Keycloak Running in Container Thread Error
Running keycloak in a kubernetes cluster, started seeing this issue out of the blue, with no changes on the cluster. It times out randomly.
Any ideas on what could cause it?
Running version:
docker.io/bitnami/keycloak:19.0.3-debian-11-r4
2022-10-26 23:37:23,312 WARN  [io.vertx.core.impl.BlockedThreadChecker] (vertx-blocked-thread-checker) Thread Thread[vert.x-eventloop-thread-5,5,main] has been blocked for 3751 ms, time limit is 2000 ms: io.vertx.core.VertxException: Thread blocked
	at java.base@11.0.17/sun.nio.ch.EPoll.wait(Native Method)
	at java.base@11.0.17/sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:120)
	at java.base@11.0.17/sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:124)
	at java.base@11.0.17/sun.nio.ch.SelectorImpl.select(SelectorImpl.java:141)
	at io.netty.channel.nio.SelectedSelectionKeySetSelector.select(SelectedSelectionKeySetSelector.java:68)
	at io.netty.channel.nio.NioEventLoop.select(NioEventLoop.java:813)
	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:460)
	at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:986)
	at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
	at java.base@11.0.17/java.lang.Thread.run(Thread.java:829)
022-10-26 21:52:53,466 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-15) Failed to create error page: org.infinispan.commons.IllegalLifecycleStateException: ISPN000324: Cache 'realms' is in 'STOPPING' state and this is an invocation not belonging to an on-going transaction, so it does not accept new invocations. Either restart it or recreate the cache container.
