Hello community,
I have the following situation:
In the realm called: test-realm
- An application that uses OIDC for authentication with Keycloak (e.q: we can also use the
security-admin-console
for this example). - A Keycloak Identity provider ‘okta-broker’ used to consume the SAMLResponse from Okta when the user click the Application to initiate the flow.
- A Keycloak SAML 2.0 client ‘test-client-saml-oidc’ with the
IDP-Initiated SSO URL name
:okta-client
- A OKTA identity provider with the IDP-initiated flow setup configured. The Single Sign on URL : {kc_domain}/realms/test-realm/broker/okta-broker/endpoint/clients/okta-client
By default the SAML 2.0 client configured at step 3 will forward the response from Okta to another entity which consumes SAML. For OIDC this doesn’t work out of the box.
What I did was to go to the client Advanced Settings and enable the REDIRECT binding, which I populated with the value of the HomeUrl “http://localhost:8080/admin/test-realm/console” of the ‘security-admin-console’.
Exported client.json:
"clientId": "test-client-saml-oidc",
"bearerOnly": false,
"consentRequired": false,
"standardFlowEnabled": true,
"implicitFlowEnabled": false,
"directAccessGrantsEnabled": true,
"serviceAccountsEnabled": false,
"publicClient": true,
"frontchannelLogout": true,
"protocol": "saml",
"attributes": {
"saml_assertion_consumer_url_redirect": "http://localhost:8080/admin/test-realm/console/",
"saml.force.post.binding": "false",
"saml_idp_initiated_sso_url_name": "okta-client"
"authenticationFlowBindingOverrides": {},
"fullScopeAllowed": true,
"nodeReRegistrationTimeout": -1,
"defaultClientScopes": [
"saml_organization",
"role_list"
"optionalClientScopes": [],
"access": {
"view": true,
"configure": true,
"manage": true
With this method I’m logged in in both the SAML client ‘test-client-saml-oidc’ and the ‘security-admin-console’.
This is possible because the “browser” authentication flow has the “CookieAuthenticator” which will attach a session in security-admin-console
to the root session test-client-saml-oidc
Could a similar logic be added to the SAML client (or a special client implementation) in order to make the IDP-init client to redirect to a OIDC application?
