Hi, I would like to know if there is a way to loggin roundcube against my Keycloak. In fact, I’m not sure if the configuration is at roundcube or dovecot level.
Thank you
According to: Oauth2 support in roundcube
“OAuth support is currently only available in the git-master version of Roundcube. It will be included in the next major release, version 1.5.”
Once they support OAuth, you should be able to use OpenID with Keycloak.
Thx! I will keep an eye on that
In case I want to change roundcube, do you know any mail service that supports login with keycloak?
