I’m trying to deploy Keycloak kubernetes with Microsoft SQL Server. My configs is as follows.
Error connecting to Keycloak database:
"The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: “PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target”.
Keycloak console logs:
Sep 18, 2022 11:23:09 AM org.keycloak.common.crypto.CryptoIntegration detectProvider
INFO: Detected crypto provider: org.keycloak.crypto.def.DefaultCryptoProvider
Added 'admin' to '/opt/jboss/keycloak/standalone/configuration/keycloak-add-user.json', restart server to load user
-b 0.0.0.0
Using Microsoft SQL Server database
11:23:14,952 INFO [org.jboss.modules] (CLI command executor) JBoss Modules version 2.0.2.Final
11:23:15,230 INFO [org.jboss.msc] (CLI command executor) JBoss MSC version 1.4.13.Final
11:23:15,275 INFO [org.jboss.threads] (CLI command executor) JBoss Threads version 2.4.0.Final
11:23:15,805 INFO [org.jboss.as] (MSC service thread 1-2) WFLYSRV0049: Keycloak 19.0.2 (WildFly Core 18.1.1.Final) starting
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.wildfly.extension.elytron.SSLDefinitions (jar:file:/opt/jboss/keycloak/modules/system/layers/base/org/wildfly/extension/elytron/main/wildfly-elytron-integration-18.1.1.Final.jar!/) to method com.sun.net.ssl.internal.ssl.Provider.isFIPS()
WARNING: Please consider reporting this to the maintainers of org.wildfly.extension.elytron.SSLDefinitions
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
11:23:18,034 INFO [org.wildfly.security] (ServerService Thread Pool -- 19) ELY00001: WildFly Elytron version 1.19.0.Final
11:23:20,404 WARN [org.wildfly.extension.elytron] (MSC service thread 1-1) WFLYELY00023: KeyStore file '/opt/jboss/keycloak/standalone/configuration/application.keystore' does not exist. Used blank.
11:23:20,435 WARN [org.wildfly.extension.elytron] (MSC service thread 1-2) WFLYELY01084: KeyStore /opt/jboss/keycloak/standalone/configuration/application.keystore not found, it will be auto generated on first use with a self-signed certificate for host localhost
11:23:20,576 INFO [org.jboss.as.patching] (MSC service thread 1-1) WFLYPAT0050: Keycloak cumulative patch ID is: base, one-off patches include: none
11:23:20,871 INFO [org.jboss.as.server] (Controller Boot Thread) WFLYSRV0212: Resuming server
11:23:20,888 INFO [org.jboss.as] (Controller Boot Thread) WFLYSRV0025: Keycloak 19.0.2 (WildFly Core 18.1.1.Final) started in 5906ms - Started 49 of 72 services (24 services are lazy, passive or on-demand) - Server configuration file in use: standalone.xml
The batch executed successfully
11:23:21,583 INFO [org.jboss.as] (MSC service thread 1-2) WFLYSRV0050: Keycloak 19.0.2 (WildFly Core 18.1.1.Final) stopped in 67ms
11:23:26,204 INFO [org.jboss.modules] (CLI command executor) JBoss Modules version 2.0.2.Final
11:23:26,443 INFO [org.jboss.msc] (CLI command executor) JBoss MSC version 1.4.13.Final
11:23:26,498 INFO [org.jboss.threads] (CLI command executor) JBoss Threads version 2.4.0.Final
11:23:26,810 INFO [org.jboss.as] (MSC service thread 1-2) WFLYSRV0049: Keycloak 19.0.2 (WildFly Core 18.1.1.Final) starting
11:23:28,911 INFO [org.wildfly.security] (ServerService Thread Pool -- 21) ELY00001: WildFly Elytron version 1.19.0.Final
11:23:31,398 WARN [org.wildfly.extension.elytron] (MSC service thread 1-2) WFLYELY00023: KeyStore file '/opt/jboss/keycloak/standalone/configuration/application.keystore' does not exist. Used blank.
11:23:31,440 WARN [org.wildfly.extension.elytron] (MSC service thread 1-1) WFLYELY01084: KeyStore /opt/jboss/keycloak/standalone/configuration/application.keystore not found, it will be auto generated on first use with a self-signed certificate for host localhost
11:23:31,640 INFO [org.jboss.as.patching] (MSC service thread 1-2) WFLYPAT0050: Keycloak cumulative patch ID is: base, one-off patches include: none
11:23:32,128 INFO [org.jboss.as.server] (Controller Boot Thread) WFLYSRV0212: Resuming server
11:23:32,151 INFO [org.jboss.as] (Controller Boot Thread) WFLYSRV0025: Keycloak 19.0.2 (WildFly Core 18.1.1.Final) started in 5924ms - Started 49 of 79 services (31 services are lazy, passive or on-demand) - Server configuration file in use: standalone-ha.xml
11:23:32,816 INFO [org.jboss.as] (MSC service thread 1-1) WFLYSRV0050: Keycloak 19.0.2 (WildFly Core 18.1.1.Final) stopped in 50ms
JBoss Bootstrap Environment
JBOSS_HOME: /opt/jboss/keycloak
JAVA: java
JAVA_OPTS: -server -Xms64m -Xmx512m -XX:MetaspaceSize=96M -XX:MaxMetaspaceSize=256m -Djava.net.preferIPv4Stack=true -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true --add-exports=java.desktop/sun.awt=ALL-UNNAMED --add-exports=java.naming/com.sun.jndi.ldap=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.lang.invoke=ALL-UNNAMED --add-opens=java.base/java.lang.reflect=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.security=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.management/javax.management=ALL-UNNAMED --add-opens=java.naming/javax.naming=ALL-UNNAMED
11:23:56,987 FATAL [org.keycloak.services] (ServerService Thread Pool -- 67) Error during startup: java.lang.RuntimeException: Failed to connect to database
at org.keycloak.keycloak-model-jpa@19.0.2//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.getConnection(DefaultJpaConnectionProviderFactory.java:420)
at org.keycloak.keycloak-model-jpa@19.0.2//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lazyInit(LiquibaseDBLockProvider.java:65)
at org.keycloak.keycloak-model-jpa@19.0.2//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lambda$waitForLock$2(LiquibaseDBLockProvider.java:96)
at org.keycloak.keycloak-server-spi-private@19.0.2//org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:751)
at org.keycloak.keycloak-model-jpa@19.0.2//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.waitForLock(LiquibaseDBLockProvider.java:94)
at org.keycloak.keycloak-services@19.0.2//org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:135)
at org.keycloak.keycloak-server-spi-private@19.0.2//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:250)
at org.keycloak.keycloak-services@19.0.2//org.keycloak.services.resources.KeycloakApplication.startup(KeycloakApplication.java:129)
at org.keycloak.keycloak-wildfly-extensions@19.0.2//org.keycloak.provider.wildfly.WildflyPlatform.onStartup(WildflyPlatform.java:47)
at org.keycloak.keycloak-services@19.0.2//org.keycloak.services.resources.KeycloakApplication.<init>(KeycloakApplication.java:115)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.constructOutsideRequest(ConstructorInjectorImpl.java:225)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:209)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.core.providerfactory.Utils.createProviderInstance(Utils.java:102)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.core.providerfactory.ResteasyProviderFactoryImpl.createProviderInstance(ResteasyProviderFactoryImpl.java:1385)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.core.ResteasyDeploymentImpl.createApplication(ResteasyDeploymentImpl.java:418)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.core.ResteasyDeploymentImpl.initializeObjects(ResteasyDeploymentImpl.java:265)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.core.ResteasyDeploymentImpl.startInternal(ResteasyDeploymentImpl.java:137)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.core.ResteasyDeploymentImpl.start(ResteasyDeploymentImpl.java:121)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:144)
at org.jboss.resteasy.resteasy-core@4.7.6.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:42)
at io.undertow.servlet@2.2.17.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
at org.wildfly.security.elytron-web.undertow-server-servlet@1.10.1.Final//org.wildfly.elytron.web.undertow.server.servlet.RunAsLifecycleInterceptor.doIt(RunAsLifecycleInterceptor.java:70)
at org.wildfly.security.elytron-web.undertow-server-servlet@1.10.1.Final//org.wildfly.elytron.web.undertow.server.servlet.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:76)
at io.undertow.servlet@2.2.17.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
at io.undertow.servlet@2.2.17.Final//io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:309)
at io.undertow.servlet@2.2.17.Final//io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:145)
at io.undertow.servlet@2.2.17.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:588)
at io.undertow.servlet@2.2.17.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:559)
at io.undertow.servlet@2.2.17.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
at io.undertow.servlet@2.2.17.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@26.1.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1544)
at io.undertow.servlet@2.2.17.Final//io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:601)
at org.wildfly.extension.undertow@26.1.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:106)
at org.wildfly.extension.undertow@26.1.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:87)
at org.jboss.threads@2.4.0.Final//org.jboss.threads.JBossThread.run(JBossThread.java:513)
Caused by: java.sql.SQLException: javax.resource.ResourceException: IJ000453: Unable to get managed connection for java:jboss/datasources/KeycloakDS
at org.jboss.ironjacamar.jdbcadapters@1.5.3.Final//org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:159)
at org.jboss.as.connector@26.1.1.Final//org.jboss.as.connector.subsystems.datasources.WildFlyDataSource.getConnection(WildFlyDataSource.java:64)
at org.keycloak.keycloak-model-jpa@19.0.2//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.getConnection(DefaultJpaConnectionProviderFactory.java:414)
... 48 more
Caused by: javax.resource.ResourceException: IJ000453: Unable to get managed connection for java:jboss/datasources/KeycloakDS
at org.jboss.ironjacamar.impl@1.5.3.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:690)
at org.jboss.ironjacamar.impl@1.5.3.Final//org.jboss.jca.core.connectionmanager.tx.TxConnectionManagerImpl.getManagedConnection(TxConnectionManagerImpl.java:440)
at org.jboss.ironjacamar.impl@1.5.3.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.allocateConnection(AbstractConnectionManager.java:789)
at org.jboss.ironjacamar.jdbcadapters@1.5.3.Final//org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:151)
... 50 more
Caused by: javax.resource.ResourceException: IJ031084: Unable to create connection
at org.jboss.ironjacamar.jdbcadapters@1.5.3.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:364)
at org.jboss.ironjacamar.jdbcadapters@1.5.3.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:371)
at org.jboss.ironjacamar.jdbcadapters@1.5.3.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:287)
at org.jboss.ironjacamar.impl@1.5.3.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.createConnectionEventListener(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1328)
at org.jboss.ironjacamar.impl@1.5.3.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.getConnection(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:505)
at org.jboss.ironjacamar.impl@1.5.3.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getSimpleConnection(AbstractPool.java:640)
at org.jboss.ironjacamar.impl@1.5.3.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getConnection(AbstractPool.java:605)
at org.jboss.ironjacamar.impl@1.5.3.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:624)
... 53 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target". ClientConnectionId:4aa97aca-9504-4478-a76b-8a7338929e29
at com.microsoft.sqlserver.jdbc//com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:3680)
at com.microsoft.sqlserver.jdbc//com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:2113)
at com.microsoft.sqlserver.jdbc//com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:3204)
at com.microsoft.sqlserver.jdbc//com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:2833)
at com.microsoft.sqlserver.jdbc//com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:2671)
at com.microsoft.sqlserver.jdbc//com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1640)
at com.microsoft.sqlserver.jdbc//com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:936)
at org.jboss.ironjacamar.jdbcadapters@1.5.3.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:335)
... 60 more
Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.ssl.Alert.createSSLException(Alert.java:131)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:353)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:296)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:291)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:654)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(CertificateMessage.java:473)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(CertificateMessage.java:369)
at java.base/sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:392)
at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:443)
at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:421)
at java.base/sun.security.ssl.TransportContext.dispatch(TransportContext.java:183)
at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:172)
at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1506)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1416)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:456)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:427)
at com.microsoft.sqlserver.jdbc//com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:2021)
... 66 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:439)
at java.base/sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:306)
at java.base/sun.security.validator.Validator.validate(Validator.java:264)
at java.base/sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:313)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:233)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:110)
at com.microsoft.sqlserver.jdbc//com.microsoft.sqlserver.jdbc.TDSChannel$HostNameOverrideX509TrustManager.checkServerTrusted(IOBuffer.java:1702)
at java.base/sun.security.ssl.AbstractTrustManagerWrapper.checkServerTrusted(SSLContextImpl.java:1549)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:638)
... 78 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
at java.base/java.security.cert.CertPathBuilder.build(CertPathBuilder.java:297)
at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:434)
... 86 more
