Keycloak persistent session not working with custom authentication flow
I have a custom login with recaptcha flow on Keycloak, and I have replaced the usual browser flow in the Keycloak admin dashboard with this one. Here’s the code for the custom class I’m using:
package org.keycloak.authentication.authenticator.recaptcha;
import org.apache.http.HttpResponse;
import org.apache.http.NameValuePair;
import org.apache.http.client.HttpClient;
import org.apache.http.client.entity.UrlEncodedFormEntity;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.message.BasicNameValuePair;
import org.jboss.logging.Logger;
import org.keycloak.authentication.AuthenticationFlowContext;
import org.keycloak.authentication.AuthenticationFlowError;
import org.keycloak.authentication.AuthenticationFlowException;
import org.keycloak.authentication.Authenticator;
import org.keycloak.authentication.authenticators.browser.UsernamePasswordForm;
import org.keycloak.connections.httpclient.HttpClientProvider;
import org.keycloak.events.Details;
import org.keycloak.events.Errors;
import org.keycloak.forms.login.LoginFormsProvider;
import org.keycloak.models.AuthenticatorConfigModel;
import org.keycloak.models.utils.FormMessage;
import org.keycloak.protocol.LoginProtocol.Error;
import org.keycloak.services.ServicesLogger;
import org.keycloak.services.messages.Messages;
import org.keycloak.services.validation.Validation;
import org.keycloak.util.JsonSerialization;
import com.google.zxing.Result;
import jakarta.ws.rs.core.MultivaluedMap;
import jakarta.ws.rs.core.Response;
import java.io.InputStream;
import java.util.*;
public class RecaptchaUsernamePasswordForm extends UsernamePasswordForm implements Authenticator{
    public static final String G_RECAPTCHA_RESPONSE = "g-recaptcha-response";
    public static final String SITE_KEY = "site.key";
    public static final String SITE_SECRET = "secret";
    public static final String USE_RECAPTCHA_NET = "useRecaptchaNet";
    private static final Logger logger = Logger.getLogger(RecaptchaUsernamePasswordForm.class);
    private String siteKey;
    @Override
    public void authenticate(AuthenticationFlowContext context) {
        context.getEvent().detail(Details.AUTH_METHOD, "auth_method");
        displayRecaptcha(context);
        super.authenticate(context);
    private void displayRecaptcha(AuthenticationFlowContext context) {
        AuthenticatorConfigModel captchaConfig = context.getAuthenticatorConfig();
        LoginFormsProvider form = context.form();
        String userLanguageTag = context.getSession().getContext().resolveLocale(context.getUser()).toLanguageTag();
        if (captchaConfig == null || captchaConfig.getConfig() == null
                || captchaConfig.getConfig().get(SITE_KEY) == null
                || captchaConfig.getConfig().get(SITE_SECRET) == null) {
            form.addError(new FormMessage(null, Messages.RECAPTCHA_NOT_CONFIGURED));
            return;
        String siteKey = captchaConfig.getConfig().get(SITE_KEY);
        form.setAttribute("recaptchaRequired", true);
        form.setAttribute("recaptchaSiteKey", siteKey);
        form.addScript("https://www." + getRecaptchaDomain(captchaConfig) + "/recaptcha/api.js?hl=" + userLanguageTag);
    @Override
    public void action(AuthenticationFlowContext context) {
        MultivaluedMap<String, String> formData = context.getHttpRequest().getDecodedFormParameters();
        List<FormMessage> errors = new ArrayList<>();
        boolean success = false;
        String captcha = formData.getFirst(G_RECAPTCHA_RESPONSE);
        if (!Validation.isBlank(captcha)) {
            String secret = captchaConfig.getConfig().get(SITE_SECRET);
            success = validateRecaptcha(context, success, captcha, secret);
        if (success) {
            super.action(context);
        } else {
            errors.add(new FormMessage(null, Messages.RECAPTCHA_FAILED));
            formData.remove(G_RECAPTCHA_RESPONSE);
            context.getEvent().error(Messages.RECAPTCHA_FAILED);
            Response challengeResponse = context.form()
                .setError(Messages.RECAPTCHA_FAILED)
                .createLoginUsernamePassword();
            context.forceChallenge(challengeResponse);
            return;
    private String getRecaptchaDomain(AuthenticatorConfigModel config) {
        Boolean useRecaptcha = Optional.ofNullable(config)
                .map(configModel -> configModel.getConfig())
                .map(cfg -> Boolean.valueOf(cfg.get(USE_RECAPTCHA_NET)))
                .orElse(false);
        if (useRecaptcha) {
            return "recaptcha.net";
        return "google.com";
    protected boolean validateRecaptcha(AuthenticationFlowContext context, boolean success, String captcha, String secret) {
        logger.info("validateRecaptcha(AuthenticationFlowContext, boolean, String, String) start");
        HttpClient httpClient = context.getSession().getProvider(HttpClientProvider.class).getHttpClient();
        HttpPost post = new HttpPost("https://www." + getRecaptchaDomain(context.getAuthenticatorConfig()) + "/recaptcha/api/siteverify");
        List<NameValuePair> formparams = new LinkedList<>();
        formparams.add(new BasicNameValuePair("secret", secret));
        formparams.add(new BasicNameValuePair("response", captcha));
        try {
            UrlEncodedFormEntity form = new UrlEncodedFormEntity(formparams, "UTF-8");
            post.setEntity(form);
            HttpResponse response = httpClient.execute(post);
            InputStream content = response.getEntity().getContent();
            try {
                Map json = JsonSerialization.readValue(content, Map.class);
                Object val = json.get("success");
                success = Boolean.TRUE.equals(val);
            } finally {
                content.close();
        } catch (Exception e) {
            ServicesLogger.LOGGER.recaptchaFailed(e);
        return success;
For some reason, Keycloak’s persistent session using rememberMe is not working with this flow. It does work if I use the default browser flow. Any help or pointers would be appreciated.
Here’s the docker file I use locally if this helps:
FROM quay.io/keycloak/keycloak:22.0 as builder
# Enable health and metrics support
ENV KC_HEALTH_ENABLED=true
ENV KC_METRICS_ENABLED=true
WORKDIR /opt/keycloak
COPY --from=builder /opt/keycloak/ /opt/keycloak/
ADD --chown=keycloak:keycloak providers/ /opt/keycloak/providers/
ENTRYPOINT ["/opt/keycloak/bin/kc.sh", "start-dev --spi-theme-static-max-age=-1 --spi-theme-cache-themes=false --spi-theme-cache-templates=false"]
@manasnisar Does this still happen for later Keycloak versions like V25 or V26?
