hi,
I am using keycloak version 12.0.1. I want to store user in ms SQL Sever. Keycloak is working fine default H2 data. I have frontend angular application. when I try to run wildfly adapter to start keycloak,I am getting error message as below: -
08:57:44,180 INFO [org.jboss.as.controller] (Controller Boot Thread) OPVDX002: Failed to pretty print validation error: null
08:57:44,184 ERROR [org.jboss.as.server] (Controller Boot Thread) WFLYSRV0055: Caught exception during boot: org.jboss.as.controller.persistence.ConfigurationPersistenceException: WFLYCTL0085: Failed to parse configuration
at org.jboss.as.controller.persistence.XmlConfigurationPersister.load(XmlConfigurationPersister.java:143)
at org.jboss.as.server.ServerService.boot(ServerService.java:395)
at org.jboss.as.controller.AbstractControllerService$1.run(AbstractControllerService.java:416)
Caused by: javax.xml.stream.XMLStreamException: org.jboss.as.connector.util.ParserException: IJ010061: Unexpected element: connection-url
at org.jboss.as.connector.subsystems.datasources.DataSourcesExtension$DataSourceSubsystemParser.readElement(DataSourcesExtension.java:651)
at org.jboss.as.connector.subsystems.datasources.DataSourcesExtension$DataSourceSubsystemParser.readElement(DataSourcesExtension.java:205)
at org.jboss.staxmapper.XMLMapperImpl.processNested(XMLMapperImpl.java:122)
at org.jboss.staxmapper.XMLExtendedStreamReaderImpl.handleAny(XMLExtendedStreamReaderImpl.java:69)
at org.jboss.as.server.parsing.StandaloneXml_14.parseServerProfile(StandaloneXml_14.java:673)
at org.jboss.as.server.parsing.StandaloneXml_14.readServerElement(StandaloneXml_14.java:243)
at org.jboss.as.server.parsing.StandaloneXml_14.readElement(StandaloneXml_14.java:140)
at org.jboss.as.server.parsing.StandaloneXml.readElement(StandaloneXml.java:138)
at org.jboss.as.server.parsing.StandaloneXml.readElement(StandaloneXml.java:52)
at org.jboss.staxmapper.XMLMapperImpl.parseDocument(XMLMapperImpl.java:76)
at org.jboss.as.controller.persistence.XmlConfigurationPersister.load(XmlConfigurationPersister.java:126)
… 3 more
Caused by: org.jboss.as.connector.util.ParserException: IJ010061: Unexpected element: connection-url
at org.jboss.as.connector.subsystems.datasources.DsParser.parseDataSources(DsParser.java:261)
at org.jboss.as.connector.subsystems.datasources.DsParser.parse(DsParser.java:189)
at org.jboss.as.connector.subsystems.datasources.DataSourcesExtension$DataSourceSubsystemParser.readElement(DataSourcesExtension.java:644)
… 14 more
08:57:44,188 FATAL [org.jboss.as.server] (Controller Boot Thread) WFLYSRV0056: Server boot has failed in an unrecoverable manner; exiting. See previous messages for details.
08:57:44,212 INFO [org.jboss.as] (MSC service thread 1-4) WFLYSRV0050: Keycloak 12.0.1 (WildFly Core 13.0.3.Final) stopped in 13ms
any input on above issue will be highly appreciate.
