Keycloak pod is not getting up | using rh-sso-7/sso76-openshift-rhel8:7.6-23
Getting below message continuously and after sometime pod get restart.
15:29:58,978 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-llbzw timed out (after 3000 ms), on try 0
31515:30:02,530 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-lnmj2 timed out (after 3000 ms), on try 0
31615:30:05,933 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-769b7575c7-chmmt timed out (after 3000 ms), on try 0
31715:30:11,347 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-lnmj2 timed out (after 3000 ms), on try 1
31815:30:14,418 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-llbzw timed out (after 3000 ms), on try 1
31915:30:17,764 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-769b7575c7-chmmt timed out (after 3000 ms), on try 1
32015:30:22,912 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-lnmj2 timed out (after 3000 ms), on try 2
32115:30:26,221 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-769b7575c7-chmmt timed out (after 3000 ms), on try 2
32215:30:29,617 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-llbzw timed out (after 3000 ms), on try 2
32315:30:34,881 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-llbzw timed out (after 3000 ms), on try 3
32415:30:38,181 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-769b7575c7-chmmt timed out (after 3000 ms), on try 3
32515:30:41,598 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-lnmj2 timed out (after 3000 ms), on try 3
32615:30:46,713 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-lnmj2 timed out (after 3000 ms), on try 4
32715:30:50,111 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-86cf6ccc9f-nz5vm: JOIN(ycloak-86cf6ccc9f-nz5vm) sent to ycloak-5b7fbd8fdf-llbzw timed out (after 3000 ms), on try 4
e[0me[31m07:33:12,137 ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) WFLYCTL0348: Timeout after [300] seconds waiting for service container stability. Operation will roll back. Step that first updated the service container was ‘add’ at address ‘[
(“core-service” => “management”),
(“management-interface” => “http-interface”)
e[0me[31m07:33:22,337 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) WFLYCTL0190: Step handler org.jboss.as.controller.ParallelBootOperationStepHandler$2@5b4bdc42 for operation parallel-subsystem-boot at address failed – java.util.concurrent.TimeoutException
e[0me[33m07:33:22,526 WARN [org.jgroups.protocols.pbcast.GMS] (ServerService Thread Pool – 76) ycloak-6985b5bd44-hsjp5: JOIN(ycloak-6985b5bd44-hsjp5) sent to ycloak-6985b5bd44-nmczx timed out (after 3000 ms), on try 9
e[0m
