Hey, thanks for the reply.
I’m using Keycloak 12.0.1 and I have also tried Keycloak 11.
I’m using the Authorization Code flow with no PKCE.
For the client I am using the JAVA Servlet Filter Adapter and it is using this config file:
"realm": "master",
"auth-server-url": "http://localhost:9090/auth/",
"ssl-required": "external",
"resource": "testapp",
"enable-cors": true,
"verify-token-audience": true,
"credentials": {
"secret": "4ee80bf4-93b9-4fd8-814a-495748c1b9d0"
"confidential-port": 0
And this is client configuration in keycloak:
"id": "3618d93f-2c7a-4abe-ad5a-270c1763a42a",
"clientId": "testapp",
"rootUrl": "",
"surrogateAuthRequired": false,
"enabled": true,
"alwaysDisplayInConsole": false,
"clientAuthenticatorType": "client-secret",
"secret": "**********",
"redirectUris": [
"https://192.168.1.77:8443/*"
"webOrigins": [
"https://192.168.1.77:8443"
"notBefore": 0,
"bearerOnly": false,
"consentRequired": false,
"standardFlowEnabled": true,
"implicitFlowEnabled": false,
"directAccessGrantsEnabled": true,
"serviceAccountsEnabled": true,
"authorizationServicesEnabled": true,
"publicClient": false,
"frontchannelLogout": false,
"protocol": "openid-connect",
"attributes": {
"saml.assertion.signature": "false",
"saml.force.post.binding": "false",
"saml.multivalued.roles": "false",
"saml.encrypt": "false",
"saml.server.signature": "false",
"saml.server.signature.keyinfo.ext": "false",
"exclude.session.state.from.auth.response": "false",
"saml_force_name_id_format": "false",
"saml.client.signature": "false",
"tls.client.certificate.bound.access.tokens": "false",
"saml.authnstatement": "false",
"display.on.consent.screen": "false",
"saml.onetimeuse.condition": "false"
"authenticationFlowBindingOverrides": {},
"fullScopeAllowed": false,
"nodeReRegistrationTimeout": -1,
"protocolMappers": [
"id": "8ccecdf9-ded7-4f1c-a015-0483b6aa0a4d",
"name": "Client ID",
"protocolMapper": "oidc-usersessionmodel-note-mapper",
"config": {
"user.session.note": "clientId",
"id.token.claim": "true",
"access.token.claim": "true",
"claim.name": "clientId",
"jsonType.label": "String"
"id": "330a8735-af5f-4899-967f-3805b724de37",
"name": "Client IP Address",
"config": {
"user.session.note": "clientAddress",
"claim.name": "clientAddress",
"id": "16607424-62c2-4416-a445-312963d7b811",
"name": "Client Host",
"config": {
"user.session.note": "clientHost",
"claim.name": "clientHost",
"defaultClientScopes": [
"web-origins",
"role_list",
"profile",
"roles",
"email"
"optionalClientScopes": [
"address",
"phone",
"offline_access",
"microprofile-jwt"
"authorizationSettings": {
"allowRemoteResourceManagement": true,
"policyEnforcementMode": "ENFORCING",
"resources": [
"name": "Default Resource",
"type": "urn:testapp:resources:default",
"ownerManagedAccess": false,
"attributes": {},
"_id": "00c92519-aecf-46be-803f-48b80c58fdbe",
"uris": [
"policies": [
"id": "6a423f9b-3719-4803-b5ff-37b30cb7195d",
"name": "Default Policy",
"description": "A policy that grants access only for users within this realm",
"type": "js",
"logic": "POSITIVE",
"decisionStrategy": "AFFIRMATIVE",
"config": {
"code": "// by default, grants any permission associated with this policy\n$evaluation.grant();\n"
"id": "1382c805-d4cf-4585-801f-85dcaf0360a9",
"name": "Default Permission",
"description": "A permission that applies to the default resource type",
"type": "resource",
"decisionStrategy": "UNANIMOUS",
"config": {
"defaultResourceType": "urn:testapp:resources:default",
"applyPolicies": "[\"Default Policy\"]"
"scopes": [],
I have tried Chrome and Firefox in case that was the issue but nope.
