Hi, I am trying to configure Single Sign On using Open Id in Denodo Solution Manager. I was able to obtain most fields from open-id configuration provided by Keycloak except Token role field.
This is the documentation I am using: https://community.denodo.com/docs/html/browse/8.0/en/solution_manager/administration/authentication_and_authorization/authenticating_with_sso/authenticating_with_sso#openid-configuration
Open id settings I got from Keycloak realms → openid configuration.
Denodo now first shows keycloak login page so it is referring to keycloak for IAM. But, upon entering the user credentials in that login page, it does not login into Denodo and instead reopens Denodo login page and shows “Could not obtain access token”.
So my questions are:
- What is Token Role Field? How do I get it from Keycloak?
- I have created a realm, a client app (with denodo urls) and a user in Keycloak. Do I need to define roles to obtain access token?
If somebody has used Keycloak with Denodo, I would appreciate your guidance.
