Dear @all
I am working with Keycloaks Spring Boot and Spring Security Adapters.
There are two Docker containers - the Keycloak instance (localhost:8080) and a Spring Boot app (localhost:8081). The app uses keycloak for authentication. Unfortunately, I have exactly the same problem as someone earlier has mentioned in this Issue (see: https://issues.redhat.com/browse/KEYCLOAK-16372?jql=key%20%3D%20KEYCLOAK-16372)
Login is possible since the KEYCLOAK.FRONTEND.URL has been set in the docker compose file. But now the Logout ist not possible anymore.
Error:
o.k.a.RefreshableKeycloakSecurityContext : failed to invoke remote logout
java.net.ConnectException: Connection refused
I would really appreciate some help since i am working on this for my bachelors thesis
Thank you in advance
