Greetings, I modified the keycloak.conf file as follows:
db=mssql
db-username=sa
db-password=admin1234
db-url-database=as2_plus
db-url-host=localhost
But when running the command kc.bat start-dev I get the following error:
And in the database if the tables referring to keycloak were created
Because of that error the keycloak server is not running, any ideas?
PS: check the credentials and configuration of the database a thousand times
