I am running Keycloak in cluster mode with 1 master and 1 slave. Both have been configure with the same database URL, and the slave is able to connect to the master. When I log in and change settings (like the Realm display name), they are not propagated correctly. I have one session connected to the master, and one session connected to the slave. When I save settings on the master, the slave session doesn’t report the updated settings. I am not sure where to start debugging this. I have checked the domain.xml on both instances and the datasources are identical (pretty much the whole config directory is the same, only the startup arguments are different). Any ideas?
Thanks
