Hey guys!
I created a LDAP mapper which allows for editing LDAP attributes through a JS script.
Mapper works fine (for a FILE_TYPE field, in that case I pass script as a file), script is executed and passed LDAP attributes are modified and returned back.
The problem arises when I change FILE_TYPE to a SCRIPT_TYPE.
I create SCRIPT_TYPE field in that way:
property = new ProviderConfigProperty();
property.setType(ProviderConfigProperty.SCRIPT_TYPE);
property.setLabel(ProviderConfigProperty.SCRIPT_TYPE);
property.setName(ProviderConfigProperty.SCRIPT_TYPE);
property.setHelpText("");
property.setDefaultValue("// select script file");
If SCRIPT_TYPE field is selected there are serval problems:
Instead of ‘// select script file’ script content is set to ’ {{config[option.name][0]}} ’
Ignore that “Test test test” string. I was playing around with angular template files and I hardcoded that paragraph inthemes/base/admin/resources/templates/kc-component-config.html
Console prints following error
Error: ui-ace cannot use an object or an array as a model
- When the script content is changed to the correct one, the following error is thrown in the keycloak after saving the mapper settings
12:53:35,352 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-7) Uncaught server error: com.fasterxml.jackson.databind.exc.MismatchedInputException: Cannot deserialize instance of `java.util.ArrayList<java.lang.Object>` out of VALUE_STRING token
at [Source: (io.undertow.servlet.spec.ServletInputStreamImpl); line: 1, column: 264] (through reference chain: org.keycloak.representations.idm.ComponentRepresentation["config"]->org.keycloak.common.util.MultivaluedHashMap["Script"])
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.exc.MismatchedInputException.from(MismatchedInputException.java:59)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.DeserializationContext.reportInputMismatch(DeserializationContext.java:1445)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.DeserializationContext.handleUnexpectedToken(DeserializationContext.java:1219)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.DeserializationContext.handleUnexpectedToken(DeserializationContext.java:1129)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.std.StringCollectionDeserializer.handleNonArray(StringCollectionDeserializer.java:274)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.std.StringCollectionDeserializer.deserialize(StringCollectionDeserializer.java:183)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.std.StringCollectionDeserializer.deserialize(StringCollectionDeserializer.java:173)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.std.StringCollectionDeserializer.deserialize(StringCollectionDeserializer.java:21)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.std.MapDeserializer._readAndBindStringKeyMap(MapDeserializer.java:527)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.std.MapDeserializer.deserialize(MapDeserializer.java:364)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.std.MapDeserializer.deserialize(MapDeserializer.java:29)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeAndSet(MethodProperty.java:129)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.BeanDeserializer.vanillaDeserialize(BeanDeserializer.java:288)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.deser.BeanDeserializer.deserialize(BeanDeserializer.java:151)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.ObjectReader._bind(ObjectReader.java:1682)
at com.fasterxml.jackson.core.jackson-databind@2.10.4//com.fasterxml.jackson.databind.ObjectReader.readValue(ObjectReader.java:977)
at org.jboss.resteasy.resteasy-jackson2-provider@3.12.1.Final//org.jboss.resteasy.plugins.providers.jackson.ResteasyJackson2Provider.readFrom(ResteasyJackson2Provider.java:194)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.interception.AbstractReaderInterceptorContext.readFrom(AbstractReaderInterceptorContext.java:66)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.interception.ServerReaderInterceptorContext.readFrom(ServerReaderInterceptorContext.java:61)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.interception.AbstractReaderInterceptorContext.proceed(AbstractReaderInterceptorContext.java:56)
at org.jboss.resteasy.resteasy-crypto@3.12.1.Final//org.jboss.resteasy.security.doseta.DigitalVerificationInterceptor.aroundReadFrom(DigitalVerificationInterceptor.java:36)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.interception.AbstractReaderInterceptorContext.proceed(AbstractReaderInterceptorContext.java:59)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.MessageBodyParameterInjector.inject(MessageBodyParameterInjector.java:198)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.MethodInjectorImpl.injectArguments(MethodInjectorImpl.java:91)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:113)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:543)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:432)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:393)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:358)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:395)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:364)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:150)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:110)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:141)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:104)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:245)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:61)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.keycloak.keycloak-wildfly-extensions@11.0.0//org.keycloak.provider.wildfly.WildFlyRequestFilter.lambda$doFilter$0(WildFlyRequestFilter.java:41)
at org.keycloak.keycloak-services@11.0.0//org.keycloak.services.filters.AbstractRequestFilter.filter(AbstractRequestFilter.java:43)
at org.keycloak.keycloak-wildfly-extensions@11.0.0//org.keycloak.provider.wildfly.WildFlyRequestFilter.doFilter(WildFlyRequestFilter.java:39)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.core@2.1.3.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.core@2.1.3.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.core@2.1.3.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.core@2.1.3.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.core@2.1.3.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.core@2.1.3.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:370)
at io.undertow.core@2.1.3.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
Is there any way to use SCRIPT_TYPE field in my LDAP mapper?
