Hello
I’m currently testing the keycloak-x application and i’m trying to run a bash script as soon as keycloak-x is started but with no luck and i’m wondering if anyone got it to work. Here’s my entire process.
1: Building the image with the following:
docker build . --tag keycloak_test_startup:latest
here’s my Dockerfile
FROM quay. io/keycloak/keycloak-x:latest
COPY providers /opt/jboss/keycloak/providers/
COPY startup-scripts /opt/jboss/startup-scripts/
WORKDIR /opt/jboss/keycloak# Creating a self-signed for testing purposes
RUN keytool -genkeypair -storepass password -storetype PKCS12 -keyalg RSA -keysize 2048 -dname “CN=server” -alias server -ext “SAN:c=DNS:localhost,IP:127.0.0.1” -keystore conf/server.keystore# Run the config command to install custom providers
RUN ./bin/kc.sh config
Here’s the content of startup-scripts:
cedric@cedric-work-pc:~/Documents/test$ ls -la ./startup-scripts/
total 96
drwxrwxrwx 2 cedric cedric 4096 Mar 19 14:56 .
drwxrwxr-x 5 cedric cedric 4096 Mar 30 07:46 …
-rwxrwxrwx 1 cedric cedric 85341 Mar 10 08:23 my_realm.json
-rwxrwxrwx 1 cedric cedric 386 Mar 19 13:22 testingfile.sh
testingfile.sh:
#!/bin/bash
echo “inside testingfile”;
for i in {1…10}; do
echo “test: $i”;
sleep 5s
doneecho “after loop”;
/opt/jboss/keycloak/bin/kcadm.sh config credentials --server "http://"localhost:8080/ --realm master --user admin --client admin-cli --password “PASSWORD”;
/opt/jboss/keycloak/bin/kcadm.sh create realms -s realm=demorealm -s enabled=true;
echo “after create realms”;
So far so good, the image get’s built correctly.
Starting up:
docker run --name keycloak_test_startup -p 8080:8080 --net keycloak-network -e KEYCLOAK_ADMIN=admin -e KEYCLOAK_ADMIN_PASSWORD=“PASSWORD” keycloak_test_startup:latest --auto-config --db=postgres -Dkc.db.url.host=“INTERNAL DB ADDRESS” --db-username=keycloak --db-password=“DB PASSWORD” --http-enabled=true
Here’s the output when starting up:
Updating the configuration and installing your custom providers, if any. Please wait.
Server configuration updated and persisted. Run the following command to review the configuration:kc.sh show-config
2021-03-30 11:52:38,019 WARN [org.key.qua.KeycloakRecorder] (main) New property [kc.db.url.host] set with value [“INTERNAL DB ADDRESS”] in [SysPropConfigSource]. This property is not persisted into the server image.
2021-03-30 11:52:38,025 WARN [org.key.qua.KeycloakRecorder] (main) Please, run the ‘config’ command if you want to persist the new configuration into the server image:kc.sh config --db=postgres --db-username=keycloak --db-password=“DB PASSWORD” --http-enabled=true --db-url-host=“INTERNAL DB ADDRESS”
2021-03-30 11:52:39,325 WARN [io.qua.run.ConfigChangeRecorder] (main) Build time property cannot be changed at runtime. quarkus.package.type was fast-jar at build time and is now mutable-jar
2021-03-30 11:52:40,287 INFO [org.key.url.DefaultHostnameProviderFactory] (main) Frontend: , Admin: , Backend:
2021-03-30 11:52:40,451 INFO [org.key.pro.qua.QuarkusCacheManagerProvider] (main) Loading cluster configuration from /opt/jboss/keycloak/bin/…/conf/cluster-default.xml
2021-03-30 11:52:40,898 INFO [org.inf.CONTAINER] (main) ISPN000128: Infinispan version: Infinispan ‘Corona Extra’ 11.0.4.Final
2021-03-30 11:52:41,043 INFO [org.inf.CLUSTER] (main) ISPN000078: Starting JGroups channel ISPN
2021-03-30 11:52:41,043 INFO [org.inf.CLUSTER] (main) ISPN000088: Unable to use any JGroups configuration mechanisms provided in properties {}. Using default JGroups configuration!
2021-03-30 11:52:41,133 WARN [org.jgr.pro.UDP] (main) JGRP000015: the send buffer of socket MulticastSocket was set to 1.00MB, but the OS only allocated 212.99KB
2021-03-30 11:52:41,133 WARN [org.jgr.pro.UDP] (main) JGRP000015: the receive buffer of socket MulticastSocket was set to 20.00MB, but the OS only allocated 212.99KB
2021-03-30 11:52:41,134 WARN [org.jgr.pro.UDP] (main) JGRP000015: the receive buffer of socket MulticastSocket was set to 25.00MB, but the OS only allocated 212.99KB
2021-03-30 11:52:43,144 INFO [org.jgr.pro.pbc.GMS] (main) af4fc943196a-6956: no members discovered after 2003 ms: creating cluster as coordinator
2021-03-30 11:52:43,183 INFO [org.inf.CLUSTER] (main) ISPN000094: Received new cluster view for channel ISPN: [af4fc943196a-6956|0] (1) [af4fc943196a-6956]
2021-03-30 11:52:43,201 INFO [org.inf.CLUSTER] (main) ISPN000079: Channel ISPN local address is af4fc943196a-6956, physical addresses are [172.18.0.3:48112]
2021-03-30 11:52:43,669 INFO [org.key.con.inf.DefaultInfinispanConnectionProviderFactory] (main) Node name: af4fc943196a-6956, Site name: null
2021-03-30 11:52:43,834 INFO [org.key.con.jpa.QuarkusJpaConnectionProviderFactory] (main) Database info: {databaseUrl=jdbc:postgresql://“INTERNAL DB ADDRESS”:5432/keycloak?allowEncodingChanges=false&ApplicationName=PostgreSQL+JDBC+Driver&autosave=never&binaryTransfer=true&binaryTransferDisable=&binaryTransferEnable=&cancelSignalTimeout=10&cleanupSavepoints=false&connectTimeout=10&databaseMetadataCacheFields=65536&databaseMetadataCacheFieldsMiB=5&defaultRowFetchSize=0&disableColumnSanitiser=false&escapeSyntaxCallMode=select&gssEncMode=allow&gsslib=auto&hideUnprivilegedObjects=false&hostRecheckSeconds=10&jaasLogin=true&loadBalanceHosts=false&loginTimeout=0&logServerErrorDetail=true&logUnclosedConnections=false&preferQueryMode=extended&preparedStatementCacheQueries=256&preparedStatementCacheSizeMiB=5&prepareThreshold=5&readOnly=false&readOnlyMode=transaction&receiveBufferSize=-1&reWriteBatchedInserts=false&sendBufferSize=-1&socketTimeout=0&sspiServiceClass=POSTGRES&targetServerType=any&tcpKeepAlive=false&unknownLength=2147483647&useSpnego=false&xmlFactoryFactory=, databaseUser=keycloak, databaseProduct=PostgreSQL 13.1 (Debian 13.1-1.pgdg100+1), databaseDriver=PostgreSQL JDBC Driver 42.2.18}
2021-03-30 11:52:44,660 ERROR [org.key.services] (main) KC-SERVICES0010: Failed to add user ‘admin’ to realm ‘master’: user with username exists
2021-03-30 11:52:45,216 INFO [io.quarkus] (main) Keycloak 12.0.4 on JVM (powered by Quarkus 1.10.0.CR1) started in 7.639s. Listening on: "http://"0.0.0.0:8080 and "https://"0.0.0.0:8443
2021-03-30 11:52:45,217 INFO [io.quarkus] (main) Profile prod activated.
2021-03-30 11:52:45,217 INFO [io.quarkus] (main) Installed features: [agroal, cdi, hibernate-orm, jdbc-h2, jdbc-mariadb, jdbc-mysql, jdbc-postgresql, keycloak, mutiny, narayana-jta, resteasy, resteasy-jackson, smallrye-context-propagation, smallrye-health, smallrye-metrics, vertx, vertx-web]
Sorry for the output mess but i’m not sure how i can make it better.
As it look like, the image started, connected to the DB, admin account was previously created when starting up before, nothing seem to be out of the ordinary at first glance.
I connected to the container to make sure the bash script was indeed in there:
bash-4.4$ ls -la
total 100
drwxr-xr-x 2 root root 4096 Mar 30 11:41 .
drwxrwxr-x 1 jboss root 4096 Mar 30 11:41 …
-rwxrwxrwx 1 root root 85341 Mar 10 13:23 my_realm.json
-rwxrwxrwx 1 root root 386 Mar 19 17:22 testingfile.sh
bash-4.4$ pwd
It is present.
But the file is never executed, no echo in the logs and the realm does not get created, if i login the container and execute the script the realm gets created without any problem.
I’m not sure what i can try anymore, any help would be appreciated.
Thank you!
