I was successful at integrating the KeycloakProvider into a simple React Application using such:
return (
<KeycloakProvider
keycloak={KeycloakConfig}
initConfig={InitConfig}
LoadingComponent={LoadingComponent}
onEvent={(event, error) => handleOnEvent(event, error)}
<BrowserRouter basename="/">
<Switch>
<Route path="/error" exact component={ErrorPage}/>
<PrivateRoute path="/home" exact component={HomePage}/>
<PrivateRoute path="/" exact component={HomePage}/>
<PrivateRoute path="" exact component={HomePage}/>
</Switch>
</BrowserRouter>
</KeycloakProvider>
However now we want to externalize authentication as part of a single-spa.js application, see https://single-spa.js.org/, and I am beyond my knowledge to get this working. I copied an existing microservice and loaded it as a “authentication”… such as…
registerApplication({
app: () => System.import("@mysystem/authentication"),
activeWhen: ['/']
app: () => System.import("@mysystem/navigation"),
activeWhen: ['/navigation']
in the root.component.js file of the “Authentication” application… I have the KeycloakProvider as configured above. When I attempt to load the application, http://localhost:9000, I see the LoadingComponent component appear, however the application never gets redirected to the keycloak server for me to login.
I am clueless on how to set this up to properly redirect if a keycloak token does not exist in this architecture. The root-config application seems to be proxying to the authentication application so this may be affecting the KeycloadProvider code.
Any suggestions would be appreciated.
