I have been following Keycloak docs about adding an SSSD User Federation provider instead of using AD/LDAP provider.
- OS: RHEL 7.6
- Keycloak version: 11.0.2 (Docker)
- FreeIPA: freeipa-server:centos-8
- Docker: 19.03.7
Dockerfile
To achieve this in Docker, I installed jna and libunix-dbus-java-0.8.0-1.fc24.x86_64. Since RHEL UBI doesnt have jna in its repo, I added the centos8 repos and installed jna from those repos instead:
RUN microdnf update -y && microdnf install -y glibc-langpack-en gzip hostname java-11-openjdk-headless openssl tar which jna && microdnf clean all
RUN rpm -ivh /tmp/libunix-dbus-java-0.8.0-1.fc24.x86_64.rpm
FreeIPA
On the server I installed sssd-dbus and sssd-tools for debugging and started FreeIPA Server using:
docker run --name freeipa-server-container -it
-h server.freeipa.local
-e PASSWORD=password -
v /sys/fs/cgroup:/sys/fs/cgroup:ro
--sysctl net.ipv6.conf.lo.disable_ipv6=0
-v /var/lib/ipa-data:/data:Z
10.242.0.74/library/freeipa/freeipa-server:centos-8
SSSD
Enrolled my server to the domain and ran federation-sssd-setup.sh on the host to configure /etc/sssd/sssd.conf:
[domain/freeipa.local]
cache_credentials = True
krb5_store_password_if_offline = True
ipa_domain = freeipa.local
id_provider = ipa
auth_provider = ipa
access_provider = ipa
ldap_tls_cacert = /etc/ipa/ca.crt
ldap_user_extra_attrs = mail:mail, sn:sn, givenname:givenname, telephoneNumber:telephoneNumber
ipa_hostname = dockerhost.mydomain
chpass_provider = ipa
ipa_server = _srv_, server.freeipa.local
dns_discovery_domain = freeipa.local
[sssd]
services = nss, sudo, pam, ssh, ifp
debug_level=6
domains = freeipa.local
[nss]
homedir_substring = /home
[pam]
[ifp]
allowed_uids = root
user_attributes = +mail, +telephoneNumber, +givenname, +sn
And /etc/pam.d/keycloak:
auth required pam_sss.so
account required pam_sss.so
Adding user
# ipa user-add testuser --first=test --last=testuser --email=testuser@mydomain.com --phone=042424242 --street="Testing street" --city="Testing city" --state="Testing State" --postalcode=0000000000 --password
Testing sssd-dbus:
# sssctl user-checks testuser -s keycloak
user: testuser
action: acct
service: keycloak
SSSD nss user lookup result:
- user name: testuser
- user id: 1856600005
- group id: 1856600005
- gecos: test testuser
- home directory: /home/testuser
- shell: /bin/sh
SSSD InfoPipe user lookup result:
- name: testuser
- uidNumber: 1856600005
- gidNumber: 1856600005
- homeDirectory: /home/testuser
- loginShell: /bin/sh
testing pam_acct_mgmt
pam_acct_mgmt: Success
PAM Environment:
- no env -
Debus send
# dbus-send --print-reply --system --dest=org.freedesktop.sssd.infopipe /org/freedesktop/sssd/infopipe org.freedesktop.sssd.infopipe.GetUserGroups string:testuser
method return time=1603972476.282837 sender=:1.12056883 -> destination=:1.12057120 serial=34 reply_serial=2
array [
string "ipausers"
Keycloak
Startup
docker run -d --name keycloak \
-v /var/run/dbus:/var/run/dbus:ro \
-v /etc/sssd/sssd.conf:/etc/sssd/sssd.conf:ro \
-v /etc/pam.d/keycloak:/etc/pam.d/keycloak:ro \
-u root -p 8280:8080 \
-l traefik.enable="true" \
-l traefik.http.routers.keycloak-http.entrypoints="http" \
-l traefik.http.routers.keycloak-http.rule="PathPrefix(\`/auth\`)" \
-l traefik.http.routers.keycloak-https.entrypoints="https" \
-l traefik.http.routers.keycloak-https.tls="true" \
-l traefik.http.routers.keycloak-https.rule="PathPrefix(\`/auth\`)" \
-e KEYCLOAK_USER=admin \
-e KEYCLOAK_PASSWORD=password \
-e PROXY_ADDRESS_FORWARDING=true \
myregistry/library/jboss/keycloaktest:11.0.2
The SSSD provider shows up when I launch the admin console, I am able to configure and enable it. However, when trying to log into a web app using Keycloak (this works with ldap provider) I get the following stack trace:
11:34:00,944 WARN [org.keycloak.services] (default task-1) KC-SERVICES0013: Failed authentication: java.lang.NullPointerException
at org.keycloak.federation.sssd.impl.PAMAuthenticator.authenticate(PAMAuthenticator.java:58)
at org.keycloak.federation.sssd.SSSDFederationProvider.isValid(SSSDFederationProvider.java:182)
at org.keycloak.credential.UserCredentialStoreManager.validate(UserCredentialStoreManager.java:187)
at org.keycloak.credential.UserCredentialStoreManager.isValid(UserCredentialStoreManager.java:168)
at org.keycloak.credential.UserCredentialStoreManager.isValid(UserCredentialStoreManager.java:112)
at org.keycloak.authentication.authenticators.browser.AbstractUsernameFormAuthenticator.validatePassword(AbstractUsernameFormAuthenticator.java:199)
at org.keycloak.authentication.authenticators.browser.AbstractUsernameFormAuthenticator.validatePassword(AbstractUsernameFormAuthenticator.java:188)
at org.keycloak.authentication.authenticators.browser.AbstractUsernameFormAuthenticator.validateUserAndPassword(AbstractUsernameFormAuthenticator.java:128)
at org.keycloak.authentication.authenticators.browser.UsernamePasswordForm.validateForm(UsernamePasswordForm.java:55)
at org.keycloak.authentication.authenticators.browser.UsernamePasswordForm.action(UsernamePasswordForm.java:48)
at org.keycloak.authentication.DefaultAuthenticationFlow.processAction(DefaultAuthenticationFlow.java:160)
at org.keycloak.authentication.AuthenticationProcessor.authenticationAction(AuthenticationProcessor.java:938)
at org.keycloak.services.resources.LoginActionsService.processFlow(LoginActionsService.java:311)
at org.keycloak.services.resources.LoginActionsService.processAuthentication(LoginActionsService.java:282)
at org.keycloak.services.resources.LoginActionsService.authenticate(LoginActionsService.java:266)
at org.keycloak.services.resources.LoginActionsService.authenticateForm(LoginActionsService.java:339)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138)
at org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:543)
at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:432)
at org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:393)
at org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:358)
at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:395)
at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:364)
at org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:150)
at org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:104)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
at org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
at org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
at org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:245)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:61)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.keycloak.provider.wildfly.WildFlyRequestFilter.lambda$doFilter$0(WildFlyRequestFilter.java:41)
at org.keycloak.services.filters.AbstractRequestFilter.filter(AbstractRequestFilter.java:43)
at org.keycloak.provider.wildfly.WildFlyRequestFilter.doFilter(WildFlyRequestFilter.java:39)
at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:370)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
at org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1982)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
11:34:00,945 WARN [org.keycloak.events] (default task-1) type=LOGIN_ERROR, realmId=myrealm, clientId=myclient,
userId=null, ipAddress=10.10.10.55, error=invalid_user_credentials, auth_method=openid-connect, auth_type=code,
redirect_uri=https://dockerhost.mydomain/myclient/auth, code_id=ac228c05-36ba-4b52-a6aa-cdd3051aaab3, username=testuser, authSessionParentId=ac228c05-36ba-4b52-a6aa-cdd3051aaab3, authSessionTabId=Vv4GWH_8664
Any clue why this is happening? The user is cached in keycloak and has correct group membership, just as in FreeIPA.
