I used to run keycloak, and it was fetching the 17.0.0 version. But then when we changed to the 19 version, I had to adapt a lot of things to make it work. Finally, everything seems to be working, except that I don’t get the admin console.
I always the the page “Loading the admin console” with a spinning circle.
I have googled it non stop, but have no idea how to fix this. Access to realms seem to work, but I don’t know why the admin console doesn’t load.
Here’s my deployment configuration:
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: side-prod
labels:
app: keycloak
service: keycloak
spec:
replicas: 1
selector:
matchLabels:
app: keycloak
service: keycloak
template:
metadata:
labels:
app: keycloak
service: keycloak
spec:
containers:
- name: keycloak
image: quay.io/keycloak/keycloak:latest
args: ["start"]
ports:
- name: http
containerPort: 8080
env:
- name: KC_HOSTNAME_STRICT_HTTPS
value: "false"
value: "false"
- name: KC_TRANSACTION_XA_ENABLED
value: "false"
- name: KC_HTTP_ENABLED
value: "true"
- name: KC_HTTP_RELATIVE_PATH
value: "auth"
- name: KEYCLOAK_USER
value: "admin"
- name: KEYCLOAK_PASSWORD
value: "SOMEPASS"
- name: KEYCLOAK_FRONTEND_URL
value: "https://prod.mydomain.com/auth"
- name: KC_HOSTNAME
value: "prod.mydomain.com"
- name: KC_PROXY
value: "none"
- name: KC_PROXY_ADDRESS_FORWARDING
value: "true"
- name: KC_DB
value: "postgres"
- name: KC_DB_URL
value: "jdbc:postgresql://10.11.11.10/keycloak"
- name: KC_DB_USERNAME
value: "keycloak"
- name: DB_SCHEMA
value: "public"
- name: KC_DB_PASSWORD
value: "REDACTED"
- name: KEYCLOAK_LOGLEVEL
value: "DEBUG"
- name: WILDFLY_LOGLEVEL
value: "DEBUG"
# readinessProbe:
# httpGet:
# path: /auth/realms/master
# port: 8080
I have tried to change the proxy to passthrough and to edge, to no avail.
My ingress is configured like this:
kind: Ingress
metadata:
labels:
app: keycloak
service: keycloak
spec:
ingressClassName: nginx
rules:
- host: prod.mydomain.com
http:
paths:
- path: /auth
pathType: Prefix
backend:
service:
port:
number: 8080
Could anyone give me a hint on how to fix this?
Best,
Francis
