dukeim
March 31, 2020, 6:45am
1
Hi.
In the documentation of JavaScript adapter i have found that: " The library can be retrieved directly from the Keycloak server at /auth/js/keycloak.js
and is also distributed as a ZIP archive.", but i couldn’t found it. where really is it?
Regards
Julio
zonaut
March 31, 2020, 10:45am
2
After starting the Keycloak server you can access it from http://localhost:8080/auth/js/keycloak.js
dukeim
March 31, 2020, 4:20pm
3
That works well. Thank you.
in the docker container latest (4 hours ago)
the FRONTEND_URL env var is completely ignored for whatever reason and I’ve had to mount a modified version of the file
in place you can edit it like so… otherwise mount a file
bash-4.4$ sed -i -e 's@${authUrl}js/keycloak.js@${authUrl}/js/keycloak.js@g' themes/keycloak.v2/account/index.ftl
bash-4.4$ cat themes/keycloak.v2/account/index.ftl | grep keycloak.js
<script src="${authUrl}/js/keycloak.js"></script>
I want to change in keycloak.js how can I do it ?
If I changed inside keycloak zip, will it do my work?
Thanka
