Hi, I’m trying to use the keycloak docker image (https://hub.docker.com/r/jboss/keycloak/) with an Oracle DB but I’m stuck.
The Oracle DB is a PDB, which apparently isn’t currently supported because the connection string in the oracle/change-database.cli is as follows:
jdbc:oracle:thin:@${env.DB_ADDR:oracle}:${env.DB_PORT:1521}:${env.DB_DATABASE:XE}${env.JDBC_PARAMS:}
so uses the :<SID>
syntax and is not possible to switch to the /<SERVICE_NAME>
syntax that is necessary to connect to PDBs. So I cloned the repository and I altered the oracle/change-database.cli file setting the connection string to:
jdbc:oracle:thin:@${env.DB_ADDR:oracle}:${env.DB_PORT:1521}${env.ORACLE_DB_SEPARATOR::}${env.DB_DATABASE:XE}${env.JDBC_PARAMS:}
(i.e. changed :${env.DB_DATABASE:XE}
to ${env.ORACLE_DB_SEPARATOR::}${env.DB_DATABASE:XE}
. I then modified the docker-entrypoint.sh
from this:
oracle)
DB_NAME="Oracle"
to this:
oracle)
DB_NAME="Oracle"
if [[ -z ${_ORACLE_DB_SEPARATOR:-} ]]; then
ORACLE_DB_SEPARATOR=":"
fi
which should take care to specify the default env var.
My docker-compose.yml then specifies the following variables:
DB_VENDOR: ORACLE
DB_ADDR: <MY-IP>
DB_PORT: 1521
DB_DATABASE: keycloak
DB_USER: keycloak
DB_PASSWORD: password
KEYCLOAK_USER: admin
KEYCLOAK_PASSWORD: admin
ORACLE_DB_SEPARATOR: "/"
So this should yield a connection string of:
jdbc:oracle:thin:@<MY-IP>:1521/keycloak
Using sqlplus
I cannot connect the user keycloak/password
using the connection url @<MY-IP>:1521/keycloak
so, IMHO, this should work… but it doesn’t:
keycloak_1 | Caused by: javax.resource.ResourceException: IJ031084: Unable to create connection
keycloak_1 | at org.jboss.ironjacamar.jdbcadapters@1.4.22.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:345)
keycloak_1 | at org.jboss.ironjacamar.jdbcadapters@1.4.22.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:352)
keycloak_1 | at org.jboss.ironjacamar.jdbcadapters@1.4.22.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:287)
keycloak_1 | at org.jboss.ironjacamar.impl@1.4.22.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.createConnectionEventListener(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1322)
keycloak_1 | at org.jboss.ironjacamar.impl@1.4.22.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.getConnection(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:499)
keycloak_1 | at org.jboss.ironjacamar.impl@1.4.22.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getSimpleConnection(AbstractPool.java:632)
keycloak_1 | at org.jboss.ironjacamar.impl@1.4.22.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getConnection(AbstractPool.java:604)
keycloak_1 | at org.jboss.ironjacamar.impl@1.4.22.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:624)
keycloak_1 | ... 50 more
keycloak_1 | Caused by: java.sql.SQLException: Listener refused the connection with the following error:
keycloak_1 | ORA-12505, TNS:listener does not currently know of SID given in connect descriptor
keycloak_1 |
keycloak_1 | at com.oracle.jdbc@12.2.0.1.0//oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:774)
keycloak_1 | at com.oracle.jdbc@12.2.0.1.0//oracle.jdbc.driver.PhysicalConnection.connect(PhysicalConnection.java:688)
keycloak_1 | at com.oracle.jdbc@12.2.0.1.0//oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:39)
keycloak_1 | at com.oracle.jdbc@12.2.0.1.0//oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:691)
keycloak_1 | at org.jboss.ironjacamar.jdbcadapters@1.4.22.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:321)
keycloak_1 | ... 57 more
keycloak_1 | Caused by: oracle.net.ns.NetException: Listener refused the connection with the following error:
keycloak_1 |
keycloak_1 | at com.oracle.jdbc@12.2.0.1.0//oracle.net.ns.NSProtocolNIO.negotiateConnection(NSProtocolNIO.java:271)
keycloak_1 | at com.oracle.jdbc@12.2.0.1.0//oracle.net.ns.NSProtocol.connect(NSProtocol.java:317)
keycloak_1 | at com.oracle.jdbc@12.2.0.1.0//oracle.jdbc.driver.T4CConnection.connect(T4CConnection.java:1438)
keycloak_1 | at com.oracle.jdbc@12.2.0.1.0//oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:518)
keycloak_1 | ... 61 more
The Oracle PDB keycloak should be up:
$ lsnrctl status
LSNRCTL for Linux: Version 12.2.0.1.0 - Production on 01-DEC-2020 12:09:46
Copyright (c) 1991, 2016, Oracle. All rights reserved.
Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=IPC)(KEY=EXTPROC1)))
STATUS of the LISTENER
Alias LISTENER
Version TNSLSNR for Linux: Version 12.2.0.1.0 - Production
Start Date 01-DEC-2020 10:37:12
Uptime 0 days 1 hr. 32 min. 33 sec
Trace Level off
Security ON: Local OS Authentication
SNMP OFF
Listener Parameter File /opt/oracle/product/12.2.0.1/dbhome_1/network/admin/listener.ora
Listener Log File /opt/oracle/diag/tnslsnr/6020f0c150b5/listener/alert/log.xml
Listening Endpoints Summary...
(DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=EXTPROC1)))
(DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=0.0.0.0)(PORT=1521)))
(DESCRIPTION=(ADDRESS=(PROTOCOL=tcps)(HOST=6020f0c150b5)(PORT=5500))(Security=(my_wallet_directory=/opt/oracle/admin/IRP/xdb_wallet))(Presentation=HTTP)(Session=RAW))
Services Summary...
Service "IRP" has 1 instance(s).
Instance "IRP", status READY, has 1 handler(s) for this service...
Service "IRPXDB" has 1 instance(s).
Service "b565c8c1ba6b097fe053020011ac99c9" has 1 instance(s).
Service "keycloak" has 1 instance(s).
The command completed successfully
Other info:
LSNRCTL for Linux: Version 12.2.0.1.0 - Production on 01-DEC-2020 12:10:27
Services Summary...
Handler(s):
"DEDICATED" established:10 refused:0 state:ready
LOCAL SERVER
Handler(s):
"D000" established:0 refused:0 current:0 max:1022 state:ready
DISPATCHER <machine: 6020f0c150b5, pid: 2192>
(ADDRESS=(PROTOCOL=tcp)(HOST=6020f0c150b5)(PORT=37305))
Handler(s):
LOCAL SERVER
Handler(s):
LOCAL SERVER
