I am trying to deploy keycloak 20.0.3 using docker-compose. However i keep getting “loading admin console”
Bellow is the dockerfile I am using as well as the focker-compose.yaml
FROM quay.io/keycloak/keycloak:latest as builder
# Enable health and metrics support
ENV KC_HEALTH_ENABLED=true
ENV KC_METRICS_ENABLED=true
# Configure a database vendor
ENV KC_DB=mariadb
WORKDIR /opt/keycloak
# for demonstration purposes only, please make sure to use proper certificates in production instead
RUN keytool -genkeypair -storepass password -storetype PKCS12 -keyalg RSA -keysize 2048 -dname "CN=server" -alias server -ext "SAN:c=DNS:localhost,IP:127.0.0.1" -keystore conf/server.keystore
COPY --from=builder /opt/keycloak/ /opt/keycloak/
ENTRYPOINT ["/opt/keycloak/bin/kc.sh"]
And the docker compose
version: "3.9"
services:
accounts:
build: .
container_name: Accounts
ports:
- 8080:8080
environment:
- KEYCLOAK_FRONTEND_URL=http://localhost
- KC_HOSTNAME_PORT=8080
- PROXY_ADDRESS_FORWARDING=true
- KC_HOSTNAME=http://localhost
- KEYCLOAK_ADMIN=admin
- KEYCLOAK_ADMIN_PASSWORD=password
- KC_DB_URL_HOST=database
- KC_DB_URL_DATABASE=accounts
- KC_DB_URL_PORT=3306
- KC_DB_USERNAME=keycloak
- KC_DB_PASSWORD=keycloak
# - KC_PROXY=none
- KC_HOSTNAME_STRICT_HTTPS=false
- KC_HOSTNAME_STRICT=false
- KC_HTTP_ENABLED=true
# logging:
# driver: none
restart: always
#command: start --optimized --proxy edge
command: --verbose start --optimized
database:
image: mariadb
container_name: AccountsDatabase
ports:
- 3306:3306
environment:
- MARIADB_ROOT_PASSWORD=root-password
- MYSQL_DATABASE=accounts
- MYSQL_USER=keycloak
- MYSQL_PASSWORD=keycloak
volumes:
- /Temp/Accounts/Databases:/var/lib/mysql
logging:
driver: none
restart: always
