How do I configure Keycloak in Kubernetes to use MSSQL database?
Regards,
Nikolas
Regards,
Nikolas
I get this error:
[org.jboss.jca.core.connectionmanager.pool.strategy.OnePool] (ServerService Thread Pool – 64) IJ000604: Throwable while attempting to get a new connection: null: javax.resource.ResourceException: IJ031084: Unable to create connection
And here is the deployment:
Solved:
Needed to allow kubernetes in DB firewall :))
Hey,
How did you resolve the issue?
Can you provide your and the manifests files you used for deployment in kubernetes? I need to connect to MSSQL server remotely from the KC pod.
