Hi.
I am trying to setup infinspan on Keycloak.X to persist to a JDBC cache store. I thought that the new infinispan XML namespace would allow for the same configuration as is available on a dedicated infinispan server, but I might have misundertood that, because I tried setting up a jdbc cache the same way it is done on a dedicated infinispan, and it would not parse. So I looked up the xml schema, and sure that configuration is not available. Is there really no other way to persist to jdbc, than to use a dedicated infinispan server and configuring that as a remote-cache? I was really hoping keycloak.x had a solution for this, because I really want to avoid setting up the infinispan infrastructure if I can.
I got the following error when I tried the configuration below:
ERROR [org.key.cli.Picocli] (main) ERROR: org.infinispan.commons.CacheConfigurationException: ISPN000327: Cannot find a parser for element 'string-keyed-jdbc-store' in namespace 'urn:infinispan:config:11.0'. Check that your configuration is up-to date for Infinispan '11.0.4.Final' and if you have the proper dependency in the classpath
ERROR [org.key.cli.Picocli] (main) ERROR: ISPN000327: Cannot find a parser for element 'string-keyed-jdbc-store' in namespace 'urn:infinispan:config:11.0'. Check that your configuration is up-to date for Infinispan '11.0.4.Final' and if you have the proper dependency in the classpath
Below is my cluster-default.xml configuration.
~ Copyright 2019 Red Hat, Inc. and/or its affiliates
~ and other contributors as indicated by the @author tags.
~ Licensed under the Apache License, Version 2.0 (the "License");
~ you may not use this file except in compliance with the License.
~ You may obtain a copy of the License at
~ http://www.apache.org/licenses/LICENSE-2.0
~ Unless required by applicable law or agreed to in writing, software
~ distributed under the License is distributed on an "AS IS" BASIS,
~ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
~ See the License for the specific language governing permissions and
~ limitations under the License.
<infinispan
xsi:schemaLocation="urn:infinispan:config:11.0 http://www.infinispan.org/schemas/infinispan-config-11.0.xsd"
xmlns="urn:infinispan:config:11.0">
<transport lock-timeout="60000"/>
<local-cache name="realms">
<encoding>
</encoding>
<memory storage="HEAP" max-count="10000"/>
</local-cache>
<local-cache name="users">
<encoding>
</encoding>
</local-cache>
<distributed-cache-configuration name="persistent-jdbc-string-keyed">
<persistence>
<string-keyed-jdbc-store datasource="java:jboss/datasources/PostgresDS" fetch-state="true" preload="false" purge="false" shared="false">
<string-keyed-table prefix="ISPN">
<id-column name="id" type="VARCHAR"/>
<data-column name="datum" type="BYTEA"/>
<timestamp-column name="version" type="BIGINT"/>
</string-keyed-table>
<write-behind modification-queue-size="1024" thread-pool-size="1"/>
</string-keyed-jdbc-store>
</persistence>
</distributed-cache-configuration>
<distributed-cache name="sessions" owners="1" configuration="persistent-jdbc-string-keyed"/>
<distributed-cache name="authenticationSessions" owners="1" configuration="persistent-jdbc-string-keyed"/>
<distributed-cache name="offlineSessions" owners="1" configuration="persistent-jdbc-string-keyed"/>
<distributed-cache name="clientSessions" owners="1" configuration="persistent-jdbc-string-keyed"/>
<distributed-cache name="offlineClientSessions" owners="1" configuration="persistent-jdbc-string-keyed"/>
<distributed-cache name="loginFailures" owners="1" configuration="persistent-jdbc-string-keyed"/>
<encoding>
</encoding>
</local-cache>
<replicated-cache name="work" configuration="persistent-jdbc-string-keyed"/>
<local-cache name="keys">
<encoding>
</encoding>
<memory storage="HEAP" max-count="1000"/>
</local-cache>
<distributed-cache name="actionTokens" owners="2" configuration="persistent-jdbc-string-keyed">
<encoding>
</encoding>
<expiration max-idle="-1" interval="300000"/>
<memory storage="HEAP" max-count="-1"/>
</distributed-cache>
</cache-container>
</infinispan>
