Keycloak in spring project compatibility in native-images
Hi all,
I don’t really know if I’m at the right place to ask my question or to look for advice.
I am currently trying to create a working native-image for a spring-project that uses keycloak using graalvm. Trying to run my native-image an error occurs that is referred to the use of proxyBeanMethods by the autoconfiguration class of keycloak. I know that native-image does not support cross bean invocations which means that I cannot use keycloak.
However, keycloak is a essential dependency and I would like to know if there is a road map or issue that is focusing on supporting native-image usage in the future.
I currently use keycloak-spring-boot-2-starter version 4.0.0.Final and keycloak-spring-security-adapter version 12.0.04.
Thank you all for your help.
