Alex7
October 21, 2019, 8:23am
#1
Social login using token exchange does not save attributes when the login is made using the following post request:
/auth/realms/{realmName}/protocol/openid-connect/token
client_id: web_app
client_secret: ****
grant_type: urn:ietf:params:oauth:grant-type:token-exchange
subject_token: github_user_token
subject_issuer: github
It saves the attributes correspondingly when the login is made from the browser accessing the: /auth/realms/{realmName}/account/applications
Am I missing something?
Thanks!
Hi, can I ask if you managed to solve this issue?
I’m facing same problem on jboss/keycloak:10.0.2
Alex7
October 14, 2020, 3:31pm
#3
Unfortunately, I couldn’t find a working solution using KeyCloak API.
I used Firebase authentication with a middleware filter that verifies, if token is valid create a new user or get the existing user from database, if not throw invalid credentials.
If you use Spring Boot you can find a working solution at https://github.com/gladius/firebase-spring-boot-rest-api-authentication
Thanks man, appreciate your response.
we solved it by writng custom mappers (keycloak spi)
Alex7
October 21, 2021, 8:34am
#6
Hi, @kkcmadhu !
Can you provide a code example?
Thanks!
