Hi all,
I using Keycloak in docker container. Its works very well, no problem until here but has a little bit high resource consumption. I made some investigation and found the Keycloak-X server distribution. It based on quarkus stack instead of wildfly. The main goal of this version is consume much more less resources. So I decided to test. I could able to run it but I could not import my realm file properly. When I tried to import configurations into the server, it crashed at the first time, but if I run server again it successfully import and launch. You can see the command that I used;
./kc.sh import --file=/home/ygtysr/test/loginservice/docker/rsc/MY_REALM.json --override=false --profile=dev
So here is my question; How can I import my realm configuration during at the initial stage.
I could able to do it with on Wildfly core stack;
./standalone.sh -Dkeycloak.migration.action=import -Dkeycloak.migration.provider=singleFile -Dkeycloak.migration.file=/opt/jboss/rsc/MY_REALM.json -Dkeycloak.migration.strategy=IGNORE_EXISTING
What is the corresponding command for quarkus stack.
Thanks,
Yigit
