to
/subsystem=datasources/data-source=KeycloakDS: add(jndi-name=java:jboss/datasources/KeycloakDS,enabled=true,use-java-context=true,use-ccm=true, connection-url=jdbc:oracle:thin:@//{env.DB_ADDR:oracle}:{env.DB_PORT:1521}/{env.DB_DATABASE:XE}{env.JDBC_PARAMS:}, driver-name=oracle)
That’s it. It’s working.
Another thing.
Changed keycloak version from 8.0.0 to 10.0.2.
I need to do something more to have the last correct version of Docker Distribution?
Hi Thanks for this update, very useful.
did you however encounter :
database: oracle
version: 18c
jdbc
Caused by: org.hibernate.HibernateException: **Access to DialectResolutionInfo cannot be null when 'hibernate.dialect' not set**
at org.hibernate@5.3.12.Final//org.hibernate.engine.jdbc.dialect.internal.DialectFactoryImpl.determineDialect(DialectFactoryImpl.java:100)
at org.hibernate@5.3.12.Final//org.hibernate.engine.jdbc.dialect.internal.DialectFactoryImpl.buildDialect(DialectFactoryImpl.java:54)
at org.hibernate@5.3.12.Final//org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator.initiateService(JdbcEnvironmentInitiator.java:137)
at org.hibernate@5.3.12.Final//org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator.initiateService(JdbcEnvironmentInitiator.java:35)
at org.hibernate@5.3.12.Final//org.hibernate.boot.registry.internal.StandardServiceRegistryImpl.initiateService(StandardServiceRegistryImpl.java:94)
at org.hibernate@5.3.12.Final//org.hibernate.service.internal.AbstractServiceRegistryImpl.createService(AbstractServiceRegistryImpl.java:263)
