Keycloak v18 proxy doesn't work on EKS if you are using [ALB+NGINX]
A similar problem is discribed here.
I have a Keycloak v16 which was installed via Bitnami/Keycloak Helm Chart v7.1.7 and it works pretty well.
Now I need to upgrade Keycloak v18 by using Bitnami/Keycloak Helm Chart v9.0.0 .
This is my system:
http/https >>>> ALB (SSL Offloading)>>> (http) Nginx Ingress >>> (http) Keycloak
my existing Keycloak v16 settings are:
extraEnvVars:
  • name: KEYCLOAK_EXTRA_ARGS
    value: “-Dkeycloak.frontendUrl=https://keycloak.mydomain.com/auth”
    proxyAddressForwarding: false
...and here my Keycloak v18 confiuration:
extraEnvVars:
- name: KEYCLOAK_PROXY_ADDRESS_FORWARDING
  value: "true"
- name: KEYCLOAK_FRONTEND_URL
  value: "https://keycloak.mydomain.com/auth"
# - name: KEYCLOAK_EXTRA_ARGS
#   value: "-Dkeycloak.frontendUrl=https://keycloak.mydomain.com/auth"
proxy: passthrough
annotations:
    kubernetes.io/ingress.class: nginx
    nginx.ingress.kubernetes.io/configuration-snippet: |
      location /auth {
        proxy_set_header    X-Real-IP          $remote_addr;
        proxy_set_header    X-Forwarded-Port   $server_port;
        proxy_set_header    X-Forwarded-Proto  $scheme;
        proxy_set_header    X-Forwarded-For    $proxy_add_x_forwarded_for;
        proxy_set_header    X-Forwarded-Host   $host;
        proxy_set_header    X-Forwarded-Server $host;
        proxy_set_header Host keycloak.mydomain.com;
Actually I tried many combainations too many times like:
proxy: passthrough/edge/none/reencrytpt
  • name: KEYCLOAK_PROXY_ADDRESS_FORWARDING
    value: “true/false”
    etc.
None of them work…
Could you please advise is it a bug or am I missing something?
Thanks & Regards
You are using old env variables wirh new Keycloak. Use KC_PROXY: edge Doc Using a reverse proxy - Keycloak
I changed vars as below:
- name: KC_HOSTNAME
- name: KC_HOSTNAME_STRICT
  value: "true"
- name: KEYCLOAK_LOG_LEVEL
  value: DEBUG
- name: JAVA_OPTS
  value: "-Djgroups.dns.query=keycloak-headless.keycloak"
proxy: edge
location /auth {
        proxy_set_header X-Forwarded-Host HTTPS;
        proxy_set_header Host $http_host;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "Upgrade";
        proxy_pass_request_headers on;
…but nothing changed.
Keycloak is still looking for http://…
Is there working pattern which is used for LB level ssl termination?
Thanks & Regards
You have ALB → Nginx → Keycloak = Keycloak behind 2 proxies. Nginx must set X-Forwarded headers based on current X-Forwarded headers (or just hardcode them), not based on request. I guess ALB is doing SSL offloading so nginx receives http request and set it to X-Forwarded header as well. So Keycloak is only following what those proxies configure in X-Forwarded headers. It is your proxy issue, not a Keycloak issue.
Hello @jangaraj
Correct; ALB does SSL offloading, nginx receives http request.
In my scnario, should I set "proxy:edge" or "proxy:passthrough" ?
Thanks & Regards
What will set this config?
http protocol because ALB uses http to reach nginx, so Keycloak is requested ro respond with http protocol
Proxy config is a problem, not Keycloak config now!
So naive solution is to hardcode https
        proxy_set_header Host https:
Others headers may have the same problem. Don’t blame if it is wrong syntax. This is Keycloak forum so don’t expect correct syntax for nginx conf
Sorry @jangaraj I wish it is not related with Keycloak but not sure.
I tried with both;
    nginx.org/server-snippets: |
      location /auth {
        proxy_set_header Host https;
…and
      location /auth {
also I tried the bıth configs above with proxy: edge and proxy: passthrough, nothing works. Keycloak doesn’t care proxy config; nothing changes. Keycloak looks for http:// endpoint persistently.
DEBUG [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-0) Error response 404: javax.ws.rs.NotFoundException: RESTEASY003210: Could not find resource for full path: http://keycloak.mydomain.com/auth/
Sorry, this is my last post here. It really looks like you are not friend with the doc, you have a many errors/testing random config values.
- name: KC_HOSTNAME
Is it areally a hostname? URL is not a hostname.
ok thanks @jangaraj for all your help and advises. I am writing as a reference for others:
I entered there URL because I read something like “KC_HOSTNAME” is the replacement of “KEYCLOAK_FRONTEND_URL” variable in somewhere.
Of course it’s not hard to test it. I tried it as “keycloak.mydomain.com” and also as “keycloak”; nothing changed.
Maybe that’s the same problem:
Thanks & Regards
I encountered the exact same issue while my infrastructure is:
Browser (https)=> ALB (http)=> Nginx (http)=> Keycloak
And I got the “Invalid parameter: redirect_uri” error from Keycloak while I was trying to access the admin console login page.
Thanks for @jangaraj’s hints, the problem should be related to the header x-forwarded-proto / x-forwarded-scheme are http when Keycloak received the request from Nginx, and the redirect_uri is https://… because the browser is using https to access Keycloak.
I think due to the protocol is different which caused Keycloak complaint it.
My solution is to change my infrastructure as below (which made the protocol aligned to use HTTPS):
Browser (https)=> ALB (https)=> Nginx (http)=> Keycloak
The related ALB ingress setting for above change as follow, hope can help other people who encountered the same issue.
kind: Ingress
metadata:
  annotations:
    kubernetes.io/ingress.class: "alb"
    alb.ingress.kubernetes.io/backend-protocol: "HTTPS"
spec:
  rules:
  - host: "*.example.com"
    http:
      paths:
      - path: "/"
        pathType: "Prefix"
        backend:
          service:
            port:
Hi @tirelibirefe,
Try setting up the 2 ENV variables as below:
KC_HOSTNAME → Hostname of your app (e.g. app.domain.com)
KC_HOSTNAME_ADMIN → Admin console Hostname (e.g admin.domain.com)
Thanks
