I moved forward on this topic by continue reading and manipulating the same time.
What I have done so far is to use your gist giving a proper cache-ispn.xml file and make Keycloak use it properly.
Looking at the table jgroupsping
I have one row containing my host.
Embedded infinispan seems to start properly as per Keycloak log:
2022-08-07 15:03:38,534 DEBUG [org.infinispan.quarkus.hibernate.cache.QuarkusInfinispanRegionFactory] (JPA Startup Thread: supplier-store) Starting Infinispan region factory
2022-08-07 15:03:38,560 DEBUG [org.hibernate.internal.SessionFactoryImpl] (JPA Startup Thread: supplier-store) Instantiating session factory with properties: {hibernate.hbm2ddl.auto=update, hibernate.allow_update_outside_transaction=false, hibernate.connection.handling_mode=DELAYED_ACQUISITION_AND_RELEASE_BEFORE_TRANSACTION_COMPLETION, hibernate.dialect=org.hibernate.dialect.PostgreSQLDialect, javax.persistence.transactionType=JTA, hibernate.bytecode.allow_enhancement_as_proxy=true, hibernate.xml_mapping_enabled=false, hibernate.multiTenancy=NONE, hibernate.jdbc.wrap_result_sets=false, hibernate.ejb.persistenceUnitName=supplier-store, hibernate.temp.use_jdbc_metadata_defaults=true, hibernate.transaction.coordinator_class=class org.hibernate.resource.transaction.backend.jta.internal.JtaTransactionCoordinatorBuilderImpl, hibernate.connection.datasource=io.agroal.pool.DataSource@563a5746, hibernate.show_sql=false, hibernate.connection.provider_disables_autocommit=true, hibernate.cache.region.factory_class=org.infinispan.quarkus.hibernate.cache.QuarkusInfinispanRegionFactory, hibernate.order_updates=true}
2022-08-07 15:03:38,580 DEBUG [org.infinispan.quarkus.hibernate.cache.QuarkusInfinispanRegionFactory] (JPA Startup Thread: keycloak-default) Starting Infinispan region factory
2022-08-07 15:03:38,580 DEBUG [org.hibernate.internal.SessionFactoryImpl] (JPA Startup Thread: keycloak-default) Instantiating session factory with properties: {hibernate.allow_update_outside_transaction=false, hibernate.connection.handling_mode=DELAYED_ACQUISITION_AND_RELEASE_BEFORE_TRANSACTION_COMPLETION, hibernate.dialect=io.quarkus.hibernate.orm.runtime.dialect.QuarkusPostgreSQL10Dialect, javax.persistence.transactionType=JTA, hibernate.bytecode.allow_enhancement_as_proxy=true, hibernate.xml_mapping_enabled=false, hibernate.multiTenancy=NONE, hibernate.jdbc.wrap_result_sets=false, hibernate.ejb.persistenceUnitName=keycloak-default, hibernate.temp.use_jdbc_metadata_defaults=true, jboss.as.jpa.managed=false, hibernate.transaction.coordinator_class=class org.hibernate.resource.transaction.backend.jta.internal.JtaTransactionCoordinatorBuilderImpl, kc.query.deleteExpiredClientSessions=delete from PersistentClientSessionEntity sess where sess.userSessionId IN (select u.userSessionId from PersistentUserSessionEntity u where u.realmId = :realmId AND u.offline = :offline AND u.lastSessionRefresh < :lastSessionRefresh), hibernate.query.startup_check=false, hibernate.connection.provider_disables_autocommit=true, hibernate.connection.datasource=io.agroal.pool.DataSource@3d34d26b, hibernate.cache.region.factory_class=org.infinispan.quarkus.hibernate.cache.QuarkusInfinispanRegionFactory, hibernate.order_updates=true}
Instance is well detected aswell:
2022-08-07 15:03:39,754 INFO [org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory] (main) Node name: core-keycloak-51068, Site name: null
However it stills argues that no remote store is configured for cache.
2022-08-07 15:03:39,854 DEBUG [org.keycloak.models.sessions.infinispan.InfinispanUserSessionProviderFactory] (main) No remote store configured for cache âsessionsâ
2022-08-07 15:03:39,854 DEBUG [org.keycloak.models.sessions.infinispan.InfinispanUserSessionProviderFactory] (main) No remote store configured for cache âclientSessionsâ
2022-08-07 15:03:39,855 DEBUG [org.keycloak.models.sessions.infinispan.InfinispanUserSessionProviderFactory] (main) No remote store configured for cache âofflineSessionsâ
2022-08-07 15:03:39,855 DEBUG [org.keycloak.models.sessions.infinispan.InfinispanUserSessionProviderFactory] (main) No remote store configured for cache âofflineClientSessionsâ
2022-08-07 15:03:39,856 DEBUG [org.keycloak.models.sessions.infinispan.InfinispanUserSessionProviderFactory] (main) Skipping pre-loading of userSessions from persistent storage
2022-08-07 15:03:39,859 DEBUG [org.keycloak.cluster.infinispan.CrossDCAwareCacheFactory] (main) No configured remoteStore available. Cross-DC scenario is not used
2022-08-07 15:03:39,869 DEBUG [org.keycloak.cluster.infinispan.InfinispanClusterProviderFactory] (main) Initialized cluster startup time to Sun Aug 07 15:03:38 CEST 2022
2022-08-07 15:03:39,871 DEBUG [org.keycloak.cluster.infinispan.InfinispanNotificationsManager] (main) Added listener for infinispan cache: work
2022-08-07 15:03:39,872 DEBUG [org.keycloak.models.sessions.infinispan.InfinispanUserSessionProviderFactory] (main) Registered cluster listeners
2022-08-07 15:03:39,873 DEBUG [org.keycloak.models.sessions.infinispan.InfinispanUserLoginFailureProviderFactory] (main) No remote store configured for cache âloginFailuresâ
Any idea why?
Per curiosity I also installed an external infinispan on the server, configured it using the same cache-container
and jgroups
section. Navigating to the console website I observe that my keycloak node appears, all cache files correctly created and not used with same message in Keycloak logs (no DC configured).
Any help would be more that welcome.
