Keycloak Connection Admin Console An internal server error has occurred
Hello, I cannot connect to the Keycloak Administration Console. I have a 500 error.
And here is the error in the keycloak logs. Can you help me and tell me where it comes from?
THANKS
ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-290) Uncaught server error: java.lang.NullPointerException: Cannot invoke “org.keycloak.models.AuthenticationFlowModel.getId()” because “flow” is null
at org.keycloak.protocol.AuthorizationEndpointBase.handleBrowserAuthenticationRequest(AuthorizationEndpointBase.java:107)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.buildAuthorizationCodeAuthorizationResponse(AuthorizationEndpoint.java:338)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.process(AuthorizationEndpoint.java:194)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.buildGet(AuthorizationEndpoint.java:112)
at jdk.internal.reflect.GeneratedMethodAccessor33.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:90)
at io.quarkus.vertx.core.runtime.VertxCoreRecorder$13.runWith(VertxCoreRecorder.java:545)
at java.base/java.lang.Thread.run(Thread.java:833)
Looks like you may have changed the browser login flow. If that is the case, you would need to change it manually in the database, or start over.
