I’m using the built-in ldap user federation provider and I need to overwrite only the removeUser
feature to disable the user. I know that I can create a new custom provider but
is it possibile to extends all ldap classes and modify only the part of code desired?
This is what I tried until now.
I created these files:
User Storage Provider
package com.blackpoints.storage.ldap;
import org.keycloak.models.KeycloakSession;
import org.keycloak.storage.ldap.idm.store.ldap.LDAPIdentityStore;
import org.keycloak.component.ComponentModel;
import org.keycloak.storage.ldap.LDAPStorageProviderFactory;
public class LDAPStorageProvider extends org.keycloak.storage.ldap.LDAPStorageProvider
public LDAPStorageProvider(LDAPStorageProviderFactory factory, KeycloakSession session, ComponentModel model, LDAPIdentityStore ldapIdentityStore) {
super(factory,session,model,ldapIdentityStore);
User Storage Provider Factory
public class LDAPStorageProviderFactory extends org.keycloak.storage.ldap.LDAPStorageProviderFactory{
@Override
public String getId() {
return "blackpoints-ldap";
POM
~ Copyright 2016 Red Hat, Inc. and/or its affiliates
~ and other contributors as indicated by the @author tags.
~ Licensed under the Apache License, Version 2.0 (the "License");
~ you may not use this file except in compliance with the License.
~ You may obtain a copy of the License at
~ http://www.apache.org/licenses/LICENSE-2.0
~ Unless required by applicable law or agreed to in writing, software
~ distributed under the License is distributed on an "AS IS" BASIS,
~ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
~ See the License for the specific language governing permissions and
~ limitations under the License.
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<name>Keycloak IDPM Provider</name>
<description/>
<modelVersion>4.0.0</modelVersion>
<artifactId>keycloak-idpm-ldap-provider</artifactId>
<groupId>com.blackpoints.keycloak.storage.ldap</groupId>
<version>1.0.0</version>
<packaging>jar</packaging>
<properties>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
</properties>
<dependencies>
<dependency>
<artifactId>keycloak-core</artifactId>
<version>7.0.1</version>
</dependency>
<dependency>
<artifactId>keycloak-server-spi</artifactId>
</dependency>
<dependency>
<artifactId>keycloak-server-spi-private</artifactId>
</dependency>
<dependency>
<artifactId>keycloak-kerberos-federation</artifactId>
</dependency>
<dependency>
<artifactId>keycloak-ldap-federation</artifactId>
</dependency>
<dependency>
<groupId>org.jboss.resteasy</groupId>
<artifactId>resteasy-jaxrs</artifactId>
<version>3.9.0.Final</version>
</dependency>
<dependency>
<groupId>org.jboss.logging</groupId>
<artifactId>jboss-logging</artifactId>
<version>3.4.1.Final</version>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.12</version>
</dependency>
<dependency>
<groupId>org.jboss.spec.javax.transaction</groupId>
<artifactId>jboss-transaction-api_1.2_spec</artifactId>
<version>1.1.1.Final</version>
</dependency>
</dependencies>
<build>
<finalName>idpm-ldap-provider</finalName>
</build>
</project>
jboss deployment structure
<jboss-deployment-structure>
<deployment>
<dependencies>
<module name="junit"/>
<module name="org.keycloak.keycloak-core"/>
<module name="org.keycloak.keycloak-server-spi"/>
<module name="org.keycloak.keycloak-server-spi-private"/>
<module name="org.keycloak.keycloak-kerberos-federation"/>
<module name="org.keycloak.keycloak-ldap-federation"/>
<module name="org.jboss.resteasy.resteasy-jaxrs"/>
<module name="org.jboss.logging.jboss-logging"/>
<module name="org.jboss.spec.javax.transaction.jboss-transaction-api_1.2_spec"/>
<module name="org.keycloak.keycloak-model-jpa"/>
<module name="org.keycloak.keycloak-common"/>
<module name="org.keycloak.keycloak-model-infinispan"/>
<module name="org.keycloak.keycloak-services"/>
</dependencies>
</deployment>
</jboss-deployment-structure>
I create the package jar
with docker image of maven executing the following command:
docker run -it --rm --name my-maven-project -v "$(pwd)":/usr/src/mymaven -w /usr/src/mymaven maven:3.6.1-jdk-14 mvn clean package -e
The build is successful but when copying the jar in the deployments folder the following error occurs:
keycloak_web | 13:13:09,163 WARN [org.jboss.modules.define] (MSC service thread 1-1) Failed to define class com.blackpoints.storage.ldap.LDAPStorageProviderFactory in Module "deployment.idpm-ldap-provider.jar" from Service Module Loader: java.lang.NoClassDefFoundError: Failed to link com/blackpoints/storage/ldap/LDAPStorageProviderFactory (Module "deployment.idpm-ldap-provider.jar" from Service Module Loader): org/keycloak/storage/ldap/LDAPStorageProviderFactory
keycloak_web | at java.lang.ClassLoader.defineClass1(Native Method)
keycloak_web | at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
keycloak_web | at java.lang.ClassLoader.defineClass(ClassLoader.java:839)
keycloak_web | at org.jboss.modules.ModuleClassLoader.doDefineOrLoadClass(ModuleClassLoader.java:424)
keycloak_web | at org.jboss.modules.ModuleClassLoader.defineClass(ModuleClassLoader.java:555)
keycloak_web | at org.jboss.modules.ModuleClassLoader.loadClassLocal(ModuleClassLoader.java:339)
keycloak_web | at org.jboss.modules.ModuleClassLoader$1.loadClassLocal(ModuleClassLoader.java:126)
keycloak_web | at org.jboss.modules.Module.loadModuleClass(Module.java:731)
keycloak_web | at org.jboss.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:247)
keycloak_web | at org.jboss.modules.ConcurrentClassLoader.performLoadClassUnchecked(ConcurrentClassLoader.java:410)
keycloak_web | at org.jboss.modules.ConcurrentClassLoader.performLoadClass(ConcurrentClassLoader.java:398)
keycloak_web | at org.jboss.modules.ConcurrentClassLoader.loadClass(ConcurrentClassLoader.java:116)
keycloak_web | at java.lang.Class.forName0(Native Method)
keycloak_web | at java.lang.Class.forName(Class.java:348)
keycloak_web | at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:370)
keycloak_web | at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404)
keycloak_web | at java.util.ServiceLoader$1.next(ServiceLoader.java:480)
keycloak_web | at org.keycloak.provider.DefaultProviderLoader.load(DefaultProviderLoader.java:60)
keycloak_web | at org.keycloak.provider.ProviderManager.load(ProviderManager.java:92)
keycloak_web | at org.keycloak.services.DefaultKeycloakSessionFactory.loadFactories(DefaultKeycloakSessionFactory.java:214)
keycloak_web | at org.keycloak.services.DefaultKeycloakSessionFactory.deploy(DefaultKeycloakSessionFactory.java:115)
keycloak_web | at org.keycloak.provider.ProviderManagerRegistry.deploy(ProviderManagerRegistry.java:42)
keycloak_web | at org.keycloak.subsystem.server.extension.KeycloakProviderDeploymentProcessor.deploy(KeycloakProviderDeploymentProcessor.java:55)
keycloak_web | at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:176)
keycloak_web | at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1737)
keycloak_web | at org.jboss.msc.service.ServiceControllerImpl$StartTask.execute(ServiceControllerImpl.java:1699)
keycloak_web | at org.jboss.msc.service.ServiceControllerImpl$ControllerTask.run(ServiceControllerImpl.java:1557)
keycloak_web | at org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
keycloak_web | at org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1982)
keycloak_web | at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
keycloak_web | at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
keycloak_web | at java.lang.Thread.run(Thread.java:748)
keycloak_web |
keycloak_web | 13:13:09,169 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-1) MSC000001: Failed to start service jboss.deployment.unit."idpm-ldap-provider.jar".POST_MODULE: org.jboss.msc.service.StartException in service jboss.deployment.unit."idpm-ldap-provider.jar".POST_MODULE: WFLYSRV0153: Failed to process phase POST_MODULE of deployment "idpm-ldap-provider.jar"
keycloak_web | at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:183)
keycloak_web | Caused by: java.lang.NoClassDefFoundError: Failed to link com/blackpoints/storage/ldap/LDAPStorageProviderFactory (Module "deployment.idpm-ldap-provider.jar" from Service Module Loader): org/keycloak/storage/ldap/LDAPStorageProviderFactory
keycloak_web | ... 8 more
keycloak_web |
keycloak_web | 13:13:09,171 ERROR [org.jboss.as.controller.management-operation] (DeploymentScanner-threads - 2) WFLYCTL0013: Operation ("full-replace-deployment") failed - address: ([]) - failure description: {"WFLYCTL0080: Failed services" => {"jboss.deployment.unit.\"idpm-ldap-provider.jar\".POST_MODULE" => "WFLYSRV0153: Failed to process phase POST_MODULE of deployment \"idpm-ldap-provider.jar\"
keycloak_web | Caused by: java.lang.NoClassDefFoundError: Failed to link com/blackpoints/storage/ldap/LDAPStorageProviderFactory (Module \"deployment.idpm-ldap-provider.jar\" from Service Module Loader): org/keycloak/storage/ldap/LDAPStorageProviderFactory"}}
