Kyecloak 8.2.2 - User Storage SPI - Users not listed in admin interface
I have created a user storage SPI, exactly as defined in the documentation: https://www.keycloak.org/docs/latest/server_development/index.html#_user-storage-spi
I have implemented the interface UserQueryProvider correctly, but when I go to the admin console in kecloak, Manage -> Users -> View all users, only internal users are displayed. The methods of UserQueryProvider are never called (added some logs to see if they are ever called, and they aren’t)
However, when i search in the same screen for one of my custom users, they show up.Just the method ‘getUsers’ is never called.
Any idea why?
Regards
I am facing the same issue in keycloak 9.0.2. Did you possibly find a solution for that?
I followed the docs and the quickstart user storage jpa example. Login and updating users works fine.
But the UserQueryProvider portion seems to be never used when searching/listing users.
From a log message in the factory’s create method I can see that it is called when searching for users though.
In fact, even with the writeable-property-file quickstart example (https://github.com/keycloak/keycloak-quickstarts/tree/latest/user-storage-simple) I can’t list or search for users and I wonder what I am missing.
Only found this issue which might be related: https://issues.redhat.com/browse/KEYCLOAK-12988
Best regards
Just want to add that searching works for me now with keycloak 9.0.3. Details on this can indeed be found in the issue I posted above.
@mashedpotatoes can you please share the working code, i am also trying to implement user storage SPI but able to fix it. I am using keycloak 10.0.2. I am getting below error
00:52:14,740 WARN [org.keycloak.events] (default task-6) type=LOGIN_ERROR, realmId=master, clientId=security-admin-console, userId=null, ipAddress=127.0.0.1, error=invalid_user_credentials, auth_method=openid-connect, auth_type=code, redirect_uri=http://localhost:8080/auth/admin/master/console/, code_id=52ed33bb-39a3-442b-adba-a7e8ee078579, username=user, authSessionParentId=52ed33bb-39a3-442b-adba-a7e8ee078579, authSessionTabId=O-KRMr9TPRQ
00:52:14,798 ERROR [org.jboss.as.ejb3.invocation] (default task-6) WFLYEJB0034: EJB Invocation failed on component EjbExampleUserStorageProvider for method public void org.keycloak.quickstart.storage.user.EjbExampleUserStorageProvider.close(): javax.ejb.NoSuchEJBException: WFLYEJB0168: Could not find EJB with id UUIDSessionID [422e8cc3-3ac1-47c1-b474-72f5165b7781]
at org.jboss.as.ejb3.component.stateful.StatefulComponentInstanceInterceptor.processInvocation(StatefulComponentInstanceInterceptor.java:55)
at org.jboss.invocation.InterceptorContext.proceed(InterceptorContext.java:422)
at org.jboss.as.ejb3.component.interceptors.AdditionalSetupInterceptor.processInvocation(AdditionalSetupInterceptor.java:54)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:249)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.required(CMTTxInterceptor.java:374)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.processInvocation(CMTTxInterceptor.java:156)
at org.jboss.invocation.InterceptorContext$Invocation.proceed(InterceptorContext.java:509)
at org.jboss.weld.module.ejb.AbstractEJBRequestScopeActivationInterceptor.aroundInvoke(AbstractEJBRequestScopeActivationInterceptor.java:81)
at org.jboss.as.weld.ejb.EjbRequestScopeActivationInterceptor.processInvocation(EjbRequestScopeActivationInterceptor.java:89)
at org.jboss.as.ejb3.component.interceptors.CurrentInvocationContextInterceptor.processInvocation(CurrentInvocationContextInterceptor.java:41)
at org.jboss.as.ejb3.component.invocationmetrics.WaitTimeInterceptor.processInvocation(WaitTimeInterceptor.java:47)
at org.jboss.as.ejb3.security.SecurityContextInterceptor.processInvocation(SecurityContextInterceptor.java:100)
at org.jboss.as.ejb3.deployment.processors.StartupAwaitInterceptor.processInvocation(StartupAwaitInterceptor.java:22)
at org.jboss.as.ejb3.component.interceptors.ShutDownInterceptorFactory$1.processInvocation(ShutDownInterceptorFactory.java:64)
at org.jboss.as.ejb3.component.interceptors.LoggingInterceptor.processInvocation(LoggingInterceptor.java:67)
at org.jboss.as.ee.component.NamespaceContextInterceptor.processInvocation(NamespaceContextInterceptor.java:50)
at org.jboss.invocation.ContextClassLoaderInterceptor.processInvocation(ContextClassLoaderInterceptor.java:60)
at org.jboss.invocation.InterceptorContext.run(InterceptorContext.java:438)
at org.wildfly.security.manager.WildFlySecurityManager.doChecked(WildFlySecurityManager.java:627)
at org.jboss.invocation.AccessCheckingInterceptor.processInvocation(AccessCheckingInterceptor.java:57)
at org.jboss.invocation.ChainedInterceptor.processInvocation(ChainedInterceptor.java:53)
at org.jboss.as.ee.component.ViewService$View.invoke(ViewService.java:198)
at org.jboss.as.ee.component.ViewDescription$1.processInvocation(ViewDescription.java:185)
at org.jboss.as.ee.component.ProxyInvocationHandler.invoke(ProxyInvocationHandler.java:81)
at org.keycloak.quickstart.storage.user.EjbExampleUserStorageProvider$$$view1.close(Unknown Source)
at org.keycloak.services.DefaultKeycloakSession.lambda$close$1(DefaultKeycloakSession.java:327)
at java.lang.Iterable.forEach(Iterable.java:75)
at org.keycloak.services.DefaultKeycloakSession.close(DefaultKeycloakSession.java:333)
at org.keycloak.services.filters.KeycloakSessionServletFilter.closeSession(KeycloakSessionServletFilter.java:131)
at org.keycloak.services.filters.KeycloakSessionServletFilter.doFilter(KeycloakSessionServletFilter.java:96)
at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1541)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:370)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
at org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1982)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
