Keycloak redirects with port number appended to host
Im using Keycloak (24.0.1) on kubernetes on GKE platform. I have used GKE ingress to welcome traffic and routed the traffic through nginx service to remove the unwanted URLs being exposed such as /admin.
Below are my configurations
KC_PROXY_HEADERS="xforwarded"
KC_HTTP_ENABLED="true"
KC_HOSTNAME_STRICT="false"
And i Below is my nginx configuration
location / {
    proxy_set_header Host $host;
    proxy_set_header X-Forwarded-Proto https;
    proxy_pass http://keycloak.backend.svc.cluster.local;
When i try to login from my webapp via keycloak it redirect me to the correct URL but with port number attached to host. like
https://keycloak.mydomain.com:80/realms/master
Any help to fix above is welcome. Thanks
Hey bro, did you get any solution for this?
Yep, set the frontend url to your desired URL from keycloak UI
