I read that keycloak automatically converts guid mapper to base64;
so I added the mapper like below and keycloak log after the signin showed me that it is converted into base64.
[LDAP Mapper Config]
Mapper Type : user-attribute-ldap-mapper
LDAP Attribute : objectGUID
[TestGUID]
a40bd535-2ff6-41b6-b73d-0898a0fa5dd4
[Result in the Keycloak Log]
h9dBpMnSAkiLS6KBWJ6+uQ==
The problem is, it does not match with the value I converted using this site : GUID Converter - Tool Slick
It must be “NdULpPYvtkG3PQiYoPpd1A==”.
When I convert “h9…=” back to guid, it’s “A441D787-D2C9-4802-8B4B-A281589EBEB9”, which is different from the guid I received from the ldap.
So I’m now wondering if keycloak adds some kind of salt or what during the conversion…
Is there any way I can purely convert guid into base64?
