LinOTP as OTP Provider for Keycloak
I would like to know whether we have any method to use LinOTP as MFA provider for Keycloak?
Because I want Keycloak to use SMS & Email based OTPs as Multifactor Authentication.
There is a keycloak provider for privacyIDEA, which is a fork of LinOTP.
So either you consider using privacyIDEA, or you check if you can use the privacyIDEA Keycloak Provider with LinOTP.
Thank you very much!!
I tried to use PrivacyIDEA provider with LinOTP. But it seems like not working. Can you suggest me any other methods?
