwarding="true" />
<https-listener name="https" socket-binding="https" security-realm="ApplicationRealm" enable-http2="true"/>
<host name="default-host" alias="localhost">
<location name="/" handler="welcome-content"/>
<http-invoker security-realm="ApplicationRealm"/>
</host>
</server>
<servlet-container name="default">
<jsp-config/>
<websockets/>
</servlet-container>
<handlers>
<file name="welcome-content" path="${jboss.home.dir}/welcome-content"/>
</handlers>
</subsystem>
<subsystem xmlns="urn:wildfly:elytron:13.0" final-providers="combined-providers" disallowed-providers="OracleUcrypto">
<providers>
<aggregate-providers name="combined-providers">
<providers name="elytron"/>
<providers name="openssl"/>
</aggregate-providers>
<provider-loader name="elytron" module="org.wildfly.security.elytron"/>
<provider-loader name="openssl" module="org.wildfly.openssl"/>
</providers>
<audit-logging>
<file-audit-log name="local-audit" path="audit.log" relative-to="jboss.server.log.dir" format="JSON"/>
</audit-logging>
<security-domains>
<security-domain name="ApplicationDomain" default-realm="ApplicationRealm" permission-mapper="default-permission-mapper">
<realm name="ApplicationRealm" role-decoder="groups-to-roles"/>
<realm name="local"/>
</security-domain>
<security-domain name="ManagementDomain" default-realm="ManagementRealm" permission-mapper="default-permission-mapper">
<realm name="ManagementRealm" role-decoder="groups-to-roles"/>
<realm name="local" role-mapper="super-user-mapper"/>
</security-domain>
</security-domains>
<security-realms>
<identity-realm name="local" identity="$local"/>
<properties-realm name="ApplicationRealm">
<users-properties path="application-users.properties" relative-to="jboss.server.config.dir" digest-realm-name="ApplicationRealm"/>
<groups-properties path="application-roles.properties" relative-to="jboss.server.config.dir"/>
</properties-realm>
<properties-realm name="ManagementRealm">
<users-properties path="mgmt-users.properties" relative-to="jboss.server.config.dir" digest-realm-name="ManagementRealm"/>
<groups-properties path="mgmt-groups.properties" relative-to="jboss.server.config.dir"/>
</properties-realm>
</security-realms>
<mappers>
<simple-permission-mapper name="default-permission-mapper" mapping-mode="first">
<permission-mapping>
<principal name="anonymous"/>
<permission-set name="default-permissions"/>
</permission-mapping>
<permission-mapping match-all="true">
<permission-set name="login-permission"/>
</simple-permission-mapper>
<constant-realm-mapper name="local" realm-name="local"/>
<simple-role-decoder name="groups-to-roles" attribute="groups"/>
<constant-role-mapper name="super-user-mapper">
<role name="SuperUser"/>
</constant-role-mapper>
</mappers>
<permission-sets>
<permission-set name="login-permission">
<permission class-name="org.wildfly.security.auth.permission.LoginPermission"/>
</permission-set>
<permission-set name="default-permissions">
<permission class-name="org.wildfly.extension.batch.jberet.deployment.BatchPermission" module="org.wildfly.extension.batch.jberet" target-name="*"/>
<permission class-name="org.wildfly.transaction.client.RemoteTransactionPermission" module="org.wildfly.transaction.client"/>
<permission class-name="org.jboss.ejb.client.RemoteEJBPermission" module="org.jboss.ejb-client"/>
</permission-set>
</permission-sets>
<http>
<http-authentication-factory name="management-http-authentication" security-domain="ManagementDomain" http-server-mechanism-factory="global">
<mechanism-configuration>
<mechanism mechanism-name="DIGEST">
<mechanism-realm realm-name="ManagementRealm"/>
</mechanism>
</mechanism-configuration>
</http-authentication-factory>
<provider-http-server-mechanism-factory name="global"/>
</http>
<sasl>
<sasl-authentication-factory name="application-sasl-authentication" sasl-server-factory="configured" security-domain="ApplicationDomain">
<mechanism mechanism-name="JBOSS-LOCAL-USER" realm-mapper="local"/>
<mechanism mechanism-name="DIGEST-MD5">
<mechanism-realm realm-name="ApplicationRealm"/>
</mechanism>
</sasl-authentication-factory>
<sasl-authentication-factory name="management-sasl-authentication" sasl-server-factory="configured" security-domain="ManagementDomain">
</mechanism>
<configurable-sasl-server-factory name="configured" sasl-server-factory="elytron">
<properties>
<property name="wildfly.sasl.local-user.default-user" value="$local"/>
</properties>
</configurable-sasl-server-factory>
<mechanism-provider-filtering-sasl-server-factory name="elytron" sasl-server-factory="global">
<filters>
<filter provider-name="WildFlyElytron"/>
</filters>
</mechanism-provider-filtering-sasl-server-factory>
<provider-sasl-server-factory name="global"/>
</sasl>
<tls>
<key-stores>
<key-store name="applicationKS">
<credential-reference clear-text="password"/>
<implementation type="JKS"/>
<file path="application.keystore" relative-to="jboss.server.config.dir"/>
</key-store>
</key-stores>
<key-managers>
<key-manager name="applicationKM" key-store="applicationKS" generate-self-signed-certificate-host="localhost">
</key-manager>
</key-managers>
<server-ssl-contexts>
<server-ssl-context name="applicationSSC" key-manager="applicationKM"/>
</server-ssl-contexts>
</tls>
</subsystem>
<subsystem xmlns="urn:jboss:domain:transactions:6.0">
<core-environment node-identifier="${jboss.tx.node.id:1}">
<process-id>
<uuid/>
</process-id>
</core-environment>
<recovery-environment socket-binding="txn-recovery-environment" status-socket-binding="txn-status-manager"/>
<coordinator-environment statistics-enabled="${wildfly.transactions.statistics-enabled:${wildfly.statistics-enabled:false}}"/>
<object-store path="tx-object-store" relative-to="jboss.server.data.dir"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:weld:4.0"/>
</profile>
<interfaces>
<interface name="management">
<inet-address value="10.250.58.151"/>
</interface>
<interface name="private">
</interface>
<interface name="public">
</interface>
</interfaces>
<socket-binding-group name="standard-sockets" default-interface="public" port-offset="${jboss.socket.binding.port-offset:0}">
<socket-binding name="ajp" port="${jboss.ajp.port:8009}"/>
<socket-binding name="http" port="${jboss.http.port:8080}"/>
<socket-binding name="https" port="${jboss.https.port:8443}"/>
<socket-binding name="jgroups-mping" interface="private" multicast-address="${jboss.default.multicast.address:230.0.0.4}" multicast-port="45700"/>
<socket-binding name="jgroups-tcp" interface="private" port="7600"/>
<socket-binding name="jgroups-tcp-fd" interface="private" port="57600"/>
<socket-binding name="jgroups-udp" interface="private" port="55200" multicast-address="${jboss.default.multicast.address:230.0.0.4}" multicast-port="45688"/>
<socket-binding name="jgroups-udp-fd" interface="private" port="54200"/>
<socket-binding name="management-http" interface="management" port="${jboss.management.http.port:9990}"/>
<socket-binding name="management-https" interface="management" port="${jboss.management.https.port:9993}"/>
<socket-binding name="modcluster" multicast-address="${jboss.modcluster.multicast.address:224.0.1.105}" multicast-port="23364"/>
<socket-binding name="txn-recovery-environment" port="4712"/>
<socket-binding name="txn-status-manager" port="4713"/>
<outbound-socket-binding name="mail-smtp">
<remote-destination host="${jboss.mail.server.host:localhost}" port="${jboss.mail.server.port:25}"/>
</outbound-socket-binding>
<outbound-socket-binding name="remote-cache">
<remote-destination host="10.250.58.154" port="11222"/>
</socket-binding-group>
</server>
l10178
June 11, 2021, 9:24am
5
Maybe helpful,check the Issuer and redirect_uri 。
