Custom cache config file:
<infinispan
xsi:schemaLocation="urn:infinispan:config:11.0 http://www.infinispan.org/schemas/infinispan-config-11.0.xsd"
xmlns="urn:infinispan:config:11.0">
<!-- custom stack goes into the jgroups element -->
<jgroups>
<stack name="jdbc-ping-tcp" extends="tcp">
<JDBC_PING connection_driver="org.postgresql.Driver"
connection_username="${env.KC_DB_USERNAME}" connection_password="${env.KC_DB_PASSWORD}"
connection_url="${env.KC_DB_URL}"
initialize_sql="CREATE TABLE IF NOT EXISTS JGROUPSPING (own_addr varchar(200) NOT NULL, cluster_name varchar(200) NOT NULL, ping_data BYTEA, constraint PK_JGROUPSPING PRIMARY KEY (own_addr, cluster_name));"
info_writer_sleep_time="500"
remove_all_data_on_view_change="true"
stack.combine="REPLACE"
stack.position="MPING" />
</stack>
</jgroups>
<!-- custom stack must be referenced by name in the stack attribute of the transport element -->
<transport lock-timeout="60000" stack="jdbc-ping-tcp"/>
<local-cache name="realms">
<encoding>
</encoding>
<memory max-count="10000"/>
</local-cache>
<local-cache name="users">
<encoding>
</encoding>
</local-cache>
<expiration lifespan="-1"/>
</distributed-cache>
<encoding>
</encoding>
</local-cache>
</replicated-cache>
<local-cache name="keys">
<encoding>
</encoding>
<memory max-count="1000"/>
</local-cache>
<encoding>
</encoding>
<memory max-count="-1"/>
</cache-container>
</infinispan>
Fargate environment variables:
{ "name": "KC_LOG_LEVEL", "value": "INFO"},
{ "name" : "KC_DB_URL", "value" : "jdbc:postgresql://${var.db_endpoint}:5432/keycloak" },
{ "name" : "KC_DB_PORT", "value" : "5432" },
{ "name" : "KC_PROXY", "value" : "edge" },
{ "name" : "KC_HOSTNAME", "value" : "keycloak.<mydomain>.com" },
{ "name" : "KC_DB_USERNAME", "value" : "${jsondecode(data.aws_secretsmanager_secret_version.current_secrets.secret_string)["username"]}" },
{ "name" : "KC_DB_PASSWORD", "value" : "${jsondecode(data.aws_secretsmanager_secret_version.current_secrets.secret_string)["password"]}" },
{ "name" : "KEYCLOAK_ADMIN", "value" : "admin" },
{ "name" : "KEYCLOAK_ADMIN_PASSWORD", "value" : "admin" }
Docker file:
FROM quay.io/keycloak/keycloak:latest
ENV KC_CACHE=ispn
ENV KC_CACHE_CONFIG_FILE=cache-ispn-jdbc-ping.xml
ENV KC_FEATURES=token-exchange,preview
ENV KC_HEALTH_ENABLED=true
ENV KC_HTTP_ENABLED=true
ENV KC_HOSTNAME_STRICT=false
ENV KC_HOSTNAME_STRICT_HTTPS=false
ENV KC_DB=postgres
ENV KC_METRICS_ENABLED=true
ENV KC_PROXY=edge
ENV KC_HOSTNAME_STRICT_BACKCHANNEL=false
# COPY conf/keycloak.conf /opt/keycloak/conf/keycloak.conf
COPY ./cache-ispn-jdbc-ping.xml /opt/keycloak/conf/cache-ispn-jdbc-ping.xml
# # COPY ./themes/ /opt/keycloak/themes/ # only applies if you have customized themes
RUN /opt/keycloak/bin/kc.sh build --cache-config-file=cache-ispn-jdbc-ping.xml
WORKDIR /opt/keycloak
EXPOSE 8080 8443
ENTRYPOINT [ "/opt/keycloak/bin/kc.sh" ]
Problem:
Keycloak v21.0 is worked on dev mode but on prod mode, it doesn’t work properly on multiple cluster tasks. I think the fargate tasks can not communicate with each other so anyone can help me to figure out this problem?
