Hello everyone,
I am trying to secure my existing angular application which is not secured by any means.
So when ever I enter hostname for exmple in local, http://localhost:4200 it shows all pages as I defined.
I am trying to add security by keycloak, so I am following the keycloak-angular - npm and I tried other tutorials as well. It is not showing login page. When I enter localhost 4200 it should show keycloak login page but not doing it. I have created new realm, client and user in my keycloak instance. I have very good experience with keycloak as I have been securing spring boot apps when keycloak version was 4.
Code snippets that I have added for securing my app:
- initializer in appmodule.ts
export function initializeKeycloak(keycloak: KeycloakService) {
return () =>
keycloak.init({
config: {
url: 'http://192.168.49.2:31316/auth',
realm: 'dev-realm',
clientId: 'my-ui',
initOptions: {
onLoad: 'check-sso',
checkLoginIframe: false
I did create realm dev-realm and client named my-ui.
- Providers in app
providers: [
UIService,
provide: APP_INITIALIZER,
useFactory: initConfig,
multi: true,
deps: [ConfigAssetLoaderService]
useFactory: initializeKeycloak,
multi: true,
deps: [KeycloakService],
AuthGuard,
AuthService
- AuthGaurd and AuthService as they showed in the examples.
And also added canActivate in routing as well.
- package.json
"dependencies": {
"@angular/animations": "^12.2.13",
"@angular/cdk": "^12.2.12",
"@angular/common": "~12.2.13",
"@angular/compiler": "~12.2.13",
"@angular/core": "~12.2.13",
"@angular/flex-layout": "^12.0.0-beta.35",
"@angular/forms": "~12.2.13",
"@angular/material": "^12.2.12",
"@angular/material-moment-adapter": "^12.2.12",
"@angular/platform-browser": "~12.2.13",
"@angular/platform-browser-dynamic": "~12.2.13",
"@angular/router": "~12.2.13",
"file-saver": "^2.0.5",
"keycloak-angular": "^8.4.0",
"keycloak-js": "^15.0.2",
"moment": "^2.29.1",
"ngx-currency": "^2.5.3",
"rxjs": "~7.4.0",
"tslib": "^2.3.1",
"zone.js": "~0.11.4"
Everything looks right, but its not showing login page instead its routing to my app directly.
Can you please help me here.
If I give wrong URL of keycloak like adding extra slash in inititalizer then I am getting error page page not found. So it is checking with keycloak but not showing login page.
Thanks in advance
