I am trying to integrate a custom openID connect provider with Keycloak , but Keycloak isn’t able to discover the discovery endpoint of the OP.
The endpoint is accessible both via the browser and curl.
curl -ki -X GET http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000/.well-known/openid-configuration
HTTP/1.1 200 OK
Server: Werkzeug/2.2.2 Python/3.7.15
Date: Mon, 19 Dec 2022 14:01:58 GMT
Content-type: application/json; charset=utf-8
Content-Length: 3859
Pragma: no-cache
Cache-Control: no-store
Connection: close
{"version": "3.0", "token_endpoint_auth_methods_supported": ["client_secret_post", "client_secret_basic", "client_secret_jwt", "private_key_jwt"], "claims_parameter_supported": true, "request_parameter_supported": true, "request_uri_parameter_supported": true, "require_request_uri_registration": true, "grant_types_supported": ["authorization_code", "implicit", "urn:ietf:params:oauth:grant-type:jwt-bearer", "refresh_token"], "subject_types_supported": ["public", "pairwise"], "request_object_signing_alg_values_supported": ["RS256", "RS384", "RS512", "ES256", "ES384", "ES512", "HS256", "HS384", "HS512", "PS256", "PS384", "PS512"], "registration_endpoint": "http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000/registration", "introspection_endpoint": "http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000/introspection", "response_types_supported": ["code", "token", "id_token", "code token", "code id_token", "id_token token", "code id_token token", "none"], "response_modes_supported": ["query", "fragment", "form_post"], "request_object_encryption_alg_values_supported": ["RSA-OAEP", "RSA-OAEP-256", "A128KW", "A192KW", "A256KW", "ECDH-ES", "ECDH-ES+A128KW", "ECDH-ES+A192KW", "ECDH-ES+A256KW"], "request_object_encryption_enc_values_supported": ["A128CBC-HS256", "A192CBC-HS384", "A256CBC-HS512", "A128GCM", "A192GCM", "A256GCM"], "claim_types_supported": ["normal", "aggregated", "distributed"], "authorization_endpoint": "http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000/authorization", "token_endpoint_auth_signing_alg_values_supported": ["RS256", "RS384", "RS512", "ES256", "ES384", "ES512", "HS256", "HS384", "HS512", "PS256", "PS384", "PS512"], "token_endpoint": "http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000/token", "userinfo_signing_alg_values_supported": ["RS256", "RS384", "RS512", "ES256", "ES384", "ES512", "HS256", "HS384", "HS512", "PS256", "PS384", "PS512"], "userinfo_encryption_alg_values_supported": ["RSA-OAEP", "RSA-OAEP-256", "A128KW", "A192KW", "A256KW", "ECDH-ES", "ECDH-ES+A128KW", "ECDH-ES+A192KW", "ECDH-ES+A256KW"], "userinfo_encryption_enc_values_supported": ["A128CBC-HS256", "A192CBC-HS384", "A256CBC-HS512", "A128GCM", "A192GCM", "A256GCM"], "client_authn_method": ["bearer_header", "bearer_body"], "userinfo_endpoint": "http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000/userinfo", "frontchannel_logout_supported": true, "frontchannel_logout_session_supported": true, "backchannel_logout_supported": true, "backchannel_logout_session_supported": true, "check_session_iframe": "http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000/check_session_iframe", "end_session_endpoint": "http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000/session", "issuer": "http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000", "acr_values_supported": ["urn:oasis:names:tc:SAML:2.0:ac:classes:InternetProtocolPassword"], "jwks_uri": "http://adain-dev-aps1.workspaces.corp.win.ia55.net:5000/static/jwks.json", "scopes_supported": ["offline_access", "address", "research_and_scholarship", "phone", "profile", "openid", "email"], "claims_supported": ["address", "preferred_username", "family_name", "phone_number", "name", "gender", "sub", "email_verified", "updated_at", "picture", "middle_name", "profile", "email", "nickname", "locale", "birthdate", "iss", "given_name", "website", "eduperson_scoped_affiliation", "phone_number_verified", "zoneinfo"], "id_token_signing_alg_values_supported": ["RS256", "RS384", "RS512", "ES256", "ES384", "ES512", "HS256", "HS384", "HS512", "PS256", "PS384", "PS512"], "id_token_encryption_alg_values_supported": ["RSA-OAEP", "RSA-OAEP-256", "A128KW", "A192KW", "A256KW", "ECDH-ES", "ECDH-ES+A128KW", "ECDH-ES+A192KW", "ECDH-ES+A256KW"], "id_token_encryption_enc_values_supported": ["A128CBC-HS256", "A192CBC-HS384", "A256CBC-HS512", "A128GCM", "A192GCM", "A256GCM"]}
Any leads here are appreciated.
Thanks,
Mohammed Adain
