I set up a EC2 instance on AWS and I run this command:
docker run -p 80:8080 -e KEYCLOAK_USER=admin -e KEYCLOAK_PASSWORD=admin Quay
When I navigate to:
“ec2-XX-XX-XXX-XX.us-east-2.compute.amazonaws(dot)com”
I get:
We are sorry… HTTPS required
I’ve searched at Stack Overflow but not being able to solve it. Some of the posted solutions mention, changing port to 8443
docker run -p 8443:8443 -e KEYCLOAK_USER=username -e KEYCLOAK_PASSWORD=password jboss/keycloak
Yet going to:
“ec2-XX-XX-XXX-XX.us-east-2.compute.amazonaws(dot)com:8443/auth”
Does not resolve. Also testing 8080 does not resolve.
Any ideas?
What is not working on that command (“it doesn’t work” is really vague error description)?:
It works for me. If it is not your case, then of course check the logs first.
But I guess you didn’t configure AWS sec. groups, etc.
AWS configuration is not in the scope of this forum. You should to know how is your AWS infrastructure configured: public/private network, NAT, sec. groups, …
The issue related to the browser not being able to resolve…
Adding port 8443 in the security groups to My IP and forcing “https” on the address solved the issue:
So instead of:
ec2-XX-XX-XX-XX.us-east-2.compute.amazonaws.com:8443/
https://ec2-XX-XX-XX-XX.us-east-2.compute.amazonaws.com:8443/
Solved the issue.
Thx.
